Page 2 of 3 1 2 3
Re: Rocker arm issues. [Re: blue_stocker] #3038269
04/29/22 02:57 PM
04/29/22 02:57 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
because the tip of the rocker arm moves on an arc.
Re: Rocker arm issues. [Re: blue_stocker] #3038270
04/29/22 02:58 PM
04/29/22 02:58 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Brad Haak had some really good examples, actual measurements, and CAD drawings in a detailed post about that very thing.
If you search through his posts you should be able to find it.
Re: Rocker arm issues. [Re: JohnRR] #3038272
04/29/22 03:13 PM
04/29/22 03:13 PM
AndyF Offline
AndyF  Offline
Originally Posted by JohnRR
Originally Posted by AndyF
Yeah there were all these arguments on the forums years ago so I went and bought one rocker from each mfg and put them all on a shaft. Once I did that I said "okay, now I get it"!
The Mopar rocker arms are all over the map. You don't know what works until you try it. Eventually I created a little cheat sheet that told me which rocker arms worked with which cylinder heads. If a person just randomly selects a rocker arm package then good luck and may the force be with you. Not everything works on everything.
Have you shared this cheatsheet ? whistling
I wrote a couple of books
Re: Rocker arm issues. [Re: AndyF] #3038276
04/29/22 03:30 PM
04/29/22 03:30 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Years ago Racer Brown recommended going through a set of stock rockers and selecting those that had equivalent lifts. I have done this multiple times and yes, the ratio of a stock Mopar rocker is all over the map.
Re: Rocker arm issues. [Re: 6PakBee] #3038281
04/29/22 03:45 PM
04/29/22 03:45 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
not to hijack here, but i've got a set of crane golds on my go to driver and was thinking about changing them out; over 20,000 miles on them. i thought i might have a geometry issue with new stuff seeing how i can't buy old stuff but that pic dwayne put up,.... confused. i thought things might be goofy but that's beyond goofy for me. i don't use a fast rate cam or big pressures but it looks like it's all head specific. i would have thought there might be some overlap as far as usage goes but maybe not. the deal with those prw rockers seems outrageous. were they the comp cams clones or the alum?
Re: Rocker arm issues. [Re: Stanton] #3038301
04/29/22 05:07 PM
04/29/22 05:07 PM
Red Deer, Alberta
Greenwood Offline OP
Red Deer, Alberta
I checked the actual lobe back when I got the cam. I also have, in the past, checked the actual valve lift at zero lash. The Crane's were giving me pretty much the real deal. I think it was out by .005" from the theoretical .613", which can be attributed to arc and some deflection. I had killer valve springs.
Re: Rocker arm issues. [Re: Greenwood] #3038305
04/29/22 05:40 PM
04/29/22 05:40 PM
Out of the State of Confusion
blue_stocker Offline
Thanks Dwayne, I'll look into it...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Rocker arm issues. [Re: Greenwood] #3038344
04/29/22 06:54 PM
04/29/22 06:54 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
I'm at .513" net valve lift on a .575" roller, at .020" lash. With 1.6 rockers.
The rockers aren’t marked for ratio, correct?
My guess is....... they’re 1.5’s in a 1.6 box.
.575 lift with a 1.5 is .383 lobe lift.
You getting .513 with .020 lash, which would put the number at .533 gross lift.
533/383 = 1.39.
I find it hard to believe they’d be that far off(1.6 > 1.39).
1.5 > 1.39 would be bad enough.
Re: Rocker arm issues. [Re: fast68plymouth] #3038401
04/30/22 12:07 AM
04/30/22 12:07 AM
Red Deer, Alberta
Red Deer, Alberta
Originally Posted by fast68plymouth
Quote
533/383 = 1.39.
The rockers themselves are marked 1.6..
Re: Rocker arm issues. [Re: Greenwood] #3038416
04/30/22 07:33 AM
04/30/22 07:33 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Pictures !!! Top and side.
Re: Rocker arm issues. [Re: Greenwood] #3038448
04/30/22 10:03 AM
04/30/22 10:03 AM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
Interesting. The ones that were on a motor that was just on the dyno here had no markings.
The two that were checked measured in the 1.45 range.
This isn’t doing much to make me change my mind about not using Chinese rockers.
