Re: Can't get it to idle. [Re: DrCharles] #3043918
05/20/22 02:13 PM
05/20/22 02:13 PM
Red Deer, Alberta
Greenwood Online content OP
Greenwood  Online Content OP
Red Deer, Alberta
Originally Posted by DrCharles
Originally Posted by justinp61
Many carb problems have been fixed by correcting the timing.
"90% of carburetor problems are in the ignition" - Smokey Yunick up
I like that one. smile
The distributor is an MSD unit. MSD 6AL ignition.
Re: Can't get it to idle. [Re: Greenwood] #3043936
05/20/22 02:58 PM
05/20/22 02:58 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
you can buy bushings and springs for that distributor. not a difficult modification. or, a start/retard; they work.
Re: Can't get it to idle. [Re: lewtot184] #3043957
05/20/22 04:10 PM
05/20/22 04:10 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Years ago, had a slant six at work that gave me lots of grief. Turned out to be a clogged air breather on the valve cover that was forcing fumes into the intake manifold. Simple fix was a vented breather instead of a solid oil fill cap. Wasn't ignition that time, but points and timing is normally the first place I used to look. Malfunctioning fuel vapor canisters run a close second when I would inherit a problem child that others couldn't fix.
