Page 2 of 3 1 2 3
Re: Raising compression in a 400? [Re: polkat] #303088
04/30/09 02:35 AM
04/30/09 02:35 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
Well, I suppose if there was something I WANTED to hear, what hemigod426 just added would be it! So if I mount a set of 516 heads (say with the steel shim gaskets-I have some) on the 400, milling them .040" if necessary, I would get something near 9.2 to 1 compression? That's what I was after. Does anyone else agree?
if you also mill them 40 it will be 10 to1 with 39 thou felpros. 400 has biggest bore size, which means more comp gains per smaller head than 383/440 motors
MOPAR OR NO CAR
Re: Raising compression in a 400? [Re: hemigod426] #303089
04/30/09 02:39 AM
04/30/09 02:39 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
516 might spec at 74cc but unless it's already been milled they typically measure 84cc....
And that 8.5 C/R estimate is pretty optimistic as well...
Re: Raising compression in a 400? [Re: 1_WILD_RT] #303090
04/30/09 02:49 AM
04/30/09 02:49 AM
hemigod426 Offline
hemigod426  Offline
i just milled my 906 heads 40 and there are now 74cc and those are open chambers, 516 are same chamber as 915 closed there 74-5 ccs now unmilled. you can have a 8.2 to 1 400 seen many with taller than factory deck like plus 20-25 thou. got my 906 head soo tight by also putting in 2.14/1.88 monster farera nontulup valves
MOPAR OR NO CAR
Re: Raising compression in a 400? [Re: hemigod426] #303091
04/30/09 03:02 AM
04/30/09 03:02 AM
Doesn't the low compression 440 pistons in a 400 bring it up to 10.1? You may have to cut valve reliefs but.....
Re: Raising compression in a 400? #303092
04/30/09 03:05 AM
04/30/09 03:05 AM
hemigod426 Offline
hemigod426  Offline
you cant put 440 pistons in 400, 440 has 4.32 bore 400 has 4.34 bore and 440 has 6.76 long rod for raised block 400 is low deck with monster bore
MOPAR OR NO CAR
Re: Raising compression in a 400? [Re: hemigod426] #303093
04/30/09 03:36 AM
04/30/09 03:36 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We run a stock stroke 400 in my sons Dart. We use KB pistons and with the closed chamber 84 cc Eddy heads that we milled .040 we have 10.6 comp using the .039 head gasket. It works great as it is a driver street car that weighs almost 3600 with him in the car. And it has run 11.40's with 3.91's. Change the pistons and decide on the heads you want to use (closed chamber will be best) and then calculate the comp to see if any milling is needed. Its really not hard to get comp in a 400. Ron
Re: Raising compression in a 400? [Re: hemigod426] #303094
04/30/09 04:04 AM
04/30/09 04:04 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I don't remember the formula off hand, but I really don't think cutting .040 is going to bring a 90cc 906 head down to 74cc.
Re: Raising compression in a 400? [Re: hemigod426] #303095
04/30/09 04:27 AM
04/30/09 04:27 AM
https://board.moparts.org/ubbthreads/showflat.php?Number=5153974&page=0
http://www.moparchat.com/forums/showthread.php?t=90139
http://valiantlord.com/engine.html
Re: Raising compression in a 400? #303096
04/30/09 08:31 AM
04/30/09 08:31 AM
AZ
FM370RR Offline
mopar addict
FM370RR  Offline
mopar addict
AZ
Re: Raising compression in a 400? #303097
04/30/09 09:26 AM
04/30/09 09:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You use the "Lighten up Francis" ALMOST as much as you use the "Outside the box thing" Think up some new ones or crawl back under your rock PLEASE!!!!!!!
Do you actually have anything constructive to add , if not go back under your BRIDGE ... PLEASE ...
Re: Raising compression in a 400? [Re: hemigod426] #303098
04/30/09 09:32 AM
04/30/09 09:32 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
you can get .020 over 440 pistons at 4.34" or .030 over at 4.35". 0 deck on a 400 block should be a compression height of ~ 1.932". federal mogul stock replacement pistons are 1.813" CH, so I'd imagine the stock pistons would be ~.120" in the hole. low comp 440 replacement pistons are 1.912" CH, so they'd be ~.020 in the hole if the deck is at blueprint spec.
assuming blueprint deck height on 9.98", .020" steel shim head gaskets, 90cc open chamber heads, and .020 in the hole low comp 440 pistons, you're looking at 9.12:1 compression by the math.