Re: Rocker arm issues. [Re: fast68plymouth] #3038530
04/30/22 02:57 PM
04/30/22 02:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
Quote
I've measure a bunch of different brand BB Mopar adjustable rocker arms, stock Ductile iron Max Wedges, stock Street Hemi ductile iron rockers from many different motors, Isky, Cranes and Erson brand ductile iron rocker arms as well as several different brands of aluminum rocker arms like Harland sharp, both early and later made, and several sets of T&D single shaft sets, none of them were dead nuts on the ratio on the complete sets sent to me from the factories whiney work
I use to send the ductile iron sets to a company in northern, CA for blue printing and making them accurate, after checking several different sets I had done by them I stopped doing that down
i have not yet check a complete set of Jesel paired shaft aluminum or steel rocker arms, that is next wrench work
Re: Rocker arm issues. [Re: fast68plymouth] #3038673
05/01/22 01:32 AM
05/01/22 01:32 AM
Red Deer, Alberta
Red Deer, Alberta
Quote
Fair point. I'll probably find out on Monday what the manufacturer has to say.
Re: Rocker arm issues. [Re: Greenwood] #3038700
05/01/22 07:46 AM
05/01/22 07:46 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Quote
How many of the eight common dialects spoken in China do you know?
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Rocker arm issues. [Re: Brad_Haak] #3038718
05/01/22 09:16 AM
05/01/22 09:16 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think one thing many take for granted is that the rocker ratio will yield the equivalent ratio of valve lift with every cam. However, the rocker ratio is exactly that - its the ratio of the distance from the center of the shaft to the center of the pushrod versus the distance from the shaft to the center of the valve contact point. Given the stock geometry of the shaft position, valve height and rocker design, a stockish .300 cam will yield .40 valve lift because its all designed to. But if you throw in a .400 lift cam with no changes to the shaft or valve length, you should not expect .600 lift. There are a few other factors that will affect the valve lift when you slap in a cam with double the stock lift. Without changing the shaft height or valve length, the rocker will be at a much great angle half way though the lift with the bigger cam. This results in a much lower lift ratio in the second half of the valve lift. It works similar to a piston - the fastest travel is is halfway in the bore but at the top or bottom its moving slower because of the crank angle.
Re: Rocker arm issues. [Re: Stanton] #3038743
05/01/22 10:33 AM
05/01/22 10:33 AM
So. Burlington, Vt.
So. Burlington, Vt.
That’s all fine and dandy, but it sounds like the Crane 1.6’s yielded .080” more valve lift than the PRW’s with the same cam(lobe lift).
I know which scenario I’d rather have in my engine.
Re: Rocker arm issues. [Re: fast68plymouth] #3038759
05/01/22 11:30 AM
05/01/22 11:30 AM
AndyF Offline
AndyF  Offline
My guess is that someone at the PRW factory stamped a set of 1.50 rockers with the 1.60 ID and then they got boxed and sold as 1.60 rockers. PRW gave me a set of their steel rocker arms when they first came out for a magazine article, but the rockers were a timebomb so I never used them. The rockers had ribs around the roller tip that were too big. The ribs hit the valve lock before the roller hit the valve stem so the load was all being carried by the valve lock. I never even started the engine when I saw that. Just boxed up the rocker arms and sent them back and never included them in the article. I assume they fixed this design flaw but I haven't looked at a set since.
Re: Rocker arm issues. [Re: AndyF] #3038761
05/01/22 11:38 AM
05/01/22 11:38 AM
So. Burlington, Vt.
So. Burlington, Vt.
The old unbushed will-seize-on-the-shaft CAT stainless rockers were also like that.
There is obviously no testing done on that stuff, or input from builders familiar with the platform for that matter.
I didn’t see where the OP mentioned if this is a BB or SB.
On the SB, there is a definite loss of effective ratio(as measured at the valve) from the 59* lifter bank angle and the pushrod angle.
Re: Rocker arm issues. [Re: AndyF] #3038817
05/01/22 03:42 PM
05/01/22 03:42 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I had the same issue with the ones that 440Source marketed briefly. Put them in the mill and fixed them.
Rocker body wasn't spot faced for the jam nut and when you tightened it down, it broke the adjuster. Source replaced them with new and improved but still had to trim the roller end.
Then discovered the adjusters were made of glass. Replaced them with Comp adjusters and thought we had beat them into submission...
Some time later, I had a valve cover gasket leak that was a big blessing in disguise. Pulled the cover and found one side of the roller end was broken on one rocker and when I took them off the engine discovered the rollers were loose enough on their axles that you could hear them rattle from across the shop when you shook them...
Shoulda just bought the Comp Magnums...
Kevin
Re: Rocker arm issues. [Re: AndyF] #3039043
05/02/22 10:07 AM
05/02/22 10:07 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
small block PRW rocker i recently bought.
no lock interference on this setup.
Page 2 of 3 1 2 3
