The quest for 4’s
#3049432
06/10/22 03:16 PM
06/10/22 03:16 PM
Posts: 582 Dayton, OH
1980volare
My man card has just been revoked.
Dayton, OH
Made a few changes over the winter, 3.55 to 4.10, tighter front shocks(still not tight enough), air to water intercooler(60lb on the front end). 3825 race weight Been stuck in the 1.30s finally got it acting right with a gear change. This was 1.24 on the rear tires, and pedaled 3 times and still managed to go a 5.29. So close to 4s I can feel it. https://youtu.be/x7e-ruxqxJQ
Re: The quest for 4’s
[Re: 1980volare]
#3049445
06/10/22 04:07 PM
06/10/22 04:07 PM
Posts: 2,527 PA
moparacer
PA
Oh ya that's the way...60 footin with the back tires and no sissy bars......
Fix the left hand drift with some preload, tighten the front shocks up some and let it eat.
Is perfect when it smokes the fronts when it sets them down about 200 ft. out hehe.....
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3049503
06/10/22 09:16 PM
06/10/22 09:16 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Moves out for sure. Once you get it under control and if everything is good in combo/performance it'll definitely be in the 4's. Nice piece.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: 1980volare]
#3049856
06/12/22 10:05 AM
06/12/22 10:05 AM
Posts: 4,701 On the parachute mount
n20mstr
You racing no prep ? Try some radials and get on a prep surface , instant 4’s . Otherwise if you going in the 4’s with 1.20 60 foots , you making some power out the back !
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3049890
06/12/22 11:42 AM
06/12/22 11:42 AM
1980volare
Dayton, OH
You racing no prep ? Try some radials and get on a prep surface , instant 4’s . Otherwise if you going in the 4’s with 1.20 60 foots , you making some power out the back ! Radials and normal weekly test and tune prep, so it’s basically no prep.
[Re: 1980volare]
#3049901
06/12/22 12:20 PM
06/12/22 12:20 PM
n20mstr
You racing no prep ? Try some radials and get on a prep surface , instant 4’s . Otherwise if you going in the 4’s with 1.20 60 foots , you making some power out the back ! Radials and normal weekly test and tune prep, so it’s basically no prep. Radials with out decent prep , with a car like yours not going To work well . Get on a radial prep track and you will run well . Otherwise you compromise your potential.
[Re: n20mstr]
#3049904
06/12/22 12:30 PM
06/12/22 12:30 PM
n20mstr
Watching the vid , that’s a power wheelie . Get more weigh up front . Honestly it looks like it separating pretty fast . A tad tighter on the rear extension And more power early . But it will need better prep . What ECU ? A ride height sensor or Davis VPS will help a lot
[Re: n20mstr]
#3049907
06/12/22 12:35 PM
06/12/22 12:35 PM
1980volare
Dayton, OH
You racing no prep ? Try some radials and get on a prep surface , instant 4’s . Otherwise if you going in the 4’s with 1.20 60 foots , you making some power out the back ! Radials and normal weekly test and tune prep, so it’s basically no prep. Radials with out decent prep , with a car like yours not going To work well . Get on a radial prep track and you will run well . Otherwise you compromise your potential. It works pretty good just about everywhere.
[Re: 1980volare]
#3050099
06/13/22 08:59 AM
06/13/22 08:59 AM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
That thing is nasty! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: n20mstr]
#3050200
06/13/22 01:22 PM
06/13/22 01:22 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Nope I’m not ashamed. 137-140 usually. You need to 60 in the teens to go 4.90’s with that mph Agreed....We have been 4.90's but with a 1.09 60' but again its just a lowly NA smallblock on a 29.5x20.5 slick with that MPH.
[Re: Al_Alguire]
#3050283
06/13/22 06:50 PM
06/13/22 06:50 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Nope I’m not ashamed. 137-140 usually. You need to 60 in the teens to go 4.90’s with that mph Agreed....We have been 4.90's but with a 1.09 60' but again its just a lowly NA smallblock on a 29.5x20.5 slick with that MPH. Al what’s that Corvette weigh? That rig definitely gets down the track with purpose.
- A. Einstein
[Re: EvilB1Dart]
#3050315
06/13/22 09:23 PM
06/13/22 09:23 PM
Al_Alguire
Las Vegas
Just under 2800lbs usually. Depending on track we may add some weight to it to help. We cannot make NMCA or the WCNA minimum.
