Re: B&M cast aluminum tranny pan/bolts? [Re: A727Tflite] #3046221
05/29/22 06:05 PM
05/29/22 06:05 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Originally Posted by Transman
Originally Posted by racerx
Thanks Trans... up
Looks like it is 2464324AC. Verify with dealer to be sure.
upWilco.
Re: B&M cast aluminum tranny pan/bolts? [Re: racerx] #3046303
05/29/22 11:21 PM
05/29/22 11:21 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Anyone uses the blue lock tight on them?. Semes like i cant keep them tight runaway
I think you might have some kind of harmonics going on which is loosening your hardware. anything else need tightening up?
Re: B&M cast aluminum tranny pan/bolts? [Re: racerx] #3046335
05/30/22 01:30 AM
05/30/22 01:30 AM
Cab_Burge Online work
Cab_Burge  Online Work
Try using some adhesive sealant silicone instead scope up
Re: B&M cast aluminum tranny pan/bolts? [Re: Cab_Burge] #3046360
05/30/22 08:30 AM
05/30/22 08:30 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Try Permatex "High Tack" Gasket sealant, #80062 as a brush-on or in a spray can too.
My go-to for any oil/fuel sealing, gasket or not.
It is also an effective medium thread lock, although not advertised as such.
Give it a try, nothing to lose but aggravation.... my 2 cents,
Joe
Re: B&M cast aluminum tranny pan/bolts? [Re: rebel] #3046366
05/30/22 08:59 AM
05/30/22 08:59 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
No sir,,,,,just the pan bolts.......I', thinking of just trying some lock washers first work
Re: B&M cast aluminum tranny pan/bolts? [Re: racerx] #3046399
05/30/22 11:17 AM
05/30/22 11:17 AM
A727Tflite Offline
A727Tflite  Offline
Unless you have bolts loosening up on gaskets with torque limiters I would just use the Mopar gasket and torque those bolts.
The reuseable gasket was designed to be used in production with longer bolts with captive washers.
They are slightly longer than the std. pan bolts.
They are a gray finish compared to the std 727 bolts. Longer because the gasket is thicker overall and to maintain proper thread engagement.
