Re: STREET 426 cam reccomendation [Re: A727Tflite] #3047070
06/01/22 01:22 PM
06/01/22 01:22 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Originally Posted by Transman
A real Street Hemi converter behind a stock Hemi will stall between 2800 and 3000 depending on tune.
Yep up
Loaded question: If someone wanted that today, what would be the best source?
.....Or would it be a fruitless search, and more a matter of finding a modern converter with fairly similar driving characteristics, but not necessarily the
same construction as OE (such as maybe a tight 10" or similar).
Rich H.
Esse Quam Videri
Re: STREET 426 cam reccomendation [Re: ZIPPY] #3047418
06/02/22 03:22 PM
06/02/22 03:22 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
https://www.summitracing.com/parts/bmm-10417
popcorn
i read someplace i will need crank bolts with a low profile head in order to use one of the cheaper B/RB non hemi specific converters....
https://www.summitracing.com/parts/MRG-914?rtype=10
Re: STREET 426 cam reccomendation [Re: domingo] #3047538
06/02/22 11:04 PM
06/02/22 11:04 PM
For a mild street build and use I would look for a good used 12 inch class A motor home converter up scope
Works good, last a long time as well as the fluid in it doesn't stink and looks darker than normal ATF scope up
Re: STREET 426 cam reccomendation [Re: domingo] #3047619
06/03/22 12:56 PM
06/03/22 12:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
popcorn
does your hemi have a 6 bolt or 8 bolt crank ?
Re: STREET 426 cam reccomendation [Re: JohnRR] #3047628
06/03/22 01:18 PM
06/03/22 01:18 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
popcorn
8 bolt. i would need to buy 2 sets. those are thin head bolts i think u need them to run a generic 727 converter on a 8 blt hemi crank.
i also think the lug bolts on a hemi converter are bigger? i guess i can retap the lugs on the converter to use the hemi flexplte?
hemi specific converters carry a hefty hemi pricetag. dont wanna spend 1200 bux on a converter for a street driven cruiser.
how about these 2? cause the b&M i posted earlier is rated at 350 lbs max torque i think....
https://www.summitracing.com/parts/tci-141200
https://www.summitracing.com/parts/bmm-10415
Re: STREET 426 cam reccomendation [Re: domingo] #3047637
06/03/22 01:40 PM
06/03/22 01:40 PM
All the Hemi and Max Wedge converter came with 7/16 converter to flex plate bolts, the stock 7/16 6 bolt crankshaft flex plate bolts work on those converters also up
Re: STREET 426 cam reccomendation [Re: domingo] #3047639
06/03/22 01:42 PM
06/03/22 01:42 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
turbo action 17501 11" Hemi Style has around 3000 stall.
i know these are good quality.....but 3000 is kinda higher than id like to go.
wonder where they are priced at nowadays.....they are closed i will call monday.
Re: STREET 426 cam reccomendation [Re: domingo] #3047685
06/03/22 03:55 PM
06/03/22 03:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
popcorn
instead of buying 2 sets of bolts why not just buy these ?
https://www.summitracing.com/parts/arp-200-2905/make/dodge
As far as the convertor ... considering you are outside the country and trying to find US companies to ship to you reasonably ... I'd probably get the B+M as I am not a fan of TCI.
Re: STREET 426 cam reccomendation [Re: domingo] #3047718
06/03/22 06:27 PM
06/03/22 06:27 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I have one of Turbo Action's "Hemi" converters. They can build them to be a little tighter than the 3000 rpm that is advertised. 11" cores are getting tough to find. I had to wait a few months before they were able to build me one. Well worth it.
Re: STREET 426 cam reccomendation [Re: JohnRR] #3047732
06/03/22 08:15 PM
06/03/22 08:15 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
popcorn
yes those look like they will work as well. they seem to have low prifile heads as well.
shipping is not an issue I usuallyt ship to a US address, then my freight forwarder takes care of it.
I am asking about converters because I have played very little with autos. My mopars are always 4 speeds, and whenever they have been autos they have been bone stock non performance ones like 2 barrel 318 cars.
I did buy a turbo action converter a while ago for a high horsepower application and it cost me $$$$ and it was good.
