Re: 572 all aluminum headed to dyno
[Re: Al_Alguire]
#3030955
04/05/22 02:45 PM
04/05/22 02:45 PM
Posts: 10,029 MN
JERICOGTX
MN
I did not know that. Interesting.
69 GTX
68 Road Runner
[Re: fast68plymouth]
#3036434
04/23/22 07:32 PM
04/23/22 07:32 PM
Posts: 31,045 Oregon
AndyF
They were still racing when I left. Even with the bog off the line he ran a 9.30 so once he gets the launch sorted out he should pick up some.
[Re: AndyF]
#3036459
04/23/22 09:20 PM
04/23/22 09:20 PM
Posts: 10,029 MN
JERICOGTX
MN
Looks like the car would benefit from an anti roll bar.
69 GTX
68 Road Runner
[Re: AndyF]
#3036630
04/24/22 04:04 PM
04/24/22 04:04 PM
Posts: 19,368 Las Vegas
Al_Alguire
Las Vegas
Definitely NEEDS an anti roll. Lots of ways t tune a wheelie out and if only using them as a "safety" device will be just bad as tuning the wheelie out on performance.
[Re: 572B1]
#3036633
04/24/22 04:19 PM
04/24/22 04:19 PM
AndyF
Thats about 772 hp at the engine. going by the wallace calculator. Ran a 9.27 today without any changes to the engine.
[Re: AndyF]
#3036697
04/24/22 08:06 PM
04/24/22 08:06 PM
Posts: 855 Brisbane Australia
572B1
Brisbane Australia
Thats about 772 hp at the engine. going by the wallace calculator. Ran a 9.27 today without any changes to the engine. Getting there Andy. 794 hp what was the best mph?
[Re: AndyF]
#3036873
04/25/22 10:45 AM
04/25/22 10:45 AM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I thought the race weight was in the 3200lb range??
[Re: AndyF]
#3036942
04/25/22 12:57 PM
04/25/22 12:57 PM
fast68plymouth
So. Burlington, Vt.
So, 3000+ driver.
I guesstimated 3200........ I suppose that could also be 3300, or more.
[Re: HardcoreB]
#3205208
01/16/24 11:32 AM
01/16/24 11:32 AM
fast68plymouth
So. Burlington, Vt.
The cnc345 is really better with a 2.25” intake valve.
Were those used in the EZ heads?
[Re: HardcoreB]
#3205213
01/16/24 11:43 AM
01/16/24 11:43 AM
fast68plymouth
So. Burlington, Vt.
I was of the assumption that the intake port of the EZ was the same as the -1. The difference between the two being the exhaust port height. I have to say I wouldn't be happy with multiple intake port leaks after 2 years of use. Doug
As cast, the EZ head has its own unique port shapes not shared with the other models. The floor is higher than a -1, with a much more rounded approach to the SSR, and a larger SSR radius. I do believe the ez325 and the -1 325 utilize the same cnc program in the intake ports(I’m not certain of this since I haven’t had a pair of each here in the shop at the same time), which removes quite a bit of material from the EZ floor.
#3205219
01/16/24 12:01 PM
01/16/24 12:01 PM
Posts: 4,057 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Oooof! that's not right. Hope there is some restitution for you. Do they leak OIL or COOLANT? What MPH/ET did the car wind-up running? Probably not great MPH because it's not the most aerodynamic set-up. As cast, the EZ head has its own unique port shapes not shared with the other models. The floor is higher than a -1, with a much more rounded approach to the SSR, and a larger SSR radius. I do believe the ez325 and the -1 325 utilize the same cnc program in the intake ports(I’m not certain of this since I haven’t had a pair of each here in the shop at the same time), which removes quite a bit of material from the EZ floor. Agreed...the -1 345 SHOULD have the 2.25" And IIRC AndyF said his had the 2.25 installed by BEST. Wonder if they use the 'SR' INTAKE port with a lower exhaust? Randy has the cnc '345' -1 Indys with 2.25" Intakes on his jalopy with a SMALL/gentle cam you spec'd. 540" 12.9:1 It showed about 146 or so MPH so far @ 3300lbs. But there's definitely room for more in it's performance.
