Re: Fusible Link
[Re: Snoopy]
#304479
05/01/09 06:44 PM
05/01/09 06:44 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Snoopy's turn please. Its all good ![](/ubbthreads/images/graemlins/thumbs.gif)
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
Re: Fusible Link
[Re: 440_ci]
#304480
05/01/09 06:50 PM
05/01/09 06:50 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Not nec, could require the total load, maybe, notice that the wire is discounected to the alternator when you remove the second plug. So it is possible it is alternator. Reconnect everything but remove the connection to the alternator. After you figure everything put a new end onto the fusible link. it will hold better with the correct terminal.
Re: Fusible Link
[Re: Snoopy]
#304481
05/01/09 10:32 PM
05/01/09 10:32 PM
RapidRobert
you might grab an inline fuse holder at your parts house for a buck or 2 ,the kind w a pigtail on each end & add 2 alligator clips a large one & a small one & disconnect either batt cable at the battery & put this in series with a 20 or 30 amp glass fuse to protect your baby until you get this sorted out & it might take a 5 pack(or more) but smoking wires is a no no. A circuit breaker would be even better(dont know which type).
Re: Fusible Link
[Re: HealthServices]
#304482
05/03/09 11:31 AM
05/03/09 11:31 AM
Posts: 230 Babylon,NY
440_ci
Babylon,NY
Hey guys well i took your advice and checked the alternator before doing anything else and it turns out that the fuel line was actually touching the main bolt on alternator and causing it to short out ![](/ubbthreads/images/graemlins/crazy.gif) so i bent it back a little and she works fine. But now i am not getting any spark ![](/ubbthreads/images/graemlins/maad.gif) . I checked the volts to the + side of the coil and its a steady 6.2 but i read it should have 8 ? When this shorted out could it have damaged the coil or ecu? (btw i did the coil spark test and i am not seeing the spark jump across the gap like it should and the ballast has already been replaced)
Re: Fusible Link
[Re: 440_ci]
#304487
05/05/09 09:13 PM
05/05/09 09:13 PM
RapidRobert
take the coil negative primary wire off the coil terminal & set it aside(dont let it touch anything). key on, eng off. With a jumper w 2 alligator clips jump from this(coil pri) terminal to ground like morse code & see if you have spark from the coil secondary wire held 1/4" from ground. that's the coil check.In this case not likely dist pickup but if you have a spare dist plug it in(key on,eng off) & spin it by hand & see if you have sparks. this checks the dist pickup. the ECU, you can have your parts house check it but it really needs to be hot for a valid test so If you have another you could sub it in the check the ECU.
Re: Fusible Link
[Re: 440_ci]
#304490
05/07/09 10:44 PM
05/07/09 10:44 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
did you make it with key in RUN ? Ballast good ? Is ECU getting 12 volts at blue traced yellow wire ?
Re: Fusible Link
[Re: 440_ci]
#304492
05/08/09 09:09 AM
05/08/09 09:09 AM
RapidRobert
On the ECU conector the "point" of the pentastar is the 12V feed. On the coil jump 12V to the positive pri terminal(from the batt) & jump the neg pri terminal to ground repeatedly as previously described & see if the coil wire(1/4" from ground sparks). Only have full 12V jumped to it(the coil positive pri) just long enough to do this test(a few seconds).
Re: Fusible Link
[Re: 440_ci]
#304494
05/08/09 03:33 PM
05/08/09 03:33 PM
RapidRobert
If you disconnected the orig coil neg pri wire for the test before you added the jumper then yes the coil is deceased. the ECU is supposed to default the above circuit in the "open" position but we cannot assume anything.
Re: Fusible Link
[Re: 440_ci]
#304495
05/08/09 03:58 PM
05/08/09 03:58 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Corey- I'm not ignoring you. I want you to listen to one person at a time. Hopefully by doing this it will not confuse you anymore than you are.
Allen
