Is this not the cutest little driveshaft you've ever seen? #3047150
06/01/22 04:53 PM
06/01/22 04:53 PM
Guitar Jones Offline OP
4.75" center to center of the joints.
Re: Is this not the cutest little driveshaft you've ever seen? [Re: Guitar Jones] #3047154
06/01/22 05:01 PM
06/01/22 05:01 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
That's precious! laugh
Did you have it balanced?
Facts are stubborn things.
Re: Is this not the cutest little driveshaft you've ever seen? [Re: larrymopar360] #3047157
06/01/22 05:09 PM
06/01/22 05:09 PM
I did not, the driveline shop said with a shaft that short as long as the runout is .002 or less there is no need.
Re: Is this not the cutest little driveshaft you've ever seen? [Re: Guitar Jones] #3047177
06/01/22 06:01 PM
06/01/22 06:01 PM
Kirkland, Washington
Pacnorthcuda Offline
Beats my Factory Five Cobra 8.75” driveshaft.
Re: Is this not the cutest little driveshaft you've ever seen? [Re: Pacnorthcuda] #3047182
06/01/22 06:41 PM
06/01/22 06:41 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Looks more like 5-1/5 based on that rule
Re: Is this not the cutest little driveshaft you've ever seen? [Re: cudaman1969] #3047188
06/01/22 06:58 PM
06/01/22 06:58 PM
Nope, 4.75 center to center. Looking at the open cups isn't accurate.
Re: Is this not the cutest little driveshaft you've ever seen? [Re: Guitar Jones] #3047226
06/01/22 08:51 PM
06/01/22 08:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Then the rule means nothing?
Re: Is this not the cutest little driveshaft you've ever seen? [Re: cudaman1969] #3047231
06/01/22 09:06 PM
06/01/22 09:06 PM
It was just for some perspective, sheesh.
Re: Is this not the cutest little driveshaft you've ever seen? [Re: Guitar Jones] #3047272
06/01/22 11:45 PM
06/01/22 11:45 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Is that for a drag car, 4X4 or boat?
Re: Is this not the cutest little driveshaft you've ever seen? [Re: migsBIG] #3047277
06/02/22 12:26 AM
06/02/22 12:26 AM
It gets a slip yoke on one end into an NV4500 2WD transmission and the other end attaches to the divorced NP205 transfer case. As long as it works it will save me from having to move the transfer case back which would be a lot of work and modifications. I hope I can get it in place without removing the transfer case. work
Re: Is this not the cutest little driveshaft you've ever seen? [Re: Guitar Jones] #3047294
06/02/22 07:18 AM
06/02/22 07:18 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Yanking your chain lol
Re: Is this not the cutest little driveshaft you've ever seen? [Re: cudaman1969] #3047375
06/02/22 12:54 PM
06/02/22 12:54 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
If the rule you followed brought you to this, of what use was the rule?
Re: Is this not the cutest little driveshaft you've ever seen? [Re: larrymopar360] #3047455
06/02/22 06:24 PM
06/02/22 06:24 PM
That was a great movie with a cool Ram Charger.
Re: Is this not the cutest little driveshaft you've ever seen? [Re: Guitar Jones] #3047501
06/02/22 08:40 PM
06/02/22 08:40 PM
BDW Offline
BDW  Offline
Aren't the ends on a DS supposed to be offset 90deg?
Re: Is this not the cutest little driveshaft you've ever seen? [Re: BDW] #3047509
06/02/22 09:05 PM
06/02/22 09:05 PM
Ah, no. Have you ever seen a driveshaft like that?
Re: Is this not the cutest little driveshaft you've ever seen? [Re: Guitar Jones] #3047600
06/03/22 11:53 AM
06/03/22 11:53 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pre-'74 factory 4X4 had a similar short shaft, not sure how the length compares to yours.
Re: Is this not the cutest little driveshaft you've ever seen? [Re: John_Kunkel] #3047680
06/03/22 03:41 PM
06/03/22 03:41 PM
74 was the last year for the divorced part time transfer case as far as I know. This is a 74 that had a 13" shaft with a NP 435 and NP 205 transfer case. The 2WD NV 4500 is 8" longer than the NP 435, not sure about the automatic trucks, but I know they used the short output shaft 727 with a fixed yoke.
Re: Is this not the cutest little driveshaft you've ever seen? [Re: Guitar Jones] #3047689
06/03/22 04:02 PM
06/03/22 04:02 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
The one I made for my '88 Samurai may have been a tad shorter but I didn't measure it. Just long enough to get the yokes mounted. wink 1.8 Corolla engine & 5 spd. mated to stock divorced transfer. Made a rack in the back and mounted the radiator back there. Traded it when I started having so much trouble with my knees & have regretted it ever since.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Is this not the cutest little driveshaft you've ever seen? [Re: I_bleed_MOPAR] #3047692
06/03/22 04:08 PM
06/03/22 04:08 PM
4.5" would have butted up the 1310 weld yokes. I had 5" to work with so the extra 1 /4" allowed the driveline shop to get it really straight. I did have to cut the dust boot off the rear seal though.
