Re: Mega block 528 - plugs - nitrous - Questions
[Re: n20mstr]
#3022315
03/09/22 01:27 PM
03/09/22 01:27 PM
Posts: 154 Canada
cuda499
Canada
I dont want to start any arguments or conflicts....leakdown is useless on a nitrous engine. you have to do compression test.
Block the carb open, take all the plugs out. Then compression test it, record the first pump then what it does after 5-6 pumps. for reference, my engine pumps 90 then goes to 130 after 6 pumps. (YES this is what i mean, nitrous cams that open the exh early give compression results like this)
This is also my routine maintenance, after every race i check the valve lash, the valve spring seat pressure, and compression test.
Leak down can fool you , compression test never lies.
Your "black" plugs could be from a lot of issues....if there is that much oil pumping the thing should be smoking like crazy...i would start with a compression test 100% the exact same thing I do. I do a compression test, record 1st and 5th pump when engine is new. I use this is a guide on general health on the engine. When i get a compression test that is off, i will pull my leak down tester to see where i should be looking..... Can i hear the air coming out the exhaust, intake or crank case, and that is all i will use it for. Have seen a lot of people chase there tail because there leak down test wasn't good on a cold alum engine.
[Re: sixtycycle]
#3022321
03/09/22 01:44 PM
03/09/22 01:44 PM
Posts: 4,745 On the parachute mount
n20mstr
So how are you seeing the pan vac? external analog gauge or using a sensor for input to a box or..?
I did see a guy saying You need MSD part no 7762, some 1/4 pushlock tubing and you'll be fixed right up. He says that he uses anytime he runs his car. It records in psi, and you just need to convert that to inhg. He just uses it to watch my vacuum trace for detonation. Once it's powered up it starts watching the sensor, you don't need to do anything special to make it work other than make sure the retard function is disabled, unless you want to use it, but it's referenced off of boost.
Do you have a way you do yours? And where should the measurement be taken from I have Holley EFI and a Racepak. I also have a vac guage in the car. Usually you use a 1 bar map sensor to datalog the vacum. My valley tray is tapped for the vacum source . 1/8 pipe thread and i use -4 line for the best leak free connection. You can use pushlok also. I know it is possible to log the vac with an MSD grid , but im sorry i cant tell you how.
....BAD A$$ STREET CAR.....
[Re: sixtycycle]
#3022352
03/09/22 02:45 PM
03/09/22 02:45 PM
n20mstr
Ok cool I will follow the same for the compression test. thanks to both you, So I can just Tap 1/8” npt anywhere on valley and convert to a -4 to say a Moroso Analog gauge for now? What kind of readings should I see during idle, during a run etc. what’s the good and bad spectrum? Sure you can plumb a gauge in the driver comp with -4 or -3 or pushlok. WHat vac should you see....hard to say, what your looking for is that it doesnt drop severly during a pass. It can be 5-7 at idle and 10-15 during a pass. Or it can be higher or lower, what your really looking for is consistent readings.....when the vacum decreases your losing ring seal or have a leak somewhere else ( valve cover, timing cover pan gasket etc) The reading while making a pass is whats important. Especially for a nitrous engine, its the best indication of how well the rings are sealed up
[Re: n20mstr]
#3022363
03/09/22 03:02 PM
03/09/22 03:02 PM
Posts: 19,538 Las Vegas
Al_Alguire
Las Vegas
Lots of good advice here. A vacuum gauge in the car is the best way to monitor and engines health. While its great to note oil pressure as we all know you can loose rod bearings and never see oil pressure waiver . If you start loosing vacuum you have some issues.
Those plugs look like HELL why is the question, I agree start with a compression test and then if you must follow up with a leakdown. FWIW 8% on a cold engine is pretty damn good, but it dont mean a lot without the compression test, especially at 8%. AS bad as those plugs appear(looks like oil but pictures can be deceiving I suppose) I would be digging a bit deeper. If its got valve seal issue and was started up and shut off a few times they could get ugly quick, especially depending on heat range. But oil and nitrous dont play well together so I would definitely want to get handle on it.
