Re: Why do old cars have a hand throttle?
[Re: Sniper]
#3036695
04/24/22 07:59 PM
04/24/22 07:59 PM
Posts: 10,755 North Dakota
6PakBee
North Dakota
If you were in a cold climate, pulling the hand throttle warmed the engine up while you went back in the house and warmed up.
[Re: 6PakBee]
#3036699
04/24/22 08:22 PM
04/24/22 08:22 PM
Posts: 6,317 nowhere
Sniper
nowhere
If you were in a cold climate, pulling the hand throttle warmed the engine up while you went back in the house and warmed up. Isn't that the function of the choke and fast idle?
[Re: Sniper]
#3036796
04/25/22 07:19 AM
04/25/22 07:19 AM
6PakBee
North Dakota
If you were in a cold climate, pulling the hand throttle warmed the engine up while you went back in the house and warmed up. Isn't that the function of the choke and fast idle? Obviously you have never driven a car with a manual choke and a manual throttle in a cold climate. You choked the car to get it started and then started opening the choke and pulling the throttle to keep the engine rpm up. Trying to keep the engine speed up with only the choke results in overchoking the engine as it warms up.
[Re: 6PakBee]
#3036874
04/25/22 10:46 AM
04/25/22 10:46 AM
Sniper
nowhere
If you were in a cold climate, pulling the hand throttle warmed the engine up while you went back in the house and warmed up. Isn't that the function of the choke and fast idle? Obviously you have never driven a car with a manual choke and a manual throttle in a cold climate. You choked the car to get it started and then started opening the choke and pulling the throttle to keep the engine rpm up. Trying to keep the engine speed up with only the choke results in overchoking the engine as it warms up. Guess I didn't grow up on the southern shore of Lake Michigan where the wind whistled down from Canada with nothing to stop it then tended to dump snow right on us. Until it warmed up you pretty much needed full choke to keep it running. The old style choke worked differently then the newer ones. All they did was open or close the choke flap.They didn't have a fast idle linkage. I daily drive a 51 Plymouth. In fact here is a link to it's automatic choke and fast idle setup http://www.yourolddad.com/choke.
[Re: Sniper]
#3036971
04/25/22 02:20 PM
04/25/22 02:20 PM
6PakBee
North Dakota
If you were in a cold climate, pulling the hand throttle warmed the engine up while you went back in the house and warmed up. Isn't that the function of the choke and fast idle? Obviously you have never driven a car with a manual choke and a manual throttle in a cold climate. You choked the car to get it started and then started opening the choke and pulling the throttle to keep the engine rpm up. Trying to keep the engine speed up with only the choke results in overchoking the engine as it warms up. Guess I didn't grow up on the southern shore of Lake Michigan where the wind whistled down from Canada with nothing to stop it then tended to dump snow right on us. Until it warmed up you pretty much needed full choke to keep it running. The old style choke worked differently then the newer ones. All they did was open or close the choke flap.They didn't have a fast idle linkage. I daily drive a 51 Plymouth. In fact here is a link to it's automatic choke and fast idle setup http://www.yourolddad.com/choke. Well, that's interesting. My high school car was a '50 Chevy with the tried and true 216 and three on the tree, hand choke/hand throttle. And I started that in Wyoming winters EXACTLY as I have said. No automatic choke on that puppy. And if your '51 has an automatic choke, it obviously has no manual choke, so.......
