Re: Rocker arm issues.
[Re: blue_stocker]
#3038270
04/29/22 03:58 PM
04/29/22 03:58 PM
fast68plymouth
So. Burlington, Vt.
Brad Haak had some really good examples, actual measurements, and CAD drawings in a detailed post about that very thing.
If you search through his posts you should be able to find it.
[Re: JohnRR]
#3038272
04/29/22 04:13 PM
04/29/22 04:13 PM
Posts: 31,096 Oregon
AndyF
Yeah there were all these arguments on the forums years ago so I went and bought one rocker from each mfg and put them all on a shaft. Once I did that I said "okay, now I get it"!
The Mopar rocker arms are all over the map. You don't know what works until you try it. Eventually I created a little cheat sheet that told me which rocker arms worked with which cylinder heads. If a person just randomly selects a rocker arm package then good luck and may the force be with you. Not everything works on everything. Have you shared this cheatsheet ? I wrote a couple of books
[Re: AndyF]
#3038276
04/29/22 04:30 PM
04/29/22 04:30 PM
Posts: 10,772 North Dakota
6PakBee
North Dakota
The Mopar rocker arms are all over the map. You don't know what works until you try it. Eventually I created a little cheat sheet that told me which rocker arms worked with which cylinder heads. If a person just randomly selects a rocker arm package then good luck and may the force be with you. Not everything works on everything. Years ago Racer Brown recommended going through a set of stock rockers and selecting those that had equivalent lifts. I have done this multiple times and yes, the ratio of a stock Mopar rocker is all over the map.
[Re: Greenwood]
#3038305
04/29/22 06:40 PM
04/29/22 06:40 PM
Posts: 1,366 Out of the State of Confusion
blue_stocker
Thanks Dwayne, I'll look into it...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
[Re: Greenwood]
#3038344
04/29/22 07:54 PM
04/29/22 07:54 PM
fast68plymouth
So. Burlington, Vt.
I'm at .513" net valve lift on a .575" roller, at .020" lash. With 1.6 rockers. The rockers aren’t marked for ratio, correct? My guess is....... they’re 1.5’s in a 1.6 box. .575 lift with a 1.5 is .383 lobe lift. You getting .513 with .020 lash, which would put the number at .533 gross lift. 533/383 = 1.39. I find it hard to believe they’d be that far off(1.6 > 1.39). 1.5 > 1.39 would be bad enough.
[Re: fast68plymouth]
#3038401
04/30/22 01:07 AM
04/30/22 01:07 AM
Posts: 344 Red Deer, Alberta
Greenwood
Red Deer, Alberta
I'm at .513" net valve lift on a .575" roller, at .020" lash. With 1.6 rockers. The rockers aren’t marked for ratio, correct? My guess is....... they’re 1.5’s in a 1.6 box. .575 lift with a 1.5 is .383 lobe lift. You getting .513 with .020 lash, which would put the number at .533 gross lift. 533/383 = 1.39. I find it hard to believe they’d be that far off(1.6 > 1.39). 1.5 > 1.39 would be bad enough. The rockers themselves are marked 1.6..
[Re: Greenwood]
#3038448
04/30/22 11:03 AM
04/30/22 11:03 AM
fast68plymouth
So. Burlington, Vt.
The rockers themselves are marked 1.6. Interesting. The ones that were on a motor that was just on the dyno here had no markings. The two that were checked measured in the 1.45 range. This isn’t doing much to make me change my mind about not using Chinese rockers.
#3038530
04/30/22 03:57 PM
04/30/22 03:57 PM
Posts: 43,333 Bend,OR USA
Cab_Burge
The rockers themselves are marked 1.6. Interesting. The ones that were on a motor that was just on the dyno here had no markings. The two that were checked measured in the 1.45 range. This isn’t doing much to make me change my mind about not using Chinese rockers. I've measure a bunch of different brand BB Mopar adjustable rocker arms, stock Ductile iron Max Wedges, stock Street Hemi ductile iron rockers from many different motors, Isky, Cranes and Erson brand ductile iron rocker arms as well as several different brands of aluminum rocker arms like Harland sharp, both early and later made, and several sets of T&D single shaft sets, none of them were dead nuts on the ratio on the complete sets sent to me from the factories I use to send the ductile iron sets to a company in northern, CA for blue printing and making them accurate, after checking several different sets I had done by them I stopped doing that i have not yet check a complete set of Jesel paired shaft aluminum or steel rocker arms, that is next
#3038673
05/01/22 02:32 AM
05/01/22 02:32 AM
Greenwood
Red Deer, Alberta
The rockers themselves are marked 1.6. Interesting. The ones that were on a motor that was just on the dyno here had no markings. The two that were checked measured in the 1.45 range. This isn’t doing much to make me change my mind about not using Chinese rockers. Fair point. I'll probably find out on Monday what the manufacturer has to say.
[Re: Greenwood]
#3038700
05/01/22 08:46 AM
05/01/22 08:46 AM
Posts: 1,200 Loudoun County, VA
Brad_Haak
Loudoun County, VA
How many of the eight common dialects spoken in China do you know?
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Stanton]
#3038743
05/01/22 11:33 AM
05/01/22 11:33 AM
fast68plymouth
So. Burlington, Vt.
That’s all fine and dandy, but it sounds like the Crane 1.6’s yielded .080” more valve lift than the PRW’s with the same cam(lobe lift).
I know which scenario I’d rather have in my engine.
[Re: AndyF]
#3038761
05/01/22 12:38 PM
05/01/22 12:38 PM
fast68plymouth
So. Burlington, Vt.
The old unbushed will-seize-on-the-shaft CAT stainless rockers were also like that.
There is obviously no testing done on that stuff, or input from builders familiar with the platform for that matter.
I didn’t see where the OP mentioned if this is a BB or SB.
On the SB, there is a definite loss of effective ratio(as measured at the valve) from the 59* lifter bank angle and the pushrod angle.
[Re: AndyF]
#3038817
05/01/22 04:42 PM
05/01/22 04:42 PM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
My guess is that someone at the PRW factory stamped a set of 1.50 rockers with the 1.60 ID and then they got boxed and sold as 1.60 rockers. PRW gave me a set of their steel rocker arms when they first came out for a magazine article, but the rockers were a timebomb so I never used them. The rockers had ribs around the roller tip that were too big. The ribs hit the valve lock before the roller hit the valve stem so the load was all being carried by the valve lock. I never even started the engine when I saw that. Just boxed up the rocker arms and sent them back and never included them in the article. I assume they fixed this design flaw but I haven't looked at a set since. I had the same issue with the ones that 440Source marketed briefly. Put them in the mill and fixed them. Rocker body wasn't spot faced for the jam nut and when you tightened it down, it broke the adjuster. Source replaced them with new and improved but still had to trim the roller end. Then discovered the adjusters were made of glass. Replaced them with Comp adjusters and thought we had beat them into submission... Some time later, I had a valve cover gasket leak that was a big blessing in disguise. Pulled the cover and found one side of the roller end was broken on one rocker and when I took them off the engine discovered the rollers were loose enough on their axles that you could hear them rattle from across the shop when you shook them... Shoulda just bought the Comp Magnums... Kevin
