I'm about to start the build. Was going big hemi but cars not capable.
Have a 6.1 have a P1sc Procharger have a 68 Road Runner. Have a Big Block 727 with a break.
Looking at Cams right now. Will be a drag car you can street. Heads are stock. Taking to machine shop Fri need ideas on what I should do to them. I know springs and freshen VJ but do you have to mill the guides and sh!t like the old stock stuff. Wanting something fast. The car is a drag car. Light and big tar
Block will go in when heads are done so that's a later post
Curious what your intended boost levels are with the P1?
I am bolting on a P1SC to a 5.7 with forged bottom end and head work and cam. Hoping to make 650-700hp at the crank at the least, and I would like atleast 10psi on pump gas, and anything more I may be able to squeeze out of the blower.
