Page 1 of 4 1 2 3 4
The quest for 4’s #3049432
06/10/22 03:16 PM
06/10/22 03:16 PM
Dayton, OH
1980volare Offline OP
My man card has just been revoked.
Dayton, OH
Made a few changes over the winter, 3.55 to 4.10, tighter front shocks(still not tight enough), air to water intercooler(60lb on the front end).
3825 race weight
Been stuck in the 1.30s finally got it acting right with a gear change. This was 1.24 on the rear tires, and pedaled 3 times and still managed to go a 5.29. So close to 4s I can feel it. https://youtu.be/x7e-ruxqxJQ
Re: The quest for 4’s [Re: 1980volare] #3049437
06/10/22 03:32 PM
06/10/22 03:32 PM
Cab_Burge Online work
Cab_Burge  Online Work
Make it stick from the hit and you will make a big difference in all the incremental times wrench up scope twocents
Re: The quest for 4’s [Re: 1980volare] #3049438
06/10/22 03:35 PM
06/10/22 03:35 PM
WI
mopar873 Offline
mopar873  Offline
WI
That thing is a beast....
Re: The quest for 4’s [Re: 1980volare] #3049445
06/10/22 04:07 PM
06/10/22 04:07 PM
PA
moparacer Offline
moparacer  Offline
PA
Oh ya that's the way...60 footin with the back tires and no sissy bars......
Fix the left hand drift with some preload, tighten the front shocks up some and let it eat.
Is perfect when it smokes the fronts when it sets them down about 200 ft. out hehe.....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: The quest for 4’s [Re: moparacer] #3049503
06/10/22 09:16 PM
06/10/22 09:16 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Moves out for sure. Once you get it under control and if everything is good in combo/performance it'll definitely be in the 4's. Nice piece.
"Any fool can know. The point is to understand"
- A. Einstein
Re: The quest for 4’s [Re: 1980volare] #3049856
06/12/22 10:05 AM
06/12/22 10:05 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
You racing no prep ? Try some radials and get on a prep surface , instant 4’s . Otherwise if you going in the 4’s with 1.20 60 foots , you making some power out the back !
....BAD A$$ STREET CAR.....
Re: The quest for 4’s [Re: n20mstr] #3049890
06/12/22 11:42 AM
06/12/22 11:42 AM
Dayton, OH
Dayton, OH
Radials and normal weekly test and tune prep, so it’s basically no prep.
Re: The quest for 4’s [Re: 1980volare] #3049901
06/12/22 12:20 PM
06/12/22 12:20 PM
N
n20mstr Offline
n20mstr  Offline
N
Radials with out decent prep , with a car like yours not going
To work well . Get on a radial prep track and you will run well . Otherwise you compromise your potential.
Re: The quest for 4’s [Re: n20mstr] #3049904
06/12/22 12:30 PM
06/12/22 12:30 PM
N
n20mstr Offline
n20mstr  Offline
N
Watching the vid , that’s a power wheelie . Get more weigh up front . Honestly it looks like it separating pretty fast . A tad tighter on the rear extension And more power early . But it will need better prep . What ECU ? A ride height sensor or Davis VPS will help a lot
Re: The quest for 4’s [Re: n20mstr] #3049907
06/12/22 12:35 PM
06/12/22 12:35 PM
Dayton, OH
Dayton, OH
It works pretty good just about everywhere.
Re: The quest for 4’s [Re: 1980volare] #3049950
06/12/22 02:46 PM
06/12/22 02:46 PM
N
n20mstr Offline
n20mstr  Offline
N
Is it a NT car ? What mph does it run ?
Re: The quest for 4’s [Re: n20mstr] #3049975
06/12/22 04:15 PM
06/12/22 04:15 PM
Dayton, OH
Dayton, OH
Nope I’m not ashamed. 137-140 usually.
Re: The quest for 4’s [Re: 1980volare] #3049978
06/12/22 04:35 PM
06/12/22 04:35 PM
N
n20mstr Offline
n20mstr  Offline
N
You need to 60 in the teens to go 4.90’s with that mph
Re: The quest for 4’s [Re: 1980volare] #3050099
06/13/22 08:59 AM
06/13/22 08:59 AM
an8sec70cuda Offline
That thing is nasty! up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: The quest for 4’s [Re: n20mstr] #3050200
06/13/22 01:22 PM
06/13/22 01:22 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Agreed....We have been 4.90's but with a 1.09 60' but again its just a lowly NA smallblock on a 29.5x20.5 slick with that MPH.
Re: The quest for 4’s [Re: Al_Alguire] #3050283
06/13/22 06:50 PM
06/13/22 06:50 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Al what’s that Corvette weigh? That rig definitely gets down the track with purpose.
- A. Einstein
Re: The quest for 4’s [Re: EvilB1Dart] #3050315
06/13/22 09:23 PM
06/13/22 09:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Just under 2800lbs usually. Depending on track we may add some weight to it to help. We cannot make NMCA or the WCNA minimum.
Re: The quest for 4’s [Re: 1980volare] #3050370
06/14/22 06:44 AM
06/14/22 06:44 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Nothing to add here just a Bads A$$ car up
Re: The quest for 4’s [Re: racerx] #3050374
06/14/22 07:12 AM
06/14/22 07:12 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Been awhile since I've seen this thing run in person. Cool ride for sure. As a few of you know, deep down I'm an F body guy. The fact that it is so quick and is not light is really impressive.
Doug
Re: The quest for 4’s [Re: dvw] #3050381
06/14/22 07:55 AM
06/14/22 07:55 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Very impressive car, nice work!
Page 1 of 4 1 2 3 4
