what's the verdict.... #3027968
03/27/22 07:37 AM
03/27/22 07:37 AM
usa
lewtot184 Offline OP
usa
on summit brand hydraulic flat tappets?
Re: what's the verdict.... [Re: lewtot184] #3027981
03/27/22 08:59 AM
03/27/22 08:59 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I have 4500 miles on a set in a 440 and no issues.
1969 Hemi Roadrunner 2nd owner
Re: what's the verdict.... [Re: 69hemibeep] #3027997
03/27/22 09:48 AM
03/27/22 09:48 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Ran one of the cam kits for several years in my 400. No problems with it. twocents
Re: what's the verdict.... [Re: bobby66] #3028061
03/27/22 02:02 PM
03/27/22 02:02 PM
usa
usa
i'm thinking stock magnum cam and light springs may be ok,.... shruggy.
Re: what's the verdict.... [Re: lewtot184] #3028062
03/27/22 02:05 PM
03/27/22 02:05 PM
Guitar Jones Offline
I had way better luck with the Summit flat tappet cam kit then with 2 Comp Cams kits. It just wasn't enough cam.
Re: what's the verdict.... [Re: lewtot184] #3028110
03/27/22 04:55 PM
03/27/22 04:55 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Used them in a few Mild builds and have had no issues.
The only Carbs I care about are under the hood!
