Re: A body race weight
[Re: justinp61]
#305145
05/02/09 09:39 AM
05/02/09 09:39 AM
My '70 duster weights 3180...
#305146
05/02/09 09:58 AM
05/02/09 09:58 AM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
You guys are all so heavy. Mine is 2329 without me in it. glass bumpers, deck lid, hood, doors, steel fenders, fabricated mounts for bumpers, tube chassis, lexan, 10" motor setback, full aluminum interior, and best of all SMALL BLOCK. Moving the motor back is the easiest way to get your balance a little better. I know it is not always cheap,, but.
[Re: Al_Alguire]
#305148
05/02/09 10:59 AM
05/02/09 10:59 AM
Posts: 4,980 new jersey usa
11secdart
new jersey usa
68 Dart, 365 in. S/B 904 3150 lbs with me, 2930 with out. Bench seat, no back seat, glass bumpers, hood and deck lid, one battery.
Post deleted by Defbob
[Re: BBLM23]
#305152
05/02/09 02:40 PM
05/02/09 02:40 PM
#305153
05/02/09 03:41 PM
05/02/09 03:41 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Mine was 2780lbs with me in it, iron headed small block, backhalf, fiberglass dash, hood, bumpers, a racing seat, 904, 9" Ford, stock k-frame and four wheel drums.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Jacob Pitt]
#305154
05/02/09 03:56 PM
05/02/09 03:56 PM
Posts: 3,210 robin hood country
deaks
robin hood country
What sort of weight loss would a swap from kelsey hayes discs to wilwoods be. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Jacob Pitt]
#305155
05/02/09 04:12 PM
05/02/09 04:12 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Mine weighed 2830 lbs. with me in it. Iron head 340, 727, 8 3/4" w/11" x 3" drums, fiberglass ft. fenders, hood, Lexan windows, full 8 gallon cell and 2 Group 27 batteries.
Since I broke the rear end, I swapped the 8 3/4" for a Dana 60 w/ MW aluminum spool, 40 spline gun-drilled axles, 4-wheel Aerospace dics, 904, LRT crossmember and .750" CM fabbed steering. Oh, and a MP aluminum master cylinder.
I estimate it will weigh 2730 lb. when its done. Unfortunately, my gut has saw fit to try keeping up with my age or it would be about 30 lb. lighter.
[Re: S/ST 3040]
#305156
05/02/09 05:26 PM
05/02/09 05:26 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
i really thought the scales where wrong when i weighed my duster.. but it my just be accurate after seeing some of your weights.. 3410 with me in it.. for reference. all steel body 72 duster. stock glass.steel bumpers and brakets 2 race seats,no rear seat no spare tire well.sheetmetal trunk floor 8 gal plastic fuel cell..1 batt. cromolly 10 pt cage. no heater guts, w/ carpet and otherwise stock interior 73 disc's with stock k frame alloy wheels. 360 with 727 8.75 rear. alloy drive shaft. leaf springs.. and 1 no2 bottle. 54/46 bias..
"I need to invest in some fiberglass and lexan" cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#305157
05/02/09 05:41 PM
05/02/09 05:41 PM
Posts: 850 Georgetown, TX
sc4579
Georgetown, TX
Mine is 3290 with me in it. All steel, iron head small block, full dash, factory buckets, 8pt roll bar, frame connectors, dual batteries and stock gas tank.
2023 Challenger Scat Pack 1320 2016 Jeep Renegade
