1320 Challenger ets?
#3039302
05/03/22 10:05 AM
05/03/22 10:05 AM
Posts: 1,705 Nebraska
70VcodeCoronetRT
Nebraska
Looking at picking up a Challenger 1320. What kind of times are you running stock? Do they really run 11.7s stock? And what are some of the best mods? Are you happy with your 1320. And any info you would share to a person about to order one? Thanks
Re: 1320 Challenger ets?
[Re: 70VcodeCoronetRT]
#3039382
05/03/22 01:30 PM
05/03/22 01:30 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Go to the race section and look at Brad_Haack. He has a new 1320 he has been racing on the regular.
From what I have seen here locally in decent air they go 11.80s or so.
68 Barracuda Formula S 340
#3039419
05/03/22 03:35 PM
05/03/22 03:35 PM
Posts: 1,135 Loudoun County, VA
Brad_Haak
Loudoun County, VA
In good air, with the standard clothe interior w/o passenger seat or rear seat, I'd expect I could see 11.7s in good air where I am (Mid-Atlantic). Bone stock, with the full leather interior upgrade and my 200 lbs in it, my car's squeaked into the 11.8s on one pass and 11.9s on a couple early in the year. Basically, it's a 12.0 car with potential to go a bit quicker or a bit slower depending on the weather / track location / etc.
The only mods I've done are a drop-in K&N filter (which I haven't proved to be an improvement or not) and I picked up some discontinued Race Star Recluse wheels so I can run Mickey Thompson ET Street Front 28-6.00x18 and ET Street S/S 305/40R18 tires the days I drive to the track. The standard Nexen 275/40R20 drag radials worked OK when new and on a well-prepped track. However, they'll get sketchy well before the tread's worn out and any short-sidewall tire is going to have trouble hooking consistently on less-than-perfect starting lines.
The car isn't necessarily faster w/ the MT tires & wheels combo, but it's much more predictable getting off the line. The OEM Nexens would either stick, or they'd hop & spin. My last track day was Saturday and the purpose was to see where I need to set the rear tire pressure w/ the MTs to get a more consistent 60-ft. The lighter front tires & wheels may add a touch of MPH, but the rear tire & wheel setup is also heavier than stock. I'm running less air pressure in the rears now, which may scrub off some MPH. However, if the car won't hook consistently, it doesn't matter to me if it's faster on the passes that it does hook.
I don't know of any cheap "bolt-on" mods for these cars to increase engine performance. And that's not really my intent, either. This is my daily driver that allows me to go have fun at the track while I'm still trying to pull a miracle outta my a$$ and get my '73 Challenger back to the track. Here's a snapshot of all my full 1/4 mile passes, meaning it doesn't include any pass where it simply blew off the tires or the 1/8th mile bracket event I raced a couple weeks ago.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
#3039439
05/03/22 05:33 PM
05/03/22 05:33 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
To run 11.70 with the advertised curb weight of 4150 would take 512 HP according to walleracing HP calculator and that don't include a driver or any optional stuff. If you can still run 11.7 with 200 LBS of driver that takes 536 HP, pretty impressive for a "485" HP engine I would say!
[Re: HotRodDave]
#3039551
05/04/22 12:19 AM
05/04/22 12:19 AM
Brad_Haak
Loudoun County, VA
Horsepower calculations based on ET never made sense to me. You can improve ET with changes that have nothing to do with HP or weight. The calculations based on weight and MPH are a better approach to estimating horsepower.
I scaled my 1320 with the aftermarket wheels & tires and fuel level well under 1/4 full: the car by itself was 4097. With me and and some extra fuel, it's definitely 4300+. HP calc'd for 4300 lbs at 113 MPH is right about 485, which is the factory rated net HP. That's very close to my baseline for "at sea level" corrected MPH with ETs in the 12.0 range.
#3039638
05/04/22 10:57 AM
05/04/22 10:57 AM
Brad_Haak
Loudoun County, VA
I should also mention that I really like this car. . Pics shortly after purchase and from a recent day at the track w/ the other wheels & tires.
[Re: Brad_Haak]
#3039666
05/04/22 12:40 PM
05/04/22 12:40 PM
HotRodDave
Kalispell Mt.