2017 Grand Cherokee Overland
Re: Raising compression in a 400? [Re: hemigod426] #303099
04/30/09 09:35 AM
04/30/09 09:35 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Someone must have milled those 906's then because out of the factory it will usually measure 90 cc. typically every .005 is 1 cc so with .040 off you only pulled out 8cc . the specs you are quoting for the 915 is NHRA I'm guessing which is alot smaller than ACTUAL .
As far as everyone telling him to change to a taller CH piston with it the way it is another post brought up a valid point ... CYLINDER RIDGE , unless he removes the ridge he will BREAK the new rings and from the sounds of it , NO ENGINE HOIST and he says he has NO CAR the block isn't coming out of whatever it's in anytime soon .
Buy hemigod's 516's and thats the best you will do with the constraints you have to work around for the short term fix .
Re: Raising compression in a 400? [Re: FM370RR] #303100
04/30/09 09:37 AM
04/30/09 09:37 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what about these.
http://cgi.ebay.com/ebaymotors/KEITH-BLA...p4506.m20.l1116
Those are both STROKER pistons , I don't think that's an option at this point ????
Re: Raising compression in a 400? [Re: JohnRR] #303101
04/30/09 11:04 AM
04/30/09 11:04 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I'm sure a head change will yield some increase in compression, but with worn bores and rings I gotta think blowby is going to be increased greatly. So, how much additional compression is he really going to get?
Re: Raising compression in a 400? [Re: 64Post] #303102
04/30/09 11:10 AM
04/30/09 11:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Judging by where and how this is bouncing all over the place you are just adding more facts that are confusing the issue and I don't think it really matters, if I'm reading this right getting any work done outside of just bolting on parts to the shortblock as is is the only course of action ?
There isn't a piston that will swap directly in that's not going to cause havoc with the rings and the current ridge, that's an issue being ignored.
One thing that is been glossed over is no 440 piston is going to fit a standard bore 400 because the standard bore of a 400 is 4.342 , thats .022 oversize .
Re: Raising compression in a 400? [Re: JohnRR] #303103
04/30/09 11:32 AM
04/30/09 11:32 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Yeah, that's why I was trying to stay out of it. But it's like a train wreck...
Nothing that a piston stretcher or some aggressive knurling won't fix...
Re: Raising compression in a 400? [Re: JohnRR] #303104
04/30/09 11:37 AM
04/30/09 11:37 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Don't buy new pistons to put in an old, worn block. You're gonna spend $200-300 on pistons and rings but what kinda ring seal will you have???
If you want some ideas on low-compression fixes, read this one:
https://board.moparts.org/ubbthreads/show...rue#Post5195287
Aside from that, I have to be harsh here:
If you have no daily driver, no engine hoist, etc, you are lacking some of the basic resources to do this job properly.
By 'properly', I'm not even referring to a high-HP engine, I'm just talking about an engine that will last for a few years.
If you're not planning for this engine to be used for a few years when you get it running, just skip this activity altogether and plan for the next step - either getting a good used engine or a well-planned rebuild.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Raising compression in a 400? [Re: Fury Fan] #303105
04/30/09 12:03 PM
04/30/09 12:03 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Exactly what I said way back when. But nobody seemed to agree and kept on with the new piston thing.
Re: Raising compression in a 400? [Re: MoparforLife] #303106
04/30/09 12:52 PM
04/30/09 12:52 PM
GA
roadrunninMark Offline
GA
I would go buy hemigod'a heads and then buy a set of gapless piston rings to take care of any blow by from the additional compression. That will also help seal up if the block is a little worn. It isnt hard to install new rings and they aren't that expensive. Plus the gapless rings will be like adding a few hundredths of compression maybe also hone the block with the simple hand tool verison on a drill.
Mark
Re: Raising compression in a 400? [Re: roadrunninMark] #303107
04/30/09 12:59 PM
04/30/09 12:59 PM
Upper Midwest
Upper Midwest
Rings just plain aren't going to make up for an out of round cylinder but do what you want. If you go with the tight clearance KB pistons be prepared for some piston slap too. If you are going to spend the money for new pistons do it right. For about 125 bucks you can have it bored and the pistons fit right.
Page 2 of 3 1 2 3
