Re: Are there any automobile/truck MANUAL trans with ATF OE.
[Re: a12rag]
#3017891
02/22/22 11:05 PM
02/22/22 11:05 PM
Posts: 1,757 Phila
PhillyRag
Phila
The 4spd OD unit in my 76 RoadRunner, had ATF in it . . . when I got it rebuilt, that's what went back into it . . . and according to FSM - "DEXRON" Type Automatic Transmission Fluid . . . They were more concerned about hard shifting (complaints) during cold weather then long term durability (past any warranty times then).
[Re: greendart408]
#3017991
02/23/22 12:19 PM
02/23/22 12:19 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
It's very easy to tell which 833 I've rebuilt over the years had ATF and which didn't , the atf filled trans have a groove worn from the roller bearings on the cluster gear pin .
I never use atf in an 833
[Re: PhillyRag]
#3018027
02/23/22 01:50 PM
02/23/22 01:50 PM
Posts: 26,000 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I mean... have you had your head in a hole in the ground :P? I think at this point most manwells use ATF, every tremec has since the T5, so every modern muscle car with a 6 speed uses atf... Well how about ATF in the rear axle of a 8-3/4? After all; it has gears very like an a-833. Both are reduction type setups. Uh-uh, hypoid gears differ because of the wiping action as the gears mesh; they need a special lube.
[Re: John_Kunkel]
#3018321
02/24/22 01:41 AM
02/24/22 01:41 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
I have to agree, the best a833 I ever took apart was a 73 340 one owner 80,000 miles. I only put thrust washers, and needles kit in it in it, pin was unworn with atf, input and output bearings were tighter than the new ones in the kit, but it was always kept full. My own 40k mile hemi 4-speed with gear oil thick probably 140...bearings are good, mainshaft is the best I have ever seen, pin is worn .002 but no pitting, even the thrust washers could be reused. I have only been in 75-100 4-speed but the atf ones have been better, hemi 4-speeds a little worse, overdrive with atf are usually pretty bad. The countershaft on needles is just a bad design for overdrive, gl4 gear oil, a magnet and change it a lot for those. Just what I have seen. Maybe some pins are soft who knows but I have seen enough to not blame oil 100%.
[Re: John_Kunkel]
#3018330
02/24/22 02:47 AM
02/24/22 02:47 AM
Posts: 1,757 Phila
PhillyRag
Phila
I mean... have you had your head in a hole in the ground :P? I think at this point most manwells use ATF, every tremec has since the T5, so every modern muscle car with a 6 speed uses atf... Well how about ATF in the rear axle of a 8-3/4? After all; it has gears very like an a-833. Both are reduction type setups. Uh-uh, hypoid gears differ because of the wiping action as the gears mesh; they need a special lube. Uh-uh: while not hypoid, same basic geometry on the a833 gears. ATF serves as both a lubricant & hydraulic fluid, while gear oil doesn't. Again: Chrysler changed NOT solely because functions the same, but rather by customer complaints.
