Still chipping away. Watched a lot of video of the last outing and determined the rear is separating too fast when the power comes in. Went and ran a true street class Friday, 275, tags and insurance ect. Front rd one it kept getting better as far as wheelies, I kept tightening rear extension, never touched the boost controller or changed the tuneup. Went a best of 1.23 but averaged around 1.25 60’. I think it’ll take a bunch more with the new shock adjustment, didn’t want to get too greedy with how consistent it was. Best et and mph was 5.16 139
That MPH in the 1/8 mile for that ET is really impressive: bow How much boost does it make with which blower or supercharger type and size are you using and if you don't mind what RPM does it leave the starting line at and what shift RPM and finish line RPM does it cross at: The reason I'm asking these questions is that I'm the middle of buying parts for a crank driven Vortech super charger for my new drag car, BB on E85 with B1-MC heads in a 1965 Dart back half car for the local northwest no prep series races next year
Made a few changes over the winter, 3.55 to 4.10, tighter front shocks(still not tight enough), air to water intercooler(60lb on the front end). 3825 race weight
Been stuck in the 1.30s finally got it acting right with a gear change. This was 1.24 on the rear tires, and pedaled 3 times and still managed to go a 5.29. So close to 4s I can feel it. https://youtu.be/x7e-ruxqxJQ
It lifts the front tires when it runs out of extension in the rear.... If you can slow down the rear extension, or get some more travel out of the rear, it will help you keep the nose down
Car is super awesome and the more guys running Gen3 hemis, the more support we should be able to get from aftermarket industry
4200 and 8-12lb on the leave. Shifting at 7800. Centrifugal blower is probably going to differ some as far as boost launch since boost is rpm, timing control will be your friend
Re: The quest for 4’s
[Re: cuda499]
#3079215 09/21/2207:13 AM09/21/2207:13 AM
Agreed. A lot farther than I thought an oem block and some stock heads with aftermarket springs in them would go. I’d really like holley to come out with a low ram intake so I can use a shearer intercooler lid and not have a bunch of stuff sticking out the hood.
Agreed. A lot farther than I thought an oem block and some stock heads with aftermarket springs in them would go. I’d really like holley to come out with a low ram intake so I can use a shearer intercooler lid and not have a bunch of stuff sticking out the hood. Are those the engines/ heads that come in the production newer car/trucks ?
[Re: racerx]
#3079321 09/21/2202:16 PM09/21/2202:16 PM
Yes 03-08 block with 15 6.4 truck heads.
Thank you....you have a strong combo to run 137-140 @3800 lbs
[Re: racerx]
#3085895 10/14/2207:30 AM10/14/2207:30 AM
Well chipping away but still struggling with climbing the ring gear. Got rid of the steel rear bumper. Total weight with brackets was 70lb, used a 68-73 glass nova rear bumper, don’t tell anyone. Made this pass and then it rained unfortunately. Pedaled twice to keep the wheelie down but still managed a PB 60’ 330 and 1/8. Would have been a 5.0x if it would’ve stayed down. We will get it there. Also needs a touch more preload in the left caltrac bar https://youtu.be/CtMvw-D3Eoc
[Re: GY3]
#3085924 10/14/2210:06 AM10/14/2210:06 AM
I can take some more in better lighting; the first pic is it just mocked up. Had to do some trimming on it, and it could be better but it’s not a show car. I’m going to vinyl wrap them silver this winter most likely.
This car has always impressed the Hell out of me with the 140@3800lbs with basically a stock base gen 3 . Now i know that there is other gen 3 hemis out there but you or at least I don't hear much about them
I'm getting ready to narrow mine. I tried a 70-72 Duster front bumper on the rear. It's close but the 1/4 panel dimensions up/down are about 1 1/2" taller than the bumper. The Nova bumper looks like a decent fit. Doug
