Extended flat torque curve #3021248
03/06/22 12:32 PM
03/06/22 12:32 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Why do some engines have a long flat torque curve in the upper register ?
What engine characteristics produce this ?
Long rods, good intake/exhaust balance, not too much overlap, high compression, maybe these, I don't know what else ?
Sufficient valve spring, fuel, and ignition too, but those are not design parameters.
Big valves for the displacement ?
Re: Extended flat torque curve [Re: hemienvy] #3021271
03/06/22 01:47 PM
03/06/22 01:47 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Boiling it down to the basics.........
The required air flow(and trapped VE) is keeping up with the demand as the rpm goes up.
That can be done by a variety of methods, and/or by mixing and matching different methods.
Different engine platforms need help to accomplish that in different areas.
Re: Extended flat torque curve [Re: hemienvy] #3021273
03/06/22 01:53 PM
03/06/22 01:53 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
mainly its the cam. everything else sets up around that.
Re: Extended flat torque curve [Re: ek3] #3021275
03/06/22 02:00 PM
03/06/22 02:00 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
It's the combination of parts working together. Wouldn't say it's mostly -cam -heads -valvetrain stability, induction/exhaust flow, or anything else because just one thing off in the entire combination can cause the high rpm VE to drop like a rock
Re: Extended flat torque curve [Re: INTMD8] #3021287
03/06/22 03:06 PM
03/06/22 03:06 PM
UK
rb446 Offline
rb446  Offline
UK
And here's a good example of exactly that with VE on our mild 10:1CR 589 wedge motor, 572-13's 365cnc heads, 260/270@.050 s/roller, 440-2, 1.55 Jesels, bit of a mismatch of parts as it came all built/dyno'd but it runs real well with that small carb, the small venturi probably shows up on the ET rather than on the dyno hp. Torque holds on reasonable as well through 1100rpm, it did what we wanted it to do ET wise in the car and then some.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Extended flat torque curve [Re: rb446] #3021290
03/06/22 03:22 PM
03/06/22 03:22 PM
So. Burlington, Vt.
So. Burlington, Vt.
This one has a torque curve that’s within 20ft/lbs for over 1500rpm........
It has all the usual stuff to achieve that.
Good heads, nice cam, high CR, stable valvetrain, big intake and carb, good oil pan.
Re: Extended flat torque curve [Re: hemienvy] #3021300
03/06/22 04:17 PM
03/06/22 04:17 PM
Almost all the pump gas stroker motor BB Mopar V8 I've built, and dyno tested that had less than 10.5 to 1 compression made more torque than HP, especially with iron heads below 10.0 1 to 1 compression ratio up
My first 400 stroker motor I built had a 4.25 stroke crank with 6.8 long Chinese H beam steel rods with 9.25 to 1 comp ratio 23.0 CC dished pistons with a set of iron 906 heads with big valves, low deck six pack intake and carbs, solid roller cam that motor made 612 HP at 55000 RPM with 644 Ft.. Lbs. of tire frying torque at 4500 RPM boogie up
I don't remember the exact torque numbers now but we started the first pulls at 2500 RPM and it made a hoop of torque from down their to 4500 RPM where it started to taper off slowly
Re: Extended flat torque curve [Re: Cab_Burge] #3021305
03/06/22 04:35 PM
03/06/22 04:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Here area few I have online. Not sure what you consider broad and flat but see if these fit the bill. I believe they qualify. We also have one in our dragster that is not really flat but the thing is a torque monster for sure as it peaked at 960 ft/lbs.
This engine was within 56 ft/lbs from beginning of pull up til peak HP, 2300RPM Predator headed race gas 604" sheet metal intake
This one is 25ft/lbs from start til peak HP, 1200rpm. This one is a pump gas 536" deal.
Here is another. 59 ft/lbs from start to peak power, 2100 rpm. 610" Predator with a single 4 cast intake
Re: Extended flat torque curve [Re: hemienvy] #3021338
03/06/22 07:02 PM
03/06/22 07:02 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
446" 14# 112 LSA .631 lift Edl Vic heads std port,2.19" int/1.81"exh 4.35 bore
Re: Extended flat torque curve [Re: Al_Alguire] #3021343
03/06/22 07:10 PM
03/06/22 07:10 PM
So. Burlington, Vt.
So. Burlington, Vt.
Using Al’s criteria of tq variation from the start of the pull up to peak HP.......... the one I posted still fares pretty well.......
41lbs variation over 23 lines on the sheet.
Re: Extended flat torque curve [Re: fast68plymouth] #3021347
03/06/22 07:27 PM
03/06/22 07:27 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Nice results guys ^ Mine is mild but carries some rpm. This is at the wheels through full exhaust to tips with accessories (and steel wheels). I've made some changes since and will update with results but think I can get it in the 615 wheel range.
Re: Extended flat torque curve [Re: INTMD8] #3021359
03/06/22 08:16 PM
03/06/22 08:16 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
The 440 ShortRam motor I built, ( very mild motor) makes 500+ ftlbs from 2500 to 4300, peaks at 543 ftlbs@3800. Motor doesnt make a boatload of hp (429), but it's a great little torque monster.
Re: Extended flat torque curve [Re: quickd100] #3021423
03/07/22 12:34 AM
03/07/22 12:34 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Gents,
Thank you all, the charts don't lie. "Extended torque" is relative I know.
I have an idea about valve sizing. Essentially, bigger engines don't have valve sizes that are proportionately as big as
the valves in smaller engines. The dyno charts are good, could I further ask what heads and valve sizes are in those engines ?
Re: Extended flat torque curve [Re: hemienvy] #3021424
03/07/22 12:36 AM
03/07/22 12:36 AM
New York
polyspheric Offline
polyspheric  Offline
New York
IMHO biggest single source of big dip/spike in torque: strong exhaust wave return at the wrong/right time.
Boffin Emeritus
Re: Extended flat torque curve [Re: polyspheric] #3021426
03/07/22 12:41 AM
03/07/22 12:41 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Poly,
Duration / timing, or exhaust valve size / port flow ?
Re: Extended flat torque curve [Re: hemienvy] #3021446
03/07/22 09:53 AM
03/07/22 09:53 AM
UK
rb446 Offline
rb446  Offline
UK
Originally Posted by hemienvy
Gents,
Indy 572-13 365CNC heads have 2.30/1.88 valves.......
Re: Extended flat torque curve [Re: polyspheric] #3021457
03/07/22 10:49 AM
03/07/22 10:49 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I agree. That dip on my graph 4200-4500 range I think could be fixed with tri-y's.
Re: Extended flat torque curve [Re: hemienvy] #3021490
03/07/22 12:28 PM
03/07/22 12:28 PM
New York
polyspheric Offline
polyspheric  Offline
New York
During OL, slightly off TDC either way depending on symmetrical IO/EC or not
Boffin Emeritus
Re: Extended flat torque curve [Re: hemienvy] #3021536
03/07/22 03:09 PM
03/07/22 03:09 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Two of the ones I posted were Predators as I listed on the post. 2.45/1.84. The middle engine was a 2.30/1.88 B1
Re: Extended flat torque curve [Re: Al_Alguire] #3021795
03/08/22 08:28 AM
03/08/22 08:28 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
OK Thanks All,
Interesting topic, hard to see a pattern but there must be something these engines have in common.
The opposite effect, where the torque curve just drops, seems to be related to too much duration and a smallish intake port.
Where breathing hits it's limit, the torque curve will slope down in a line, and the HP will plateau for a while with increasing RPM.
Maybe a key player in the flat torque curve is an intake port on the small side but that flows really well, a highly raised port.
Anyway thank you.
