Re: 383 pistons in 426 wedge [Re: Dodgem] #302485
04/29/09 01:57 PM
04/29/09 01:57 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
a cheaper alternative might be to get a 4.15" cast stroker crank.
kb-silvolte.com shows the #1271 piston (for a 383) as a 1.848" comp height.
1.848+6.76+(4.15/2)= 10.683", or .042" in the hole based on the blueprint height of 10.725" for an RB block.
based on my calculations assuming a .040" head gasket and 88cc heads, you're looking at about 9.96:1 compression
use a largish cam or a wide LSA to make the intake closing point late to bleed cyl pressure, and it should run on pump premium.
better check your math
1.848 + 6.76 + (3.75/2= 1.875) = 10.483 - 10.725 = -.243
About 7 to 1 compression give or take
his math was using a stroker crank , 4.15 stroke . 3.75 stroke and the piston he has currently has a 1.932 CH , assuming it's a factory std bore 383 piston from 68-69 , the OP didn't state what the piston ACTUALLY is .
Re: 383 pistons in 426 wedge [Re: JohnRR] #302486
04/29/09 02:10 PM
04/29/09 02:10 PM
AndyF Online content
AndyF  Online Content
Yeah, a 383 piston with a 4.150 stroke crank comes close to working in a 426 block. Just depends on the details and what the engine builder is trying to accomplish.
Semi-custom pistons don't cost that much these days. I think Diamond only charges $15 per piston to change the CH on a standard part number piston. So you just call them up and order a 383 piston and ask them to make the CH a little higher and you end up with exactly what you want. As long as the change can be handled in the shelf stock forging blank the cost is minor.
Re: 383 pistons in 426 wedge [Re: AndyF] #302487
04/29/09 03:00 PM
04/29/09 03:00 PM
Eastern ohio
Alexdodge Offline OP
Eastern ohio
The 383 pistons in the 426 that are in there now are about .200 in the hole. I spoke with Dave at Hughs Engines and he figured the correct flat top pistons that they sell at .030 over would come in at about .060 in the hole. With the 452 heads it should be about 9.1 to 1 compression. This is by his figures. This would be great for me being that the car is strictly a cruiser and for touring with the car club. He said I could do better by using a thinner head gasket.
I wonder if it would be better to use the 516 heads that I have on the shelf?
Thanks all, Alex
Re: 383 pistons in 426 wedge [Re: Alexdodge] #302488
04/29/09 03:12 PM
04/29/09 03:12 PM
JohnRR Offline
JohnRR  Offline
Thanks all, Alex
Either way you have no quench , the 452's will flow better than the 516's .
Re: 383 pistons in 426 wedge [Re: JohnRR] #302489
04/29/09 05:30 PM
04/29/09 05:30 PM
Eastern ohio
Eastern ohio
This is where I get totally lost. This "quench" thing everyone keeps bringing up. So what happens when there is no quench and how do I get it. How can I not have it if I'm using just stock type parts??? Is there somewhere that I can read about to get an understanding?
Does not having quench lead to pinging in the motor? Thanks, Alex
Re: 383 pistons in 426 wedge [Re: Alexdodge] #302490
04/29/09 05:45 PM
04/29/09 05:45 PM
JohnRR Offline
JohnRR  Offline
Quench wasn't a big deal when you could buy hi octane fuel at the pump on any street corner for pennies a gallon , now it's what you need to achieve if you wnat optimum performance to run on the piss available on every street corner.
Yes it can lead to detonation (pinging) especially with higher compression ratios .
What you want is .040-.045 between the piston and the head on the side of the chamber away from the valves , to achieve it with open chambers leads to aggressive head milling or step dome pistons , with closed chamber you want the piston no more than .020 below the deck with a steel shim gasket or zero deck with a composite gasket and a closed chamber head.
I have 2 friends with almost identical built 440's both using the same cam and 906's, one with KB step domes and .060-.065 quench distance , his compression ratio was 9.3 and it would ping with anything less than 93 octane , other was a motor I did a lot of machining to achieve .040-.043 with the same step dome pistons. The heads were something I had bought from another member with big valves and milled about .050 initially and compression ended up about 10.3, this one ran with no pinging on 93 octane with 38 degrees total timing.
As far as why you don't have it using stock type parts , mopar didn't do anything to really achieve it so it's a mix and match to get it if possible , unfortunatley you are working with something you can't mix and match with .
I don't know what hughes has for pistons but to get it with your 452's will be impossible without a custom piston , which is easily doable. I'm getting ready to have a set made up by diamond and it's not as pricey as you would expect for a 440 build I'm doing using 452's. Or you need a flat top with about 2.060 CH , that'll be .020 in the hole on a 10.725 deck , steel shim gasket and a closed chamber head of your chosing .
Re: 383 pistons in 426 wedge [Re: Alexdodge] #302491
04/29/09 05:52 PM
04/29/09 05:52 PM
JohnRR Offline
JohnRR  Offline
Thanks all, Alex
I just ran this setup with the hughes engine piston thru a calculator , Dave is correct , you'll have 9.1ish compression , no quench , you can run that and with the right tune it won't be a pinging pig , this is using the 452's , the 516's will bump the compression closer to 10.0 , you may have issues but with a custom ground cam and the right tune you should be ok , but you'll give up a little because of the lack of quench , to get it would require cutting .040 off the block which I highly do not recommend as the machining cost will get you up to having Diamond make you a better suited piston .
Re: 383 pistons in 426 wedge [Re: JohnRR] #302492
04/29/09 06:18 PM
04/29/09 06:18 PM
Eastern ohio
Eastern ohio
John, In my other car I have a 440 block that I put in sixpack pistons and sixpack rods. I'm using 452 heads on this motor and I do have pinging at higher rpms. More noticable when I get on it. Would a different set of heads do better on this motor?Like 915s? I always hated hearing the pinging!!!
Going back to the 426, can you tell me what specs I would need to order custom pistons for this engine to make it right? Thanks, Alex
Re: 383 pistons in 426 wedge [Re: Alexdodge] #302493
04/29/09 07:42 PM
04/29/09 07:42 PM
JohnRR Offline
JohnRR  Offline
the 440 you can tune that out somewhat , rool back the timing some , if vac advance is connected disconnect or limitthe amount of advance , putting on the 915's would help it alot , the open part of the chambe on a 452 can be as much as .120 deep and I'll assume you are using composite gaskets .
As far as the 426 , no because I can't tell if your block is square as it is and what the ACTUAL deck height is from where I live anything would be a complete guess and that's not a good way to measure for customs .
Re: 383 pistons in 426 wedge [Re: JohnRR] #302494
04/29/09 07:48 PM
04/29/09 07:48 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
did not see it was 4.15
Re: 383 pistons in 426 wedge [Re: Alexdodge] #302495
05/03/09 10:16 PM
05/03/09 10:16 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Are you looking for a set of old standard bore pistons, flat tops? I also know where there is a set of 70 over hi comp pistons. Or even some real old TRW 60 over 13.5 pistons.