I don't know of any cheap "bolt-on" mods for these cars to increase engine performance. And that's not really my intent, either. This is my daily driver that allows me to go have fun at the track while I'm still trying to pull a miracle outta my a$$ and get my '73 Challenger back to the track. Here's a snapshot of all my full 1/4 mile passes, meaning it doesn't include any pass where it simply blew off the tires or the 1/8th mile bracket event I raced a couple weeks ago. What am I missing on the 11.8@115.6MPH run? Was it also around 4300 LBS? Is it wrong to pick the best run? Even plugging the 115.6 MPH and 4300 LBS into wallerracing calculator is still over 510HP. I don't see a drop in K&N giving you 25 HP and it is my understanding the calculator is based on wheel HP not flywheel HP. All I'm saying is that in my opinion the 6.4 is very underrated not just in stock form but how easy it is to get more HP when truly un-corked with things like good long tube headers and a better intake and proper tuning that's not compromised for warranty, MPG and emissions considerations.
[Re: HotRodDave]
#3039722
05/04/22 03:53 PM
05/04/22 03:53 PM
Brad_Haak
Loudoun County, VA
Best "raw data" run bone stock was 11.89 at 113.75 w/ 3/4 tank of fuel. Corrected to sea level that's a 11.94 at 113.41. To be honest, that's something of a "unicorn" run for this car.
Best run to date is w/ K&N drop-in, aftermarket wheels & tires, and about 1/4 fuel level was 11.83 at 115.80, which is 11.87 at 115.6 corrected to sea level. That's by far the quickest & fastest pass to date.
The front wheel assemblies are definitely lighter and reduce rolling resistance; the rear wheel assemblies are heavier than OEM, but the car can hook up more consistently at lower tire pressures. Something in that combination of filter + wheels & tires helps it pull a little more MPH, but it doesn't always show up every run.
Look at the last three runs at Capitol on 3.25, which is the last event I ran "bone stock" w/ OEM Nexen drag radials... the corrected numbers are: 12.08 @ 113.30 12.15 @ 112.73 12.07 @ 112.90
Look at the last four runs from Mason-Dixon on 4.30, which was the aftermarket tire & wheels + K&N filter, where the corrected numbers are: 11.94 @ 113.53 11.99 @ 113.35 11.97 @ 113.50 11.99 @ 114.41
Only the first pass was actually in the 11s that day, and it clicked off consistent 12.0s the other three. FWIW, the fuel level was 3/4+ that day, which is about a half tank more than I run usually on track days.
When you take the differences in track conditions out and standardize them to the same atmospheric baseline, there's maybe a tenth and 1 MPH found w/ the tires & wheels and filter. But you don't see any "unicorn" runs here cuz the good air is taken out of the equation.
Can my full-interior 1320 run 11.8s "bone stock"? Yeah, but it's not a guaranteed thing. I'm still of the opinion -- based strongly on my own data which I don't make any effort to hide -- than a stock "full weight" 1320 is basically a 12.0 car. Pull my front passenger and rear seats and there's maybe 120 to 130 less lbs to haul around, so possibly 11.8s at 114+ w/ me under more typical conditions. Throw my son behind the wheel who weighs 70 lbs less than I do and maybe it's a 11.7 "stock" car w/o needing killer air.
However, having the best ET with this car doesn't matter much to me. Some 1320s seem to go faster, others are comparable to mine. I like the car and it's cool that I can take it to the track, as well as use it as my daily car.
[Re: DoubleD]
#3039986
05/05/22 02:50 PM
05/05/22 02:50 PM
Posts: 1,552 Michigan
Kiddart
for what its worth. I have a 2020 1320. on a nice Saturday evening last summer i was out making a few hot laps on the main road by my house. with the data log going and the HP graph displayed on the dash i saw as High as 525hp on the graph with it holding thru 4th gear. the cars are very underrated. still super fun to drive, on the street or track.
i am still learning this data log thing with its computer, super cool car is worth every penny. in my opinion
Thank you Kiddart
[Re: Wailin D]
#3040654
05/07/22 06:43 PM
05/07/22 06:43 PM
HotRodDave
Kalispell Mt.
That one guy claims 3960LBS and ran 120 MPH with drag radials, comes out to 527 HP while an 11.20 at that weight comes to over 550 HP.
[Re: cudaman1969]
#3040787
05/08/22 03:31 PM
05/08/22 03:31 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
Any car with the 392 will be the street-race car from now on. My 15 SRT amazes me every time I drive it (23,000 miles) 24-5 mpg at 70. Rear tires are the only thing holding these engines back (I think mine were made with grease) lol Thats why put these on
[Re: CSK]
#3040889
05/09/22 02:23 AM
05/09/22 02:23 AM
Posts: 10,139 A Red State
SNK-EYZ
A Red State
Any car with the 392 will be the street-race car from now on. My 15 SRT amazes me every time I drive it (23,000 miles) 24-5 mpg at 70. Rear tires are the only thing holding these engines back (I think mine were made with grease) lol Thats why put these on Specs on your rear wheel and tire combo???? Brand and backspacing on the wheels especially.