[Re: Al_Alguire]
#3022366
03/09/22 03:19 PM
03/09/22 03:19 PM
Posts: 13,495 Marion, South Carolina [><]
an8sec70cuda
Those plugs look like crap, but they're what I'd expect to see from a big inch nitrous motor idling around on really cold plugs w/ a crap vacuum pump. Aerospace Components pumps are the worst on the market. FWIW...I know a lot of guys that don't use any valve seals on their race engines. I always use at least intake seals.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: sixtycycle]
#3022398
03/09/22 04:40 PM
03/09/22 04:40 PM
Al_Alguire
Las Vegas
Certainly lots of race engine without valve seals out there. Not sure I would go that way with a nitrous deal. Oil will promote detonation, never a good thing but worse on the bottle for sure.
As for the vacuum pump I would use something better. Hard to beat a Moroso 3 vane an no regulator IMO for most. Moroso 4 vane is better and Star would be the top if you are looking for maximum vacuum.
[Re: sixtycycle]
#3022609
03/10/22 12:40 PM
03/10/22 12:40 PM
Al_Alguire
Las Vegas
You can leak down the remaining cylinders now, just to record the number for future reference. #^ is a tad lower than the rest but nothing alarming. I woudl be more alarmed by the actual number period more than one cylinder being a bit lower than the others. But not knowing you cam specs or compression who knows. Just seem to be a bit low on pumping overall to me. But again lots of things can make that change.
Put some plugs in it, see if she smokes when you fire it up(valve seals leaking/missing)and then let her rip tater chip.
[Re: Al_Alguire]
#3022633
03/10/22 01:47 PM
03/10/22 01:47 PM
n20mstr
Put some plugs in it, see if she smokes when you fire it up(valve seals leaking/missing)and then let her rip tater chip. Al, my current engine will pump 90-95 on the first pump and then 140-145 after 5-6 pumps. The compression is 13.7 but the cam is WAYYY different than the one shown in the post above. The readings are pretty consistent, i would say the engine is healthy as long as it has some decent pan vac, while making a nitrous pass
[Re: sixtycycle]
#3022669
03/10/22 03:58 PM
03/10/22 03:58 PM
n20mstr
Ok thank you, Can you elaborate on your cam compares to mine im sorry but im not going to put my cam card on here, no reason to. BUT its nitrous specific and its a lot bigger.
[Re: n20mstr]
#3022675
03/10/22 04:27 PM
03/10/22 04:27 PM
Posts: 36 FL
sixtycycle
FL
No problem man I wasn't looking for specifics, just wanted to know how to relate to your answer I appreciate it thank you. I'm not to worried about sharing my stuff just want to ensure I'm getting anything fixed up that I need to is all. I doubt I run into anything other than a grudge race here and there. I'll get the pan vac installed to and see what it says and hopefully I can finally get to go play barring the rest of the leak down, r still seeing oil on the new set of plugs. Which I'm changing to hotter plugs to do a couple of motor pulls
[Re: Cab_Burge]
#3022941
03/11/22 02:52 PM
03/11/22 02:52 PM
Posts: 36 FL
sixtycycle
FL
Will do Cab, I'll look when I get home this afternoon, thank you. Here's what I could get done last night on the leak down test, an out of time for the last two...
COMPRESSION TEST CYLINDER 1 BUMP 5 BUMPS CONDITIONS 1 100 195 cold 3 100 190 cold 5 100 190 cold 7 100 195 cold 2 95 195 cold 4 95 190 cold 6 95 185 cold 8 98 194 cold
LEAK DOWN TEST INPUT PSI CYLINDER PSI CONDITIONS 1 100 88 cold 3 100 86 cold 5 100 86 cold 7 100 92 cold 2 100 89 cold 4 100 86 cold 6 100 cold still need to test 8 100 cold still need to test
