Re: Transmission fluid
[Re: glenngomango]
#3054695
06/30/22 01:46 PM
06/30/22 01:46 PM
Posts: 1,239 Chicago, IL
PLUM_72
Chicago, IL
Pick something...Cause what ever you choose, it will be all over the floor over the winter as the car sits and experiences converter drain back. It will give you the opportunity to drain and try something else as you chase the leaks. LOL!
1972 Dodge Challenger
[Re: stumpy]
#3054930
07/01/22 12:39 PM
07/01/22 12:39 PM
Posts: 26,044 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Nothing "stops" drainback..the Transgo kit just allows refill in Park.
[Re: John_Kunkel]
#3054935
07/01/22 12:53 PM
07/01/22 12:53 PM
Posts: 43,367 Bend,OR USA
Cab_Burge
Nothing "stops" drainback..the Transgo kit just allows refill in Park. Don't those kits allow the pump to flow fluid in park also?
[Re: Cab_Burge]
#3054952
07/01/22 02:43 PM
07/01/22 02:43 PM
John_Kunkel
Rio Linda, CA
If the crankshaft is turning, the pump is pumping but, in Park, some of the output flows out the manual valve and converter refill is slow. The TG valve seals off the manual valve so the converter refills quicker.
