Hemi Exhaust Flanges #3015954
02/16/22 12:26 PM
02/16/22 12:26 PM
fury4speed Offline OP
Where can I buy just the two bolt exhaust flanges that hold the exhaust pipe to the exhaust manifold on a 426 Hemi , thanks
Re: Hemi Exhaust Flanges [Re: fury4speed] #3016015
02/16/22 02:24 PM
02/16/22 02:24 PM
Cab_Burge Online work
Cab_Burge  Online Work
Google it work scope try Where to buy exhaust pipe flanges scope up
Re: Hemi Exhaust Flanges [Re: Cab_Burge] #3016039
02/16/22 03:30 PM
02/16/22 03:30 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
napa has them in walker book by size, bolt center to center and hole diameter, they also sell a split one
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Hemi Exhaust Flanges [Re: fury4speed] #3016043
02/16/22 03:37 PM
02/16/22 03:37 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Rich H.
Esse Quam Videri
Re: Hemi Exhaust Flanges [Re: fury4speed] #3016087
02/16/22 05:51 PM
02/16/22 05:51 PM
A727Tflite Offline
A727Tflite  Offline
Are you building a system or ?
The factory flange is captured on the pipe.
Re: Hemi Exhaust Flanges [Re: A727Tflite] #3016106
02/16/22 06:44 PM
02/16/22 06:44 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Walker #31311. Same flange both sides. I'm not sure if Walker still has these, but they are out of my old Walker book. NAPA exhaust IS Walker, so these #'s will reflect the NAPA #'s too.
I just looked online - looks like these are available almost everywhere. They are a 2-hole flange.
EDIT: 31311 is a GASKET, NOT the flange! That being said, I was able to look up the dimensions: opening is 2-7/16", & center-to-center of the bolt holes = 3-29/32". When I look into the gasket & flange usage chart at the back of the catalog, the gasket does not show a corresponding flange. I'm still looking so stay tuned. Looking in my ROL catalog next.
OK, looks like these two ROL #'s should work - these are FLANGES: Type 7 style (2-hole flange) - SF69023 - it's 3-29/32 center-to-center, & 2.5" hole, but 5/16" thick. Next one looks better: Type 7, part# SF66045, 3-7/8" center/center holes are oblong, opening is 2-9/16" & this one is beefier 3/8" plate.
OK - more options (this is growing isn't it?): Since ROL may be out of business, I'm in a Goerlichs (AP Exhaust now) installer catalog. Here's a NICE-looking stamped & contoured flange: #9164. See diagram. Dimension A = 2-9/16". Dimension B = 3-15/16".
Re: Hemi Exhaust Flanges [Re: Sunroofcuda] #3016250
02/17/22 11:04 AM
02/17/22 11:04 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Should be readily available since there are companies that make full systems . Maybe try calling TTi and see if they'll sell you the flanges ?
Re: Hemi Exhaust Flanges [Re: JohnRR] #3016275
02/17/22 12:54 PM
02/17/22 12:54 PM
Thanks for all the detailed info , much appreciated
