Re: 572 all aluminum headed to dyno
[Re: HardcoreB]
#3205239
01/16/24 01:03 PM
01/16/24 01:03 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Hey Sean, Looks like I quoted the wrong post
[Re: fast68plymouth]
#3205240
01/16/24 01:04 PM
01/16/24 01:04 PM
Posts: 31,050 Oregon
AndyF
The cnc345 is really better with a 2.25” intake valve.
Were those used in the EZ heads? The Big EZ comes with a 2.19 intake but Best Machine opened the heads up to 2.250. So we'll be able to swap the 2.250 intakes over to the -1 heads. We kind of have to go this way anyway since the Big EZ castings are not available at the moment. The other choice was to step up to the 572-13 heads but that was going to be a bunch more money and time to replace pistons as well as other parts.
[Re: HardcoreB]
#3205242
01/16/24 01:08 PM
01/16/24 01:08 PM
AndyF
Oooof! that's not right. Hope there is some restitution for you. Do they leak OIL or COOLANT? What MPH/ET did the car wind-up running? Probably not great MPH because it's not the most aerodynamic set-up. The car was pretty consistent in the low 9's the last time I saw it. I don't think I saw the car run at all in 2023. They toured around to some different tracks but I never happened to be at the same spot. Heads are leaking coolant in multiple ports. I've heard that it can be a problem with the Big EZ heads, especially when they are opened up for a larger intake valve. We rolled the dice on this engine and lost. I have a lot of confidence in the -1 345 package. I've seen a lot of those heads in use and haven't heard of any issues with them.
[Re: AndyF]
#3205251
01/16/24 01:12 PM
01/16/24 01:12 PM
fast68plymouth
So. Burlington, Vt.
It might be worth sending the heads to Indy to see if they can be repaired.
Do you know what areas of the port are leaking?
[Re: AndyF]
#3205256
01/16/24 01:24 PM
01/16/24 01:24 PM
Posts: 4,074 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Oooof! that's not right. Hope there is some restitution for you. Do they leak OIL or COOLANT? What MPH/ET did the car wind-up running? Probably not great MPH because it's not the most aerodynamic set-up. The car was pretty consistent in the low 9's the last time I saw it. I don't think I saw the car run at all in 2023. They toured around to some different tracks but I never happened to be at the same spot. Heads are leaking coolant in multiple ports. I've heard that it can be a problem with the Big EZ heads, especially when they are opened up for a larger intake valve. We rolled the dice on this engine and lost. I have a lot of confidence in the -1 345 package. I've seen a lot of those heads in use and haven't heard of any issues with them. I know a guy with both 440-1's and 572-13's that would consider selling one or the other. Same guy is modeling some 1.3 ish C/H 572-13 pistons around a 4.505 bore.
[Re: AndyF]
#3205262
01/16/24 01:36 PM
01/16/24 01:36 PM
fast68plymouth
So. Burlington, Vt.
I figured that’s where they would be leaking from. A lot of material gets removed from there with the 325 program.
[Re: HardcoreB]
#3205277
01/16/24 02:20 PM
01/16/24 02:20 PM
fast68plymouth
So. Burlington, Vt.
Wonder if they use the 'SR' INTAKE port with a lower exhaust? Randy has the cnc '345' -1 Indys with 2.25" Intakes on his jalopy with a SMALL/gentle cam you spec'd. 540" The EZ intake ports are not the same as the SR either. In ootb form, they’re better……..and easier to get into the 340+ range. Hard to believe I sold that cam to your friend 15 years ago!!
[Re: AndyF]
#3205289
01/16/24 03:11 PM
01/16/24 03:11 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Were those used in the EZ heads? The Big EZ comes with a 2.19 intake but Best Machine opened the heads up to 2.250. So we'll be able to swap the 2.250 intakes over to the -1 heads. We kind of have to go this way anyway since the Big EZ castings are not available at the moment. The other choice was to step up to the 572-13 heads but that was going to be a bunch more money and time to replace pistons as well as other parts. The cost to go with 572-13 is high, since you have to change rocket gear, pushrods, pistons. But power at that level is never cheap. Top it off with a recert on my car, since i am certain it can now run sub 8:50 and exceeds 150 mph, needing a head restraint system this year. In my case, going from a 550 cube 15/1 compression combo with maxed out 440-1 heads sporting 2.30/1.78 valves, dyno numbers were 926 hp. A move to 572-13 cnc385 heads, same size at 549, but an aluminum block, yielded 982 hp at a higher 7600 rpm . Now if i build a bigger shortblock,,,,,,,,,,,,,,,,,
#3205295
01/16/24 03:46 PM
01/16/24 03:46 PM
HardcoreB
Shelby Twp. Mi
Wonder if they use the 'SR' INTAKE port with a lower exhaust? Randy has the cnc '345' -1 Indys with 2.25" Intakes on his jalopy with a SMALL/gentle cam you spec'd. 540" The EZ intake ports are not the same as the SR either. In ootb form, they’re better……..and easier to get into the 340+ range. Hard to believe I sold that cam to your friend 15 years ago!! Right! He's really happy with it. At the rebuild, he considered more power so, I loaned him a bigger one to test fit but it didn't have the P2V to use. I more showed the specs to give a performance context to this thread.
