Re: BB Head Gaskets
[Re: reknapp52]
#3028467
03/28/22 07:54 PM
03/28/22 07:54 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I cannot explain why or the engineering behind it, but I just know I have read that it was designed on purpose like that. But, not sure if that statement I had read was substantiated.
Re: BB Head Gaskets
[Re: reknapp52]
#3028482
03/28/22 08:24 PM
03/28/22 08:24 PM
Posts: 43,263 Bend,OR USA
Cab_Burge
I've noticed on my low deck motor that the FelPro head gaskets have a restrictive slot where the coolant flows from the block into the heads. Does a factory head gasket have the same slot? Any harm done to open it up and get more flow? Or maybe there is a reason for it? Someone smarter than me must have designed it that way. Which slots are you talking about? Pictures are worth a 1000 words If your talking about the narrow short slits in the middle of the block and heads the factory did that for allowing a small amount of coolant to transfer from the block into the heads instead of making all the coolant go all the way back to the rear of the block to transfer into the heads through the big hole at the top rear of both sides of the blocks and heads
Re: BB Head Gaskets
[Re: reknapp52]
#3028718
03/29/22 02:37 PM
03/29/22 02:37 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Your question of concern is common.
Head gaskets are designed to control the flow pattern and volume of coolant between the block and the head. Yes, some casting holes are blocked and/or restricted... again, to control the flow pattern and volume of coolant.
DO NOT EVER modify the head gasket's holes or you will encounter problems with engine temp at areas of the engine that you can't see. These patterns are designed by the OE developer.
I'm a former long-term applications engineer for a major gasket company.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
Re: BB Head Gaskets
[Re: Mopar Mitch]
#3028872
03/29/22 11:29 PM
03/29/22 11:29 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I'm a former long-term applications engineer for a major gasket company. The slots prevent air pockets and allow a limited amount of coolant flow to help equalize the cylinder head temperatures. The majority of coolant is forced to flow from the front of the block to the back of the block, then up through the back of the cylinder head to the front of the cylinder head. Enlarging the gasket holes will reduce the amount of coolant going to the rear cylinders and cylinder head. There is a misconception that making the holes larger makes the engine run cooler because the front of the engine where the temp sender is will be running cooler than the rear part of the engine.
Re: BB Head Gaskets
[Re: 451Mopar]
#3028990
03/30/22 01:59 PM
03/30/22 01:59 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
Twice per month call at the Tech Line.
Another was "I set it dot to dot and turned it around and around, then after I turned it #1 wasn't at TDC firing anymore when it was dot to dot, then I kept turning it round and round and couldn't figure it out, so your parts are junk"
Rich H.
Esse Quam Videri
Re: BB Head Gaskets
[Re: reknapp52]
#3029006
03/30/22 03:03 PM
03/30/22 03:03 PM
Mopar Mitch
Furthermore, the extra casting holes, as well as extra large size, are primarily intended to extract sand from the casting process... on all blocks and heads from any mfgr.
Mopar Mitch
Re: BB Head Gaskets
[Re: ZIPPY]
#3029012
03/30/22 03:11 PM
03/30/22 03:11 PM
Posts: 4,694 Wichita
GY3
Wichita
LOL! Probably why most people called the .528 MP cam junk. After degreeing in, mine was 8* retarded when installed "dot to dot". Try to convince the masses that even the most mundane builds need degreed, though.
Re: BB Head Gaskets
[Re: GY3]
#3029034
03/30/22 06:00 PM
03/30/22 06:00 PM
ZIPPY
S.E. Michigan
#1 vs #6 piston and valve activity seemed to be beyond alot of folks.
Attitudes are: Head gaskets must all be made in China, because they have restricted coolant flow to some holes.
That kind of stuff is the ridiculous waste of time kind of material people will call up and complain about to anyone who will listen, and is just the everyday stuff faced by a Tech Guy.
Spring relocation kit discussions were usually pretty entertaining. Plenty of others.
The reason the 528 cam was called junk by so many is because it idled like a garbage truck and made a bunch of torque, and we can't have that! If you don't have to have a 5 grand converter and 4.88s, clearly it can't be any good. That's the attitude....
Rich H.
Esse Quam Videri
