Re: I’m at that age where weather dictates my racing…
[Re: dvw]
#3049074
06/09/22 09:00 AM
06/09/22 09:00 AM
Posts: 10,034 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Man, I thought 85 the last few weeks was hot. Doug back in 2002 i raced at Eddyville, Iowa 8n July. In the afternoon the temp hit 108. You desert racers may not think thats bad, BUT THE HUMIDITY WAS 90 PERCENT! To survive i had a bucket of water with a couple T shirts in it. After a run, strip down, fr3sh wet t shirt, barn fan on high,,,,, 😀
[Re: gregsdart]
#3049119
06/09/22 12:49 PM
06/09/22 12:49 PM
Posts: 1,201 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I guess years of racing motocross from March thru November got me used to being in the heat at the track. However, crappy weather forecasts are more likely to keep me from making the trip to the strip these days since I don't want to waste the time & $ to show up and get rained out (again).
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3049128
06/09/22 01:23 PM
06/09/22 01:23 PM
Posts: 19,398 Las Vegas
Al_Alguire
Las Vegas
I have lived all over the United States, from dry to humid from HOT to temperate. I have raced in all those conditions as well. When places get hot it sucks period. Sweating, well when you live here the biggest issue I see with out of towners is they don't sweat so they think they are good. They don't understand that they are on the way to heat stroke. it is so dry here that sweating isn't always that noticeable. I always tell fellow out of towners to just keep drinking water, whether you think you are thirsty or not you can thank me later.
As for the comments on it not being so bad here due to humidity..Well turn your oven on open it up and insert yourself, thats dry heat. And contrary to popular believe it does NOT cool down at night like some think in the summer. It was 99 here last night at midnight, and its spring. The sun here will flat tear you up, being at elevation only increases its affect. I grew up in southern Texas, its always hot and humid in the summer. I have raced from New England to Cali from Michigan to Alabama. When its hot it always sucks...It was plenty warm in St Louis a couple weeks ago when we were there. Temps in the mid to upper 90's with humidity to match. Hot is not fun and as we all age we get less tolerant of things we don like.
[Re: Al_Alguire]
#3049139
06/09/22 01:46 PM
06/09/22 01:46 PM
Brad_Haak
Loudoun County, VA
No argument... HOT is HOT... humidity just makes it more uncomfortable.
I had a heat-stroke moment many years ago after the 2nd moto at a July 4th weekend race in central VA... came straight off the track in a daze, dropped the bike, and crawled under my truck to get into the shade totally on "auto pilot" cuz that's how the body reacts when it starts to shut down from the heat. The only time I recall being that wiped out after a race, too, so it must have been pretty extreme conditions for me to hit the wall that hard.
Water is your friend, water is your friend, water is your friend...
[Re: Brad_Haak]
#3049167
06/09/22 04:31 PM
06/09/22 04:31 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Back when I was younger and worked in the steel mill I was accustomed to the heat. We did dust collector work while the furnaces were running and when they would blow temperature in the dust collectors often went over 200 degrees. We were dressed in our greens then put on two plastic suits with hoods to keep the contaminates out. Our rubbers gloves were wrapped with black electrical tape to again seal everything up. We wore full face respirators so we were breathing internal temperature air. Man I was in good shape back then.
[Re: Brad_Haak]
#3049168
06/09/22 04:33 PM
06/09/22 04:33 PM
Posts: 4,715 Wichita
GY3
Wichita
Water is your friend, water is your friend, water is your friend... I had a heat stroke when I was playing little league baseball and have never been the same. Gotten hot a couple of times biking and started to black out. So, of course, I choose to race in a black car with a black helmet.
[Re: Al_Alguire]
#3049264
06/09/22 11:25 PM
06/09/22 11:25 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Reminds me of Mats in 19…. They held it in May. We usually stay at the track in the trailer and it was horrid! We tried to sleep outside (sea of heat soaked asphalt) but the locust infestation was epic! Next day the motel 6 near the track had a room available. Probably the best $350 I ever spent . It’s always interesting when you drink 3 gallons of water throughout the day…. and never have to pee. One of my more “interesting” races was in august at Famoso back in 20. Mind you Bakersfield is stupid hot and certainly has humidity. It was a night race which I didn’t think much of….. until it was 8pm and we made our first test hit. Went out round 2 at 3am. Head hit the pillow at the motel at 4am. Same deal the next night except went out round 3 and cracked a beer at 4am. Head hit the pillow at 5am Sunday. We slept until 11 (check out time) and hit the road home. 72 degrees at 2am felt heaven like!
[Re: J_BODY]
#3049268
06/10/22 12:02 AM
06/10/22 12:02 AM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
I try not to race shen it's hot out. It's just not fun.
[Re: J_BODY]
#3049459
06/10/22 05:55 PM
06/10/22 05:55 PM
Al_Alguire
Las Vegas
Reminds me of Mats in 19…. They held it in May. We usually stay at the track in the trailer and it was horrid! We tried to sleep outside (sea of heat soaked asphalt) but the locust infestation was epic! Next day the motel 6 near the track had a room available. Probably the best $350 I ever spent . It’s always interesting when you drink 3 gallons of water throughout the day…. and never have to pee How could I forget sitting in a -15 suit in the lanes with no air coming in...Oh the joy...MY issue is and has been cramps for years, and if I dont stay hydrated my evenings are not fun.
[Re: Dragula]
#3051135
06/16/22 10:55 PM
06/16/22 10:55 PM
Posts: 4,590 Motor City
6PKRTSE
Motor City
I know some of you are retired, meaning your older than me, but yeah the HEAT can get to you.....I installed a thermometer in the car a couple years ago....When its +90* out, the car can be 112*F in there....I am looking for ideas to make it more livable....I have a regular RV fan that runs off the starter battery, but when I use it a lot, I have to remember to charge the car between rounds.
I saw one guy powered his fan off dewalt batteries.....I like that Idea a lot. Looking for a base I can modify to do that.
I have seen the cool shirts, but never looked into them.... I have the cool shirt set up bolted to the cage in my car. With 12' leads I can still get out of the car and work on it while still hooked up. It's good for at least 20-30 degrees cooler than outside. Works great for a cooler for ice, water, pop and beer and the cruise nights also.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: dvw]
#3051557
06/18/22 06:32 PM
06/18/22 06:32 PM
Posts: 4,701 On the parachute mount
n20mstr
I have been racing a lot at Cecil and Lebanon valley , both have pit spots in grass …… makes a big Difference in the heat . Also my trailer has some really good ac so I usually wake up at 3:00 am and literally freezing Nitrous cars run good in the heat , and it’s easy to maintain bottle temp lol
....BAD A$$ STREET CAR.....
