Page 2 of 3 1 2 3
Re: Automatic Trans Holding Fixture [Re: MoParFish] #2423678
12/25/17 04:57 PM
12/25/17 04:57 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Originally Posted By MoParFish
Nuttin' fancy here. Hole drilled in edge of bench with a screwdriver dropped thru bell hole. Has worked ok for as many as I mess with but, might make something better next time around. Santa
Is the screw driver from Harbor Freight?
Tony
70 AARCuda Vitamin C
Re: Automatic Trans Holding Fixture [Re: Bad340fish] #2423723
12/25/17 07:47 PM
12/25/17 07:47 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Once it's ready for the guts, Nothing more than a 15? gallon drum (parts cleaner drum) goes together better being vertical.
Re: Automatic Trans Holding Fixture [Re: Bad340fish] #2423823
12/26/17 01:18 AM
12/26/17 01:18 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Blue Point bench mule I bought from Snappy years ago. Has had transmissions and rears on it over the years. It's paid for itself a few times over.
Re: Automatic Trans Holding Fixture [Re: cudaman1969] #2423844
12/26/17 09:19 AM
12/26/17 09:19 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Lol...I thought I was the only one...and I wasn't going to admit it...I don't do them often but I use one for disassembly and the reassembly, I do like the engine stand adapter idea though...right after I finish my engine run in stand I may build one of those...ha...who am I kidding, I can't seem to keep other people's projects out of my shop... work
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Automatic Trans Holding Fixture [Re: longram60] #2424198
12/26/17 11:34 PM
12/26/17 11:34 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
Originally Posted By longram60
I use a similar set-up with my engine stand, bur with a C shaped angle iron fixture bolted to the face of the tranny (I'll post a pic when I get home)
Originally Posted By gregsdart
I made up some arms to bolt to an engine stand and the tabs on the torqueflite case. Took about an hour to make them out of scrap I had in the shop. Works great.
I had some 2x2 tubing and 1/2 x 1 bar stock. I cut four pieces of bar stock to 4 1/2 inch long, drilled a 7/16 hole in one end of each close enough to the end to seat properly on the transmission tabs, and welded them onto the 2x2 x 8 inch long pieces of tubing, with the holes extending out on opposite ends. That allows a lot of adjustability for mounting the trans case.
Picture of mine:
1979 AMC Spirit, NHRA Q/SA
Re: Automatic Trans Holding Fixture [Re: Bad340fish] #2424230
12/27/17 12:45 AM
12/27/17 12:45 AM
CA
crackedback Offline
crackedback  Offline
CA
Best one ever was the wheelbarrow...
Maybe a B Body Bob special
Re: Automatic Trans Holding Fixture [Re: crackedback] #2424381
12/27/17 01:24 PM
12/27/17 01:24 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Just a couple of gusseted angle brackets, did about a dozen tranny's over 20+ years. I know that some cut the lugs off.
Re: Automatic Trans Holding Fixture [Re: B1MAXX] #2424548
12/27/17 06:01 PM
12/27/17 06:01 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: Automatic Trans Holding Fixture [Re: pittsburghracer] #3017898
02/22/22 10:27 PM
02/22/22 10:27 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
pics
Re: Automatic Trans Holding Fixture [Re: B1MAXX] #3017907
02/22/22 11:57 PM
02/22/22 11:57 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Not the greatest pictures, but I stole them from the ProTrans Facebook page ages ago.
Alan Jones
Re: Automatic Trans Holding Fixture [Re: LA360] #3017909
02/23/22 12:19 AM
02/23/22 12:19 AM
AndyF Offline
AndyF  Offline
I have several different tools for holding 727 transmissions. Here is one of the 2nd gen tools that I built.
Re: Automatic Trans Holding Fixture [Re: AndyF] #3017942
02/23/22 07:50 AM
02/23/22 07:50 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
With the pivot point so far off center of mass, I would think that could make rotation take a little more effort, or get away from you if your not careful.
Re: Automatic Trans Holding Fixture [Re: B1MAXX] #3017943
02/23/22 07:59 AM
02/23/22 07:59 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I like this setup up nice and simple B1maxx was this something you fab. up?
Re: Automatic Trans Holding Fixture [Re: John_Kunkel] #3017952
02/23/22 08:58 AM
02/23/22 08:58 AM
NC
440Jim Offline
440Jim  Offline
NC
I used one like John Kunkel's for years. It gets the job done simply. Mine had the rear supports go to the factory rear lugs and bolted.
I later made this one with the Mopar BB and SB bellhousing holes. It is nice to be able to either have the pan side up, or rotate to have the tailshaft end down.
Re: Automatic Trans Holding Fixture [Re: 440Jim] #3017953
02/23/22 09:06 AM
02/23/22 09:06 AM
NC
440Jim Offline
440Jim  Offline
NC
For my 1st PowerGlide, I just welded some angle iron that bolts to my steel bench.
jI do some work with the pan side up just laying on the bench. Then for final assembly, put it vertical.
Re: Automatic Trans Holding Fixture [Re: B1MAXX] #3017980
02/23/22 10:45 AM
02/23/22 10:45 AM
AndyF Offline
AndyF  Offline
The pivot is in the center, you just can't see it since it is on the other side.
Re: Automatic Trans Holding Fixture [Re: Bad340fish] #3017998
02/23/22 11:41 AM
02/23/22 11:41 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Originally Posted by Bad340fish
What is everyone using to hold an automatic transmission while working on them? Trans rebuilding is something I haven't done yet and I think I need to start. Something cheap but safe would be ideal. Also any tool suggestions would be great. Thanks for any input.
Hey Clark, here is the proper "Fixture" for a 727. LOL!!!
69 GTX 68 Road Runner
Re: Automatic Trans Holding Fixture [Re: AndyF] #3018001
02/23/22 11:43 AM
02/23/22 11:43 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
OK thanks for explaining.
Re: Automatic Trans Holding Fixture [Re: racerx] #3018004
02/23/22 11:45 AM
02/23/22 11:45 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Yes just cut up some angle I had around., and some gussets.
Re: Automatic Trans Holding Fixture [Re: hemi-itis] #3018005
02/23/22 11:45 AM
02/23/22 11:45 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Originally Posted by hemi-itis
I'm a simple guy and luckily don't deal with it to often whistling
Your bench looks like mine right now, Van overdrive trans. Been thinking of making one to fit on an engine stand sideways, able to spin it and when done set it on the trans jack (they are heavier now a days)
Just like BMaxx nice!
Page 2 of 3 1 2 3
