stock replacement leaf springs?
#3052742
06/23/22 03:22 PM
06/23/22 03:22 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Who has good quality stock replacement leaf springs? Specifically for a '70 challenger R/T w/ a 440/727/8.75. Just a street cruiser. Eaton/Detroit Spring has them for $800 a pair. Year one has them for about $400 a pair. Mancini has Mopar Performance restoration springs for roughly $275 a pair. I'm leery of the MP springs b/c the newer super stock mexican made springs are junk...as is most everything "made" by Mopar Performance. Not looking for OE perfect, but not wanting junk that'll need replacing in a year either.
Suggestions?
Re: stock replacement leaf springs?
[Re: moparx]
#3052754
06/23/22 03:57 PM
06/23/22 03:57 PM
an8sec70cuda
what about adding a leaf from another spring pack ? just throwing something out there to consider. Might have to if we can't find new ones. This car was just put back on the road and after driving it a little bit, we've realized just how much the original springs have sagged.
[Re: topside]
#3052765
06/23/22 04:35 PM
06/23/22 04:35 PM
an8sec70cuda
ESPO / Springs 'n Things makes a good product; I've used their springs on a couple of Mopars. There's also the option of Hellwig EZ550 helper springs. ESPO has them for $260 a pair! 4 week lead time, but that's alright. Thanks!
[Re: topside]
#3052821
06/23/22 09:15 PM
06/23/22 09:15 PM
Posts: 15,374 Omaha Ne
TJP
Omaha Ne
ESPO / Springs 'n Things makes a good product; I've used their springs on a couple of Mopars. X2 I've used Laura for over 20 years on a multitude of customers cars ZERO issues OOPS!! responded before iI saw your post
[Re: moparx]
#3052861
06/24/22 02:03 AM
06/24/22 02:03 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
what about adding a leaf from another spring pack ? This. Worked for me. Added to each side one more of the second layer, the longest leaf without eyes, about 1975 to my '69 A body that had wheel hop. Almost 50 years later, both spring assemblies are functioning as designed. The rear of the car sits about 1" higher than spec, which I think gives it a very nice stance for a muscle car.
[Re: an8sec70cuda]
#3052907
06/24/22 10:23 AM
06/24/22 10:23 AM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
Yep. Many years ago.....(here comes the boring story).........
OK I will shorten it up. I went after that at one point.
Chrysler's Mexico spring plant KNOWS how to make leaf springs. I've had a couple Rams with 200k + miles on the original springs and no problems. Plant Engr defended their process, even pulled several from production to prove they were making MP springs to print......This was true....however the prints allow way too much variation, and don't get detailed enough to make as consistent a product as I would prefer.
I'm not going to say exactly what information is missing from the OEM stock replacement XHD spring prints as well as the SS prints, but it was substantial in that there was just not enough detail in them.
I tried but was not able to get an MP engineer on board with an addendum or alteration to the '60s specs. I think he had bigger fish to fry at the time.
The MP springs are hit and miss, and that's not going to change. The SS springs on my car were reworked by a local spring shop and that's probably why they have not sagged out.
It'd probably be a better story to tell over a couple beers, tacos, or both. I forgot to contact you the one time we went to Myrtle Beach, remembered on the way home, and was mad at myself for a couple days about that.
Rich H.
Esse Quam Videri
[Re: an8sec70cuda]
#3052917
06/24/22 10:50 AM
06/24/22 10:50 AM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
I have used Eaton on three different occasions with three different cars. They are really great. Easy to deal with, arrive quickly, look very factory. I have not had problems with sagging with them over time. I do normally order them at a +1 inch to get a little more stance. Also, for cars that are very part number correct, I swap the small leaf on each side with the original that has the part number on them. So yes they are pricey, but they are really good. They come with the bushing pressed in place in case you are curious.
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: Kowal]
#3052944
06/24/22 11:41 AM
06/24/22 11:41 AM
Posts: 1,794 Greer, SC
TooMany62s
Greer, SC
I have used Eaton on three different occasions with three different cars. They are really great. Easy to deal with, arrive quickly, look very factory. I have not had problems with sagging with them over time. I do normally order them at a +1 inch to get a little more stance. Also, for cars that are very part number correct, I swap the small leaf on each side with the original that has the part number on them. So yes they are pricey, but they are really good. They come with the bushing pressed in place in case you are curious. Here ya go:https://www.eatondetroitspring.com/
[Re: ZIPPY]
#3053727
06/27/22 08:13 AM
06/27/22 08:13 AM
an8sec70cuda
Thanks for the suggestions yall. We'll be getting stock height HD springs from ESPO.
Zippy...definitely let me know if you come back down this way!
