340 Exhaust Manifold Gasket / Heat Shield #3044258
05/22/22 10:49 AM
05/22/22 10:49 AM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
Has anybody heard any rumblings about these being reproduced "again" ??? Thanks , Kevin
Re: 340 Exhaust Manifold Gasket / Heat Shield [Re: B5TA] #3044296
05/22/22 12:39 PM
05/22/22 12:39 PM
moparx Online content
moparx  Online Content
i can't help ya, but here is a bump in the hopes some one else sees this that knows for sure.
beer
Re: 340 Exhaust Manifold Gasket / Heat Shield [Re: B5TA] #3044336
05/22/22 03:03 PM
05/22/22 03:03 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
These should be SO easy to reproduce! They are thin & not too deeply contoured.
Monicatti is showing they have it: https://www.monicattichrysler.com/comersus/store/comersus_viewItem.asp?idProduct=3323#
(these were only used on the driver's side - correct?)
Re: 340 Exhaust Manifold Gasket / Heat Shield [Re: Sunroofcuda] #3044420
05/22/22 07:51 PM
05/22/22 07:51 PM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
No longer available, ordered 1 from them and got a" Dear John" response. Thanks, Kevin
Re: 340 Exhaust Manifold Gasket / Heat Shield [Re: B5TA] #3044430
05/22/22 08:21 PM
05/22/22 08:21 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Havent been avail for quite a while
Last.time i talked to the manufacturer.
He had no intention to make another run.
And that was over 5 years ago....mqybe closer to 10
But yes. Drivers side only
Re: 340 Exhaust Manifold Gasket / Heat Shield [Re: gtx6970] #3044621
05/23/22 02:15 PM
05/23/22 02:15 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I have a brand new OE gasket that you're looking for... still in the box.... Originally made by McCord. PM me if you are interested.
Re: 340 Exhaust Manifold Gasket / Heat Shield [Re: Sunroofcuda] #3044743
05/23/22 11:25 PM
05/23/22 11:25 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Pretty sure the heat shields were made of double-reduced, soft temper, 0.015" tin mill black, "black" meaning un-plated cold rolled steel sheet in coil. 0.015" is too thin for a cold rolled mill, so it's made on a tin mill.
0.015" is so much reduction that work hardening comes into play, and it has to be double-reduced or rolled/annealed, then rolled/annealed again.
Each finished piece weighs about 4 ounces. A minimum material purchase will be a 5- or 10-ton coil, which would make at least 30,000 heat shields if you figure 3 per pound, counting scrap. There's probably no other use for that material.
Only one thing to do: Take a chance to make a profit by selling a few hundred (?) finished pieces for $100+ each and throw a bunch of material away.
Or don't buy any material, don't make any.
Re: 340 Exhaust Manifold Gasket / Heat Shield [Re: Sunroofcuda] #3045188
05/25/22 06:15 PM
05/25/22 06:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'll bet tooling still exists if you want to buy it for yourself and give it a go
Ask for Tom
https://feedback.ebay.com/fdbk/feedback_profile/lb_enterprises
Re: 340 Exhaust Manifold Gasket / Heat Shield [Re: gtx6970] #3045237
05/25/22 09:31 PM
05/25/22 09:31 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Ask for Tom
Still kicking this around & thanks for the info. I already know one Detroit area shop that can do all of it, & a buddy who can also facilitate getting these done with his sources. I've got to dig out my NOS one so we have something to look at. I think there would be pretty decent volume with these.
