Re: Can't get it to idle. [Re: DrCharles] #3043918
05/20/22 02:13 PM
05/20/22 02:13 PM
Red Deer, Alberta
Greenwood Offline OP
Red Deer, Alberta
Originally Posted by DrCharles
Originally Posted by justinp61
Many carb problems have been fixed by correcting the timing.
"90% of carburetor problems are in the ignition" - Smokey Yunick up
I like that one. smile
The distributor is an MSD unit. MSD 6AL ignition.
Re: Can't get it to idle. [Re: Greenwood] #3043936
05/20/22 02:58 PM
05/20/22 02:58 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
you can buy bushings and springs for that distributor. not a difficult modification. or, a start/retard; they work.
Re: Can't get it to idle. [Re: lewtot184] #3043957
05/20/22 04:10 PM
05/20/22 04:10 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Years ago, had a slant six at work that gave me lots of grief. Turned out to be a clogged air breather on the valve cover that was forcing fumes into the intake manifold. Simple fix was a vented breather instead of a solid oil fill cap. Wasn't ignition that time, but points and timing is normally the first place I used to look. Malfunctioning fuel vapor canisters run a close second when I would inherit a problem child that others couldn't fix.
