Degreeing a cam with asymmetrical lobes #3021560
03/07/22 04:26 PM
03/07/22 04:26 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
What is the best method to use to degree a cam with asymmetrical lobes?
Re: Degreeing a cam with asymmetrical lobes [Re: mopar dave] #3021564
03/07/22 04:48 PM
03/07/22 04:48 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Maybe I'm not understanding the question, wouldn't matching the valve events @.050 still work?
Re: Degreeing a cam with asymmetrical lobes [Re: mopar dave] #3021583
03/07/22 05:55 PM
03/07/22 05:55 PM
AndyF Offline
AndyF  Offline
Follow the mfgs recommendations. You'll get different centerlines depending on where you measure so just follow the instructions. They might tell you to use an 0.050 lift number, or perhaps they'll tell you to use something else. They should know how they want it installed.
BTW - this question sparked a huge debate on the old SpeedTalk board that went on for months. Mike Jones kept telling everyone to shut up and to just follow the mfg instructions but people kept arguing about where the center line is on a non-symmetrical lobe.
Re: Degreeing a cam with asymmetrical lobes [Re: mopar dave] #3021594
03/07/22 06:17 PM
03/07/22 06:17 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Usually take the readings .050 before and after max lift
Re: Degreeing a cam with asymmetrical lobes [Re: mopar dave] #3021595
03/07/22 06:22 PM
03/07/22 06:22 PM
gregsdart Online content
gregsdart  Online Content
Use the cam card numbers, all of them of @ .050. then you will know what you have, and if your measurements vary at all.
Re: Degreeing a cam with asymmetrical lobes [Re: mopar dave] #3021598
03/07/22 06:26 PM
03/07/22 06:26 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I asked this question here about 20 years ago when I tried my first street roller which was visibly
very asymmetric just eyeballing it....the answer was do centerline method the same as anything else.
I predict the answer will be the same, and might even come from the same people as back then.
As a sanity check you can work the numbers both @.050 and @.020 before and after max lift to see if it comes out the same.
Rich H.
Esse Quam Videri
Re: Degreeing a cam with asymmetrical lobes [Re: ZIPPY] #3021601
03/07/22 06:32 PM
03/07/22 06:32 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the safest way is the centerline method, but that doesn't mean the .050" thing won't work. this is time consuming but when i mess with asymmetrical lobes i check seat timing to find out how long the closing ramp is and go from there. centerline method should be fool proof.
Re: Degreeing a cam with asymmetrical lobes [Re: gregsdart] #3021603
03/07/22 06:36 PM
03/07/22 06:36 PM
Mt Morris Michigan
Mt Morris Michigan
My cam card shows open at 30.5 at .050 and I get 29. Cam is installed at 105.25. Closing spec is 58.5 and I get 57 .050 before close. So that is real close. I have a gentleman over on speed talk tell me to use .020 to center the cam with asymmetrical lobes. I am still trying to figure duration at .200 lobe lift. Do I read the wheel for this or is it a math equation? Spec is 190 lobe lift at .200.
Re: Degreeing a cam with asymmetrical lobes [Re: mopar dave] #3021606
03/07/22 06:42 PM
03/07/22 06:42 PM
Mt Morris Michigan
Mt Morris Michigan
Also, bullet says not to use the lifter bore tool for measuring any cam specs. If roller, must use a lifter because of the wheel size. Mine are .810 wheels. Doing this does seem to get more accurate measures.
Re: Degreeing a cam with asymmetrical lobes [Re: mopar dave] #3021631
03/07/22 08:12 PM
03/07/22 08:12 PM
AndyF Offline
AndyF  Offline
For duration at 0.200 you just read the numbers on the wheel as you turn the cam from 0.200 to 0.200. When you go past TDC you need to keep track of what you are doing.
Follow your cam card and ignore the guy on Speedtalk telling you to do something else. You have the cam card, use it. If you don't understand the cam card then call the mfg. People on Speedtalk argue with everything and everybody just for fun.
Re: Degreeing a cam with asymmetrical lobes [Re: mopar dave] #3021634
03/07/22 08:22 PM
03/07/22 08:22 PM
Washington
madscientist Offline
Washington
Isnt your cam installed 2 degrees retarded? If so, the @.050 numbers line up close enough. Lifter bore bank angle and plane errors can move the @.050 numbers around quite a bit.
Send it.
Re: Degreeing a cam with asymmetrical lobes [Re: AndyF] #3021635
03/07/22 08:24 PM
03/07/22 08:24 PM
Mt Morris Michigan
Mt Morris Michigan
Ok, thanks Andy. I will give that a try tomorrow.
Re: Degreeing a cam with asymmetrical lobes [Re: mopar dave] #3021636
03/07/22 08:25 PM
03/07/22 08:25 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
You have to degree off of the events not intake center line
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Degreeing a cam with asymmetrical lobes [Re: madscientist] #3021637
03/07/22 08:26 PM
03/07/22 08:26 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, its close. Just need to check v/p clearance. I am now at truely 105* centerlined. The numbers on the card are very close.
Re: Degreeing a cam with asymmetrical lobes [Re: mopar dave] #3021663
03/07/22 09:19 PM
03/07/22 09:19 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
104
Re: Degreeing a cam with asymmetrical lobes [Re: mopar dave] #3021707
03/07/22 10:40 PM
03/07/22 10:40 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Uh-huh...couldn't agree more...that fancy looking CompCams tool caused me a massive headache as I attempted to degree my mild hydraulic roller. Eventually, degreeing off of an actual roller lifter got me the matching numbers.
Re: Degreeing a cam with asymmetrical lobes [Re: Diplomat360] #3021717
03/07/22 11:07 PM
03/07/22 11:07 PM
NC
440Jim Offline
440Jim  Offline
NC
Don't say "don't use lifter bore tool".
There are different lifter bore tools with different diameters.
I machined my own. My "tool" has a 0.810" dia ball on the end. One man's tool is different than another. And Comp's tool might have small balls...
And I use the 0.050" numbers for discussion. But I have measured the centerline at many lobe lifts for info. It can vary. But 2 degrees either way doesn't mean one number is best for your engines combination.
Re: Degreeing a cam with asymmetrical lobes [Re: 440Jim] #3021803
03/08/22 09:08 AM
03/08/22 09:08 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Just went through this. Measured @.050" open and close. Also C/L @ .070", .050", .030" before max lift. None are quite the same. In fact duration was longer than the card showed. The bottom line is advance it further than you'll ever need and check intake P to V. Retard it to far and measure exhaust P to V. Then stab it in close to where you think it should be, by whatever method you chose. Then when it's up and running you can move it with confidence. You'll never no what's best unless you try different spots.
Doug
Re: Degreeing a cam with asymmetrical lobes [Re: dvw] #3021836
03/08/22 10:37 AM
03/08/22 10:37 AM
Mt Morris Michigan
Mt Morris Michigan
Yes, i will have to see what my clearances are at my current 105* install and go from there.
Re: Degreeing a cam with asymmetrical lobes [Re: CSK] #3021851
03/08/22 11:26 AM
03/08/22 11:26 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Originally Posted by csk
104
It’s okay Charlie....... I know what you’re saying there.
On the other hand, when the VP clearance is marginal....... it may have to be installed wherever it fits.
