Re: Degreeing a cam with asymmetrical lobes
[Re: mopar dave]
#3021564
03/07/22 04:48 PM
03/07/22 04:48 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Maybe I'm not understanding the question, wouldn't matching the valve events @.050 still work?
[Re: mopar dave]
#3021583
03/07/22 05:55 PM
03/07/22 05:55 PM
Posts: 31,060 Oregon
AndyF
What is the best method to use to degree a cam with asymmetrical lobes? Follow the mfgs recommendations. You'll get different centerlines depending on where you measure so just follow the instructions. They might tell you to use an 0.050 lift number, or perhaps they'll tell you to use something else. They should know how they want it installed. BTW - this question sparked a huge debate on the old SpeedTalk board that went on for months. Mike Jones kept telling everyone to shut up and to just follow the mfg instructions but people kept arguing about where the center line is on a non-symmetrical lobe.
[Re: mopar dave]
#3021595
03/07/22 06:22 PM
03/07/22 06:22 PM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
What is the best method to use to degree a cam with asymmetrical lobes? Use the cam card numbers, all of them of @ .050. then you will know what you have, and if your measurements vary at all.
[Re: mopar dave]
#3021598
03/07/22 06:26 PM
03/07/22 06:26 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
I asked this question here about 20 years ago when I tried my first street roller which was visibly very asymmetric just eyeballing it....the answer was do centerline method the same as anything else.
I predict the answer will be the same, and might even come from the same people as back then.
As a sanity check you can work the numbers both @.050 and @.020 before and after max lift to see if it comes out the same.
Rich H.
Esse Quam Videri
[Re: mopar dave]
#3021631
03/07/22 08:12 PM
03/07/22 08:12 PM
AndyF
My cam card shows open at 30.5 at .050 and I get 29. Cam is installed at 105.25. Closing spec is 58.5 and I get 57 .050 before close. So that is real close. I have a gentleman over on speed talk tell me to use .020 to center the cam with asymmetrical lobes. I am still trying to figure duration at .200 lobe lift. Do I read the wheel for this or is it a math equation? Spec is 190 lobe lift at .200. For duration at 0.200 you just read the numbers on the wheel as you turn the cam from 0.200 to 0.200. When you go past TDC you need to keep track of what you are doing. Follow your cam card and ignore the guy on Speedtalk telling you to do something else. You have the cam card, use it. If you don't understand the cam card then call the mfg. People on Speedtalk argue with everything and everybody just for fun.
[Re: mopar dave]
#3021634
03/07/22 08:22 PM
03/07/22 08:22 PM
Posts: 4,457 Washington
madscientist
Washington
My cam card shows open at 30.5 at .050 and I get 29. Cam is installed at 105.25. Closing spec is 58.5 and I get 57 .050 before close. So that is real close. I have a gentleman over on speed talk tell me to use .020 to center the cam with asymmetrical lobes. I am still trying to figure duration at .200 lobe lift. Do I read the wheel for this or is it a math equation? Spec is 190 lobe lift at .200. Isnt your cam installed 2 degrees retarded? If so, the @.050 numbers line up close enough. Lifter bore bank angle and plane errors can move the @.050 numbers around quite a bit. Send it.
[Re: mopar dave]
#3021636
03/07/22 08:25 PM
03/07/22 08:25 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
You have to degree off of the events not intake center line
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: mopar dave]
#3021663
03/07/22 09:19 PM
03/07/22 09:19 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
104
[Re: mopar dave]
#3021707
03/07/22 10:40 PM
03/07/22 10:40 PM
Posts: 1,763 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Also, bullet says not to use the lifter bore tool for measuring any cam specs. If roller, must use a lifter because of the wheel size. Mine are .810 wheels. Doing this does seem to get more accurate measures. Uh-huh...couldn't agree more...that fancy looking CompCams tool caused me a massive headache as I attempted to degree my mild hydraulic roller. Eventually, degreeing off of an actual roller lifter got me the matching numbers.
[Re: Diplomat360]
#3021717
03/07/22 11:07 PM
03/07/22 11:07 PM
Posts: 16,928 NC
440Jim
NC
Also, bullet says not to use the lifter bore tool for measuring any cam specs. If roller, must use a lifter because of the wheel size. Mine are .810 wheels. Doing this does seem to get more accurate measures. Uh-huh...couldn't agree more...that fancy looking CompCams tool caused me a massive headache as I attempted to degree my mild hydraulic roller. Eventually, degreeing off of an actual roller lifter got me the matching numbers. Don't say "don't use lifter bore tool". There are different lifter bore tools with different diameters. I machined my own. My "tool" has a 0.810" dia ball on the end. One man's tool is different than another. And Comp's tool might have small balls... And I use the 0.050" numbers for discussion. But I have measured the centerline at many lobe lifts for info. It can vary. But 2 degrees either way doesn't mean one number is best for your engines combination.
[Re: CSK]
#3021851
03/08/22 11:26 AM
03/08/22 11:26 AM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It’s okay Charlie....... I know what you’re saying there. On the other hand, when the VP clearance is marginal....... it may have to be installed wherever it fits.
