Re: B&M cast aluminum tranny pan/bolts?
[Re: racerx]
#3046399
05/30/22 11:17 AM
05/30/22 11:17 AM
Posts: 3,093 Michigan
A727Tflite
Anyone uses the blue lock tight on them?. Semes like i cant keep them tight I think you might have some kind of harmonics going on which is loosening your hardware. anything else need tightening up? No sir,,,,,just the pan bolts.......I', thinking of just trying some lock washers first Unless you have bolts loosening up on gaskets with torque limiters I would just use the Mopar gasket and torque those bolts. The reuseable gasket was designed to be used in production with longer bolts with captive washers. They are slightly longer than the std. pan bolts. They are a gray finish compared to the std 727 bolts. Longer because the gasket is thicker overall and to maintain proper thread engagement.
