Re: Engine masters max wedge episode [Re: Cab_Burge] #3045984
05/28/22 07:22 PM
05/28/22 07:22 PM
Texas
Chief Offline
Chief  Offline
Texas
I had a 470 CI with 440-1's never got it on the dyno. But best car ran was 8.60 at 160 mph.
I did get my 500 CI, 440-1 with 871 blower on the dyno. 1300 HP 1050 TQ at 6800 12 lbs boost.
Dave Covey
Re: Engine masters max wedge episode [Re: AndyF] #3045985
05/28/22 07:24 PM
05/28/22 07:24 PM
Texas
Chief Offline
Chief  Offline
Texas
Originally Posted by AndyF
Originally Posted by Chief
Nice article Andy. Did you ever get to test after the intake was worked over?
Yes, the ported intake picked up 25 hp over the cast intake. I think the best we ever made with that 470 was 780 hp. That was a pump gas engine so we had to be super careful with the camshaft selection. Higher compression would've allowed us to make more power. I think we could've gone over 800 hp if we had put a little more compression in the engine. I've done quite a few 270 head engine since then but none have made that much power. Most engines we do are for street guy or bracket guys and neither of them want to break the bank to pick up the last 50 hp in a build.
https://www.motortrend.com/how-to/dyno-tested-vacuum-pump-help-engine-make-power/
Nice power out of the small cube.. up
Dave Covey
Re: Engine masters max wedge episode [Re: Chief] #3045987
05/28/22 07:29 PM
05/28/22 07:29 PM
AndyF Offline
AndyF  Offline
Thanks. It cost a lot of money and made a lot of power. The average BB Mopar that we see on the dyno make around 600 hp with TF240 heads and 700 hp with the larger TF270 heads. There isn't 100 hp difference between the heads, the guys with the 270 head typically run higher compression and big solid rollers., The 240 guys tend to run pump gas and hyd roller cams. Over the last several years it seems like there is always at least one BB Mopar with TF heads on the build board. Sometimes there are two or three of them stacked up in the queue. Very popular combination.
Re: Engine masters max wedge episode [Re: AndyF] #3046026
05/28/22 10:46 PM
05/28/22 10:46 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
A friend finished a short deck BB with the Trickflow 270 heads for a customer earlier in the year. It was a twin turbo deal, no idea on the power, but I don't think it was a big boost thing.
I had to machine the heads for Jesel rockers, they were nice looking heads, a lot better than the Edelbrock stuff I'd seen.
Alan Jones
Re: Engine masters max wedge episode [Re: LA360] #3046028
05/28/22 11:01 PM
05/28/22 11:01 PM
LA360 Offline
LA360  Offline
Complete Engine
Alan Jones
Re: Engine masters max wedge episode [Re: LA360] #3048941
06/08/22 04:20 PM
06/08/22 04:20 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
How do they pick up 35 HP with only 10ish CFM unless the standard port is choking it? work
Re: Engine masters max wedge episode [Re: GTX MATT] #3048953
06/08/22 04:59 PM
06/08/22 04:59 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I read this when it first came out and this is very similar to the 517 I first built about 15 years ago using the Chapman Stage VI 285 cnc heads and also after a few great long phone conversations with Mr Dulcich. I first spoke back when Moparts was collaborating on the Engine Masters that DRAM machined for us.
My motor is 11.2:1 4.375 x 4.300 in a 400 low deck and also has a 264/268 Bullet Hydraulic roller and I run a Larry Smith deep ported MP '337 for hood clearance. It's a fantastic combination and I'm sure the design of the TF270's were probably based on the Chapmans in some way or form.
335 CFM by only .400 lift is going to make big power in a BB Wedge, let alone 360+ @.600. Wish I had that dry sump, that's probably 35-40 hp and a broader torque curve.
WIZE
In Car:
Re: Engine masters max wedge episode [Re: JERICOGTX] #3049172
06/09/22 05:05 PM
06/09/22 05:05 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Originally Posted by JERICOGTX
Originally Posted by Uberpube
Trick flow 270's, Max wedge.
The 270’s were worth 45hp over the 240’s. Other than the intake being slightly different, the engine was the exact same. If you have hood clearance, the 270’s are a no brainer.
On top of that they stated "each head step was a 20 hp gain over the previous one" meaning from a 906 to the TF 270's there is about 105HP difference.
eBay-cdwmotorsports
Re: Engine masters max wedge episode [Re: cdwmotorsports] #3049200
06/09/22 07:08 PM
06/09/22 07:08 PM
AndyF Offline
AndyF  Offline
I recommend the TF240 heads for a 600 hp combo. If a customer wants to make 700 hp then I recommend the TF270 heads. If the customer wants more than 700 hp then the recommendation switches to an Indy head.
