Re: Seeking options - lowering compression on SB 426
[Re: B3422W5]
#3048857
06/08/22 11:22 AM
06/08/22 11:22 AM
Posts: 361 mississippi
lostdog
mississippi
My dyslexia kicked in on the original post I meant it was going to be 12.4 : 1
my bad
It will ONLY see street time and honestly it probably won't get driven too much. I am not opposed to running race gas but if I can avoid it, I will
Thanks guys - all good info! I don't know what your cam is like but I would certainly be conservative on timing and try it out on pump. If it isn't driven often I am not sure I would run E85 but I have no experience with it. Cam is Howards solid roller 277/285 .600/.600 That’s a TON of duration for your compression and small heads. Way more than I would run, even in a very racy combo with those heads We're gonna give it a shot and see what happens
[Re: lostdog]
#3048864
06/08/22 11:39 AM
06/08/22 11:39 AM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
This is the grudge engine I have been trying to get built over this year and a half.
It’s Hughes’ 360 base 426 stroker kit which in my case will effectively have 14.2:1 CR. However, I now need to drop that to 10:1 or so for pump gas. Yes, I called Hughes to see what they could do about different pistons but let’s just say I want to explore other options
I have trick flow heads which are 60 cc chamber
I’m open to suggestions
Thanks ! New pistons are the only way to drop compression that much without butchering your combo and output. I would not chance having reliefs milled in the pistons that much. Buy new ones and sell the old ones to recoup some of the loss.
[Re: lostdog]
#3048906
06/08/22 01:46 PM
06/08/22 01:46 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
That engine would L O V E E-85 !!!
If that is not an option I would see if 5 CC can come out of the combustion chamber, that will get you closer to 11.5 and with that cam I bet you could run fine on quality pump premium gas.
[Re: lostdog]
#3048907
06/08/22 01:54 PM
06/08/22 01:54 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
my bad
Thanks guys - all good info! I don't know what your cam is like but I would certainly be conservative on timing and try it out on pump. If it isn't driven often I am not sure I would run E85 but I have no experience with it. Cam is Howards solid roller 277/285 .600/.600 That cam's duration @.050 is 245/253 The shelf cam is on a 108 Cl, they offer one at 112 as well. Howards cam specs
[Re: krautrock]
#3048924
06/08/22 03:23 PM
06/08/22 03:23 PM
Posts: 9,888 Weddington, N.C.
Streetwize
Weddington, N.C.
If you're really "only 12.5:1 with that cam you're going to need at least 50:50 race gas but if the car is really light and has a deep gear and a loose converter you can probably run it on the street if you put in an MSD dash mount spark retard. I wouldn't go WOT with pump 93 tho. What intake are you running? If your manifold cant outflow your heads it will kill power and may it more prone to spark-knock. A 3 1/2" is will raise the torque and HP curves, a 3" will lower the peak torque rpm and also the rate of rise of the HP trajectory
[Re: Streetwize]
#3048980
06/08/22 07:32 PM
06/08/22 07:32 PM
lostdog
mississippi
Trick flow heads and intake
[Re: Streetwize]
#3048981
06/08/22 07:32 PM
06/08/22 07:32 PM
lostdog
mississippi
I am not opposed to making fuel cocktails !
[Re: lostdog]
#3048987
06/08/22 07:55 PM
06/08/22 07:55 PM
Posts: 3,024 NY
B1duster
NY
[Re: Streetwize]
#3049020
06/08/22 09:40 PM
06/08/22 09:40 PM
lostdog
mississippi
Going in an all steel full interior ‘70 Duster with shift enhanced 727 , 3.91 gear I haven’t decided on converter yet but I think my notes say I need like 3800 stall.
[Re: lostdog]
#3049033
06/08/22 11:20 PM
06/08/22 11:20 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Going in an all steel full interior ‘70 Duster with shift enhanced 727 , 3.91 gear I haven’t decided on converter yet but I think my notes say I need like 3800 stall. I can confidently say that any serious small block is going to want way more than a 3800 flash convertor to go it’s fastest.
