Re: Has anyone ever set up their own starting line/launching pad
[Re: Hemi_Joel]
#3037927
04/28/22 11:15 AM
04/28/22 11:15 AM
Posts: 10,044 MN
JERICOGTX
MN
You could just go to the local 1/8 track that is 45 minutes from your house… the opportunities are so few. You do know you can rent the track. Doesn't have to be a race day. Would be cheaper than trying to set up your own.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3037960
04/28/22 12:51 PM
04/28/22 12:51 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Stop it with your level headed, logical ideas. We are building backyard drag strips over here lol.
(Jeff is probably right)
[Re: JERICOGTX]
#3037963
04/28/22 01:06 PM
04/28/22 01:06 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
You could just go to the local 1/8 track that is 45 minutes from your house… the opportunities are so few. You do know you can rent the track. Doesn't have to be a race day. Would be cheaper than trying to set up your own. I bet Jeff would even split it with you, 90/10!
68 Barracuda Formula S 340
[Re: Jeremiah]
#3037968
04/28/22 01:14 PM
04/28/22 01:14 PM
Posts: 10,044 MN
JERICOGTX
MN
(Jeff is probably right) I’m one of the very few on this board, that has ever been to Joel’s house. Trust me, it’s an accident waiting to happen, and don’t encourage him… Why spend the time and money on this, when the car isn’t running until Drag Week anyways?
69 GTX
68 Road Runner
[Re: Bad340fish]
#3037969
04/28/22 01:15 PM
04/28/22 01:15 PM
Posts: 10,044 MN
JERICOGTX
MN
You could just go to the local 1/8 track that is 45 minutes from your house… the opportunities are so few. You do know you can rent the track. Doesn't have to be a race day. Would be cheaper than trying to set up your own. I bet Jeff would even split it with you, 90/10! 99/1… I’m poor.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3037999
04/28/22 03:36 PM
04/28/22 03:36 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: JERICOGTX]
#3038044
04/28/22 08:17 PM
04/28/22 08:17 PM
Jeremiah
Rogue River, OR
(Jeff is probably right) I’m one of the very few on this board, that has ever been to Joel’s house. Trust me, it’s an accident waiting to happen, and don’t encourage him… Why spend the time and money on this, when the car isn’t running until Drag Week anyways? lol you make several good points sir!
[Re: R3 Racing]
#3038045
04/28/22 08:30 PM
04/28/22 08:30 PM
Jeremiah
Rogue River, OR
I believe it would be possible to build a business around providing dyno services (both chassis and engine) along with actual on track testing for sixty foot launches. The launch testing could include video of all angles above and below. Reaction time tuneing with suspension setups would be available. The ability to include technical services for fine tuning various configurations of fuel injection, grid, turbos, Pro Chargers, and traction control software would be essential. Sales and installation of performance parts could also be iincluded. It could be a must "go to" for both the rookie and the serious racer. I agree however in practice most people are unwilling to spend the money for services like you listed above. At $100/hour for the dyno and $140/hour for a tech you can burn 5k worth of time up pretty quickly. Most of the cars we see on the chassis dyno are finished projects that the owner couldn't get to run right, always blaming the carburetor. About 50% of the time the problem will electrical/ignition , 25% of the time it's because the engine dyno guy "tuned it" only at idle and WOT, nowhere in between and the other 25% are installation errors and manufacturer quality control issues. It's really a good reason to have a guy like Dominic from Thumper Carbs go through your carb (s) before hitting the dyno. The machining is all over the place and assembly line (wet flowed) must be done without a human present. The AED 950 I have shot fuel straight up out of both squirter screws because the top gaskets were missing. It was marked "tested" or something like that on the spec card which makes it even more hilarious to me. If the car needs a $1000 or better carb/ignition/wiring rehab, 3-4 hours on the wheel dyno ($400 + 560) and then 3-4 hours of chassis tuning ($560) you have about $2500 into a days worth of work at the shop. Most people I know are too cheap or their lust for automotive knowledge keeps them from spending money like that when parts could be funded. Just one guys opinion..
