Re: Torque converter bolts/clearance [Re: Dartsport540] #3032531
04/11/22 09:30 AM
04/11/22 09:30 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
The last converter that I had that broke plates, broke 2 of them. It turned out that the snout was just a little too big to let it seat all the way into the back of the crank. That caused the flex that cracked the plates. Ground the OD of the converter snout down a bit so that it would fully seat into the crank and no more broken plates. I have found another new converter whose snout was just a little too large, too. Shaved it down a little and have had no problems with it's plate. twocents
Master, again and still
Re: Torque converter bolts/clearance [Re: Dartsport540] #3032532
04/11/22 09:33 AM
04/11/22 09:33 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Look at the difference in the amount of material between the holes and the circumference of plates pictured.
Obviously a considerable loss of strength there.
Anyone have a pic of a MOPAR OE plate to compare?
I would imagine the ability to resist deformation when torqueing the cracked plate
is compromised and leads to failure. My observation.
Joe
PS The failed plate pictured is what's installed on our 440. The inspection plate is coming off
at the next opportunity!!
