Re: another dominator question [Re: Quicktree] #301880
04/28/09 09:44 PM
04/28/09 09:44 PM
hudson valley n.y.
GEORGE68HEMIRR Offline OP
super street
super street
hudson valley n.y.
I don't think you can control pressure with that pump by-passing it at the pump. pm robbmc (board member) and talk to him about it and your problem.
like i said this pump and fuel system i have been using for years without any problems
Re: another dominator question [Re: 602heavy] #301881
04/28/09 09:47 PM
04/28/09 09:47 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
Maybe the fuels boiling in the bowls , seems like the only thing that's changed is temp.
thats what i am wondering also...the temp seems high but not overheating.....is this water wetter any good?....it ran cooler on anti-freeze
Re: another dominator question [Re: GEORGE68HEMIRR] #301882
04/28/09 10:21 PM
04/28/09 10:21 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
are we talking about dual doms or just one? on what intake?
are you saying the flooding problem out of the vent is fixed now and you just have a stumble?
Re: another dominator question [Re: sixpackgut] #301883
04/28/09 10:34 PM
04/28/09 10:34 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
yes dual 1050 dominators on a indy tunnel ram.....it doesnt seem to be dumping out the vents[have a bds scoop on and didnt see gas running out the back like i did before/ was at nite on the road....but it is stumbling like its shutting down and did die....seemed flooded....had to floor it to clear it up and started after a minute or so
Re: another dominator question [Re: GEORGE68HEMIRR] #301884
04/28/09 10:43 PM
04/28/09 10:43 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
hard to say its the heat then. i think its a check valve under a squirter thats causing the problem.
a blown power valve will let gas drip down the vac port hole and flood the engine but you would notice that cruising
Re: another dominator question [Re: sixpackgut] #301885
04/28/09 11:12 PM
04/28/09 11:12 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
earlier today when the gas was gushing out the vents i noticed gas coming out the primary squirter like its was boiling...it would squirt then stop then did it like 4-5 times....engine was off and everything was shut down when it was doing it.......it was 90 degrees here today.....the power valves are brand new....just put them in today....no back fires either.....just stumbing as i am jumping into it.....then it takes off.....what i dont get is after driving it....shut it off for about 10 minutes.....started up fine and jumped into it and died after 100 feet
Re: another dominator question [Re: GEORGE68HEMIRR] #301886
04/28/09 11:29 PM
04/28/09 11:29 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
well that sounds like fuel boiling problem but the carbs that high off the engine, i dont know. could be the way fuel lines are routed. everyone is complaining about this issue lately but i had that issue a long time ago, solved the problem with a return style regulator
you will hear the fuel perculating in the bowls, there is not mistaking it. its loud enough to hear clearly but just a good old fashion carb rebuild is what i think it may need. umbrella plunger in the pump housing is another possible problem
Re: another dominator question [Re: GEORGE68HEMIRR] #301887
04/28/09 11:39 PM
04/28/09 11:39 PM
Sounds like you have a bad tank of gasoline, it is boiling and trying to vapor lock,IMO
Re: another dominator question [Re: Cab_Burge] #301888
04/28/09 11:48 PM
04/28/09 11:48 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
wow i never thought of that.....i will change that tomorrow.....you really think so.....its mobil..93
Re: another dominator question [Re: sixpackgut] #301889
04/28/09 11:53 PM
04/28/09 11:53 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
i will change them and the gas tomorrow....thanks....i will keep everyone posted.....we rented lebanon valley friday so i am hoping to get this done before friday....cutting it close
Re: another dominator question [Re: GEORGE68HEMIRR] #301890
04/29/09 12:03 AM
04/29/09 12:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Another problem is the fuel at this time of year,
if its been real warm there(ambient temps) you
probably still get winter fuel which can be as high
as 15 RVP and it tends to boil REAL easy in heat.
Summer fuel is closer to 8-9 RVP (RVP is Reid Vapor
Pressure) the higher the number the more pressure
it builds alone with easy boiling, the high vapor
is made to generate vapor easier for cold winter
starting/running
Re: another dominator question [Re: MR_P_BODY] #301891
04/29/09 12:10 AM
04/29/09 12:10 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
starting/running
wow thats interesting....now would the gas station attend know what RVP/winter/summer blend.they have??this is really something i never knew....thanks for that.....i am never to old to learn something
Re: another dominator question [Re: GEORGE68HEMIRR] #301892
04/29/09 12:17 AM
04/29/09 12:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The problem is... they dont know, the company will
determine when its time(usually a calender month)
to make the change over... with us up north here it
is usually in April but if they arent moving alot
of fuel that could still be in the in ground tanks
Re: another dominator question [Re: MR_P_BODY] #301893
04/29/09 12:26 AM
04/29/09 12:26 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
so i guess i would have to ask when they got there last delievery and maybe its a summer blend since it been in the 90s since saturday...what happened to spring??....thank you
Re: another dominator question [Re: GEORGE68HEMIRR] #301894
04/29/09 08:36 AM
04/29/09 08:36 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
well let me see what happens today since its 50* today and yesterday was 90*
Re: another dominator question [Re: GEORGE68HEMIRR] #301895
04/29/09 11:22 AM
04/29/09 11:22 AM
Well It is odd that the rear carb front fuel bowl is the only one acting up
Re: another dominator question [Re: Cab_Burge] #301896
04/29/09 12:07 PM
04/29/09 12:07 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
no both carbs were acting up that last time she dump fuel out both primary vents
now with it cooler it ran at 165/170 degrees before i added some differant fuel its running great with no problems.......must have been the winter blend and the cooler temps.....great!!!!
