Re: Cal trac copy traction bars
[Re: Otherlane]
#3021162
03/05/22 11:20 PM
03/05/22 11:20 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
That is correct. I have used the real ones for 20 years and the ones you linked look and probably function exactly the same. But, do they have the same quality rod ends and tubing? Don't know.
In my first response I was suggesting that they may not be available for long.
[Re: Cab_Burge]
#3021172
03/06/22 12:36 AM
03/06/22 12:36 AM
Posts: 8,346 fredericksburg,va
cudaman1969
fredericksburg,va
I can’t see where they would be so life threatening, they push the heim joints and they are or could be the weak link. Are the welds good? If not 1/4” steel that would be the only other problem. Basically the Chinese could make them identical to Calverts but pay the guy making them $2.50 to sell them that cheap and still make a tidy profit. The Chinese have good machinery they just don’t have to pay union wages
[Re: cudaman1969]
#3021191
03/06/22 07:50 AM
03/06/22 07:50 AM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
I can’t see where they would be so life threatening, they push the heim joints and they are or could be the weak link. Are the welds good? If not 1/4” steel that would be the only other problem. Basically the Chinese could make them identical to Calverts but pay the guy making them $2.50 to sell them that cheap and still make a tidy profit. The Chinese have good machinery they just don’t have to pay union wages If the front mount, or the front heim breaks, and the front of the bar drops down, you have an incredibly dangerous scenario. Is that any more likely than a real caltrac setup? I don’t know.
[Re: Pacnorthcuda]
#3021201
03/06/22 09:49 AM
03/06/22 09:49 AM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
$ 265 or $389, 124$ difference, NO WAY would I get the cheaper copies
[Re: CSK]
#3021219
03/06/22 10:53 AM
03/06/22 10:53 AM
Posts: 16,162 Mesa, Arizona
dart4forte
Mesa, Arizona
The company is out of Texas. They build to order.
Abe Lincoln
[Re: Pacnorthcuda]
#3021232
03/06/22 11:52 AM
03/06/22 11:52 AM
Posts: 15,513 Omaha Ne
TJP
Omaha Ne
Basically the Chinese could make them identical to Calverts but pay the guy making them $2.50 to sell them that cheap and still make a tidy profit. The Chinese have good machinery they just don’t have to pay union wages If the front mount, or the front heim breaks, and the front of the bar drops down, you have an incredibly dangerous scenario. Is that any more likely than a real caltrac setup? I don’t know. NO offense meant to you but peoples thinking on the "cheaper" chinese product is exactly what has gotten this country in a position the be dependent on them. Now consider their ties to Russia and the current situation ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) And should any part of that system break during launch or hard acceleration you now have a siutuion where the vehicle may unexpectedly make a hard right or left ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: dart4forte]
#3021235
03/06/22 11:59 AM
03/06/22 11:59 AM
CSK
Pattison Texas
The company is out of Texas. They build to order. The Ebay info say Location China
[Re: CSK]
#3021253
03/06/22 12:57 PM
03/06/22 12:57 PM
Posts: 6,323 nowhere
Sniper
nowhere
The company is out of Texas. They build to order. The Ebay info say Location China Location of SELLER is China, per SELLER information, though to be honest I doubt they are selling US made product from a China location. The actual AD itself says NJ. Not sure where TX came into play.
[Re: 340Cuda]
#3021263
03/06/22 01:18 PM
03/06/22 01:18 PM
Posts: 20,211 Park Forest, IL
slantzilla
Park Forest, IL
The extra money for the Calvert's would be well worth the great support. THIS /\ I've had a set for years. The help they gave setting them up was invaluable. Also, I ordered the wrong size eye bushing, my fault. They sent me the right ones for free.
[Re: Otherlane]
#3021282
03/06/22 02:43 PM
03/06/22 02:43 PM
slantzilla
Park Forest, IL
Not cracking wise, but if it's a street car, save even more and get a cheap pair of Lakewood bolt on slapper bars. They will work just as well.
[Re: Pacnorthcuda]
#3021284
03/06/22 02:49 PM
03/06/22 02:49 PM
cudaman1969
fredericksburg,va
I can’t see where they would be so life threatening, they push the heim joints and they are or could be the weak link. Are the welds good? If not 1/4” steel that would be the only other problem. Basically the Chinese could make them identical to Calverts but pay the guy making them $2.50 to sell them that cheap and still make a tidy profit. The Chinese have good machinery they just don’t have to pay union wages If the front mount, or the front heim breaks, and the front of the bar drops down, you have an incredibly dangerous scenario. Is that any more likely than a real caltrac setup? I don’t know. The front eye of spring is still attached in same place, no where to go but bars still being attached on other side would give a dangerous ride. If bubble gum welds be wary. Both heims and tube are in compression, not stretching, solid joints would work fine. The two areas of my concern are the struts on u-bolt plate and the tube in front that pulls down on spring.
[Re: cudaman1969]
#3021337
03/06/22 06:59 PM
03/06/22 06:59 PM
Posts: 4,704 Wichita
GY3
Wichita
We made our own after a friend bought a set. Really the only thing we copied directly was the pivot. It's pretty easy to make the rest with tubing, spacers, flat stock and heim ends. We have less than $100 in materials in them.
I do have Calvert split mono springs and, up to last year ran their single adjustable shock.
It's not rocket science. Lots of other products out there with their own take on this. The Assassin bars are just one example.
They do work well as we've been 1.36 60 ft. with a 275 drag radial and 3,700 lbs. street car.
[Re: GY3]
#3021345
03/06/22 07:16 PM
03/06/22 07:16 PM
GY3
Wichita
Pics of us putting them together...
