SDC BCR main girdle set screw replacement?
#3039725
05/04/22 04:13 PM
05/04/22 04:13 PM
Posts: 294 Minnesota
RockChip
Minnesota
This is my 8th engine in with this particular girdle assembly and issue.
The 3/8-16 set screws that hold the girdle to the aluminum caps are almost always cracked mid way though the cap... major pain to remove the remaining set screw from aluminum cap I might add.
Anyway, I've been replacing all the set screws with ARP bolts on engines that come in for freshen and tossing the set screws that come with the kit in the miscellaneous bolt pail on a new build and was just curious what everyone else has been using? Bolts/studs?
This was a freshen up on a 11:5.1 499 RB bracket engine running on 112 so nothing crazy, maybe 100 passes in 10 years.
Re: SDC BRC main girdle set screw replacement?
[Re: GTXMEX]
#3115575
01/23/23 03:31 AM
01/23/23 03:31 AM
Posts: 43,272 Bend,OR USA
Cab_Burge
Are you sure you want to install a hunk of steel that has no precision interference fitting on any of the fasteners? I don't
[Re: Jerry]
#3115967
01/24/23 11:22 AM
01/24/23 11:22 AM
Posts: 4,080 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
...not much thermal expansion in the 220 deg F range. these arent cylinder heads which see combustion temperatures.
Thanks for the reply! Respectfully, even at 220*f or so! (the surfaces are closer to the fluid temperature than each parts core) what would be the amount of expansion over the span of the length of the girdle in the fore and aft plains? but let's just use from room air temp to 220F
