Re: Mega block 528 - plugs - nitrous - Questions
[Re: sixtycycle]
#3019012
02/26/22 09:34 AM
02/26/22 09:34 AM
Posts: 4,682 On the parachute mount
n20mstr
The most important thing with your combination is what was the timing ? Especially when using nitrous. 440-1 are not nitrous friendly , at least not at the 300 up level , so they may have taken more timing out than usual. Lots of variables here as far as quench , cam specs , chamber shape , to give recommendations on tuning . At least as far as your nitrous goes . On motor alone you can probably run a hotter plug . As with most nitrous engines being Conservative on timing will go a long ways , also don’t let it get too fat or too lean as both can hurt parts .
Yes you can certainly run the -9 plug for motor pulls . Yes it can be .025 -.030 gap . When I use nitrous I run the -10 plug at .025 and I use a lot more than 300hp
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3019049
02/26/22 11:16 AM
02/26/22 11:16 AM
Posts: 4,071 Mo.
racerx
Mo.
Not meaning to jack the op's thread, but what can of HP can he expect by going to a hotter plug in his (natural aspirated ) -1 heads?
[Re: sixtycycle]
#3019146
02/26/22 05:25 PM
02/26/22 05:25 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
Your way safer using 34 degrees BTDC total timing on race gas is what I have learn doing max tuning in the 1/4 mile on ET or MPH if the race gas is more than 30 days old after opening the can use it in some other vehicle with less compression, all gasoline starts losing octane when expose to our atmosphere, all of them E85 and straight methanol don't devil scope: : up: They are both way safer to use when racing also: up: Without knowing the compression ratio and quality of the gas being used it is impossible to give you the correct heat range to use, sorry If those #10 NGK stay clean and don't foul out at light part throttle driving use them: up:: two cents: If they do get real black and ugly looking, try a NGK #7 or #8 next The # 8 would be safer than the #7 but both may work better on the street than the #10 NGK
[Re: sixtycycle]
#3019274
02/27/22 12:22 AM
02/27/22 12:22 AM
Cab_Burge
[Re: sixtycycle]
#3019451
02/27/22 05:11 PM
02/27/22 05:11 PM
Cab_Burge
If it stinks it is to rich, unlike women AKA aside use the idle mixture screws to lean it out If you can't get it done that way you can enlarge the idle air bleeds on the top of the carb. but you need to have a pin vise and good selection of very small drill bits.. Can you take the carb off and flip it over after draining all the gas out of the fuel bowl first and see if the primary and secondary throttle blades are exposing the transition slots in the middle of the throttle plate? If so do that now first and if they are exposed use the idle speed screws to close them enough so they don't expose the transition:: up:
[Re: sixtycycle]
#3019614
02/28/22 10:02 AM
02/28/22 10:02 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
The -10 plugs will be good for the nitrous, but are cold for street driving. I'd use a -8 for any street driving or naturally aspirated runs.
FWIW...I use -8s gapped around .035" in my 11:1 hemi on 93 octane pump gas, but use -10 plugs gapped around .025" for 300 hp nitrous passes w/ Renegade Pro 120 nitrous fuel.
