UCA Modification for A-body #3031774
04/08/22 08:14 AM
04/08/22 08:14 AM
Chicago-area Illinois
4mopower Offline OP
4mopower  Offline OP
Seen this part to level out the UCA on E-bodies for improved handling, any benefits to doing the same on a. A-body? Would you want to do this on a track car only?
Thanks.
Re: UCA Modification for A-body [Re: 4mopower] #3031959
04/08/22 07:32 PM
04/08/22 07:32 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks.
Hotchkis said it was not needed when they did their suspension geometry analysis and plotting on the A-body platform.
It's done on the E-bodies to remove anti dive that helps improve bump steer.
I measured bump steer with a real bump steer gauge on my A-body 68 Barracuda. It has Hotchkis setup with the A-arms in the stock geometry.
The Bump Steer measurements were very good without even adjustment. 0.055" at 2" compression/dive/bump is only less than 1/16" So my finding seemed to match what Hotchkiss determined.
7590606-BumpSteer2_2_12Md1.JPG7590664-Hotchkis7_27_10TVSbuildSm29 (1).jpg7590697-CorrectedBumpSteerChartLFInitial (1).jpg
Re: UCA Modification for A-body [Re: autoxcuda] #3032026
04/09/22 01:38 AM
04/09/22 01:38 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I thought all the 62-72 B, 70-74 E and all A body cars had the "Anti-Dive" built in as evident by the lower position of the rearmost UCA bushing.
Re: UCA Modification for A-body [Re: Kern Dog] #3032043
04/09/22 07:44 AM
04/09/22 07:44 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
They do.
It just doesn't affect bump steer on the a body.
Re: UCA Modification for A-body [Re: Sniper] #3032143
04/09/22 03:44 PM
04/09/22 03:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
They do.
It just doesn't effect bump steer on the a body.
Correct.
And there's many other geometries that effect bump steer too. The Anti-Dive is not the only thing. There may be some things that cancel out others. But the net sum overall on a A-body is not bad at all.
That said. My car is lowered and I only measured to 3". Not really going to get to 3" extension/rebound on the street or roadcourse. Especially with higher spring rates. We're not Off-Roading this deal.
Now on a drag car the light front spring rates may pull the front tires nearly or completely off the ground. In that case, extension/rebound may get over 3". So the range of concern is much higher on those cars.
Re: UCA Modification for A-body [Re: autoxcuda] #3032507
04/11/22 06:04 AM
04/11/22 06:04 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Yes, drag car use a lot of tricks that are inimical to good handling. But that's another forum, not this one.
Re: UCA Modification for A-body [Re: Sniper] #3032779
04/12/22 12:54 AM
04/12/22 12:54 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Inimical ??
Who are you trying to impress?
Re: UCA Modification for A-body [Re: 4mopower] #3032794
04/12/22 05:59 AM
04/12/22 05:59 AM
4mopower Offline OP
4mopower  Offline OP
Thanks everyone for your replies, probably nothing I need to bother with.
I do have AM UCA and the upper ball joint is on the same plane as the UCA not rotated vertical to the knuckle (spindle) like an OEM part.
No issues so far just curious as to efffect to steering movements.
Thanks.