Last time I bough a converter it was a hughes 2500 stall unit for my dads el camino and it failed prematurely. argue
thats why im asking about if I should go with the B&M one above or the TCI. im clueless about the quality..... confused
Re: STREET 426 cam reccomendation [Re: 469runner] #3047733
06/03/22 08:18 PM
06/03/22 08:18 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Ill give em a call on monday.
Re: STREET 426 cam reccomendation [Re: domingo] #3047860
06/04/22 01:28 PM
06/04/22 01:28 PM
moparx Offline
moparx  Offline
i have run that B&M holeshot converter in my charger for many miles. [well, before i parked the car around 2006 or so]
i bought it in the very early 1970's, and it is a good street converter in my opinion behind a 383.
if it means anything, my charger has 3.91's for a rear gear.
beer
Re: STREET 426 cam reccomendation [Re: moparx] #3047884
06/04/22 02:53 PM
06/04/22 02:53 PM
A727Tflite Offline
A727Tflite  Offline
beer
Back in the 70’s Chrysler sold pallets full of 10-3/4” converters to B & M, painted and sold as Holeshots.
Not sure which converter they were - my guess they were the 340 model.
Re: STREET 426 cam reccomendation [Re: A727Tflite] #3048015
06/05/22 12:37 PM
06/05/22 12:37 PM
moparx Offline
moparx  Offline
i can't remember what i paid for that converter then, but maybe around $100.00 from the speed shop on main street.
used to hang out there friday and saturday nights when i wasn't working on something. it was kind of the local "watering hole" for the gear heads back then.
a more fun time in my life.
beer
Re: STREET 426 cam reccomendation [Re: moparx] #3048813
06/08/22 09:37 AM
06/08/22 09:37 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I think a real good ballpark grind would be a bullet solid F/T with about 238/238 @.050 on 110 which I think is similar to the old racer brown Street Hemi grind.
The hemi rocker ratios are really low so you need a really sharp valve job to maximize the low mid lifts and keep the cam overlap down. get it right and a hemi can be pretty snappy.
Way back in the 80's there was a nice crower Monarch(?) cam that really woke up the hemis without killing any bottom end or drivability.
WIZE
In Car:
Re: STREET 426 cam reccomendation [Re: domingo] #3049024
06/08/22 10:04 PM
06/08/22 10:04 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Hello!
all i see for sale off the shelf requires at least a 2500 or 3000 rpm tor converter
maybe even somebody might have a "wimpy" hemi cam collecting dust on a shelf??
I can't take the bait, as I had a new reproduction OE '70 hydraulic on the shelf for about 9 years, I'd put it on ebay twice in that time and nobody wanted it, didn't even have any watchers. I actually almost scrapped it at one point but didn't quite have the heart.
Ended up selling it recently on FBBO to a fellow who was tired of running a racing cam on the street.
I'd suggest maybe take a look ( in detail) as to what a stock street Hemi vehicle (the transmission) had, to support the engine.
Ex: A completely stock 10&3/4 high stall street hemi converter fell exactly into the 2500+ range mentioned.
The old Direct Connection chassis manual has some of that information.
(You weren't intending to use a 12" low stall converter from a C body in that car, were you?)
Other than that, here are some puppy cams that might be of interest.
https://www.crower.com/camshafts/mopar-426-hemi-66-71-compu-pro-hydraulic-cam-294-hdp.html
https://www.compcams.com/street-and-strip-227-227-hydraulic-flat-cam-for-chrysler-426-hemi.html
For a few dollars more, can always call rbre and order a 'street cruiser' mystery cam with no specifications, for
more of an old-timey experience of not really having a clue what cam you have, which some may prefer.
https://www.raybarton.com/products/rbre-chrysler-genii-hemi-camshafts
i remember reading someplace stock hemi converters had around a 1800 stall.
not sure about that though.
i am just about trying to decide which cam and converter to go with.
thanks for the links will give em a look.
and yes, i was about to call bullet on the cam. i got a "pure stock" hemi cam from them a while ago.
My stock 68 vert behind a 383 would go almost 3000, still got it too.
