Re: Cold fuel
[Re: racerx]
#3016047
02/16/22 03:42 PM
02/16/22 03:42 PM
Posts: 1,613 westerly, ri. usa
440lebaron
westerly, ri. usa
put the dry ice in a sealed baggie??? might be hard to handle, liquid nitrogen for cooking???, might be able to do the same with regular ice, never thought of it
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: Cold fuel
[Re: 440lebaron]
#3016066
02/16/22 04:37 PM
02/16/22 04:37 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
put the dry ice in a sealed baggie??? might be hard to handle, liquid nitrogen for cooking???, might be able to do the same with regular ice, never thought of it You cant put dry ice in a bag, well you could, but the dry ice will sublimate and blow the bag up. The carbon dioxide gas has to go somewhere.
Re: Cold fuel
[Re: Dodgeguy101]
#3016083
02/16/22 05:30 PM
02/16/22 05:30 PM
440lebaron
westerly, ri. usa
does dry ice evaporate or turn into water?
Re: Cold fuel
[Re: racerx]
#3016152
02/16/22 08:58 PM
02/16/22 08:58 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
put the dry ice in a sealed baggie??? might be hard to handle, liquid nitrogen for cooking???, might be able to do the same with regular ice, never thought of it I thought bout this with regular ice but how would you control the condensation from ice melt contaminating the fuel? Huh? A cool can is like a chemistry or distillation still, coiled fuel line within a can that allows water or dry ice to cool it, there is no mixing of fuel with anything.
Re: Cold fuel
[Re: racerx]
#3016153
02/16/22 08:58 PM
02/16/22 08:58 PM
Posts: 8,048 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I ran one on the street back in the early 80’s. A Moroso, the fuel line is coiled around the circumference of the can. Regular ice melts way too fast. Dry ice is what you want. Walmart sells dry ice.
Re: Cold fuel
[Re: racerx]
#3016163
02/16/22 09:32 PM
02/16/22 09:32 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
Engine masters did a dyno test on cold intakes, cold fuel & it picked up power with very cold fuel
Re: Cold fuel
[Re: hemienvy]
#3016176
02/16/22 10:44 PM
02/16/22 10:44 PM
Posts: 43,373 Bend,OR USA
Cab_Burge
I
I have heard of bracket racers going through a gallon and a half of fuel in one run. There is no way all that fuel is burning. What type of fuel?
Re: Cold fuel
[Re: Cab_Burge]
#3016196
02/17/22 12:48 AM
02/17/22 12:48 AM
Posts: 11,832 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I
I have heard of bracket racers going through a gallon and a half of fuel in one run. There is no way all that fuel is burning. What type of fuel? Quarter mile, I used a gallon a run. C12. That includes warming it up in the morning, driving it to the lanes and back, plus the run. Obviously less than a gallon to go A to B. Based on memory, maybe 3/4 of a gallon from the trailer, to the lanes, down the track and back to the trailer. Maybe. Granted, I wasn't moving a huge amount of air, making big power or using a big carb,
Re: Cold fuel
[Re: CMcAllister]
#3016205
02/17/22 02:42 AM
02/17/22 02:42 AM
Cab_Burge
i use to count on around a 1/2 gallon per 1/4-mile run bracket racing in SO CA with both race gas and pump gas with the Duster. My current E85 bracket car uses around 3 gallons to warm it up doing 3 laps in the morning in the pits and drive it back after 3 1/8 mile pass at Madras, OR ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) This car is hard to get heat and keep heat in the motor using E85 hence the extensive warming up each morning before racing it ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) All my other cars got hot a lot quicker on gasoline than this car does, even though it is making a lot more power than the gas motors did ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
Re: Cold fuel
[Re: hemienvy]
#3016235
02/17/22 10:08 AM
02/17/22 10:08 AM
Posts: 693 Dunnellon, FL
longram60
Dunnellon, FL
I have to ask a question here.
The colder a liquid is, the more heat it takes to evaporate it. Liquid fuel doesn't burn, only vaporized fuel burns.
If you send cold fuel to the carb, it seems to me you would have to run a richer mixture just to get the same amount of vaporized fuel, to burn. What happened to the rest of the liquid, unburned fuel ?
This is a different argument from having colder intake AIR, which is already vaporized.
If the cold fuel particles don't or can't absorb enough heat in the few milliseconds it takes to travel from the carb discharge tube to the cylinder, it won't burn. And it doesn't necessarily all evaporate in the intake stroke, or even in the compression stroke.
I have heard of bracket racers going through a gallon and a half of fuel in one run. There is no way all that fuel is burning. In a race application, you don't want fuel vaporizing in the intake. The vaporized fuel displaces oxygen. You want just enough vaporization to start the combustion process. Here is an article about carb boosters, but later goes on to explain cold intakes vs warm. https://www.motortrend.com/how-to/0511phr-carburetor-boosters-tech/
1979 AMC Spirit, NHRA Q/SA
Re: Cold fuel
[Re: longram60]
#3016368
02/17/22 07:23 PM
02/17/22 07:23 PM
Posts: 8,182 Detroit, MI
CokeBottleKid
Detroit, MI
I've seen that EM episode, you have to take these things with a large grain of salt guys FB is a smart guy but these tests hardly control all the variables etc and are only representative of their one test setup (in this case a BBC with huge heads, a huge intake and relatively short runners). Colder air makes more power, less heat transfer through the intake tract to the air, makes more power. Cold fuel may also play a part, but saying a cooler intake makes no difference is a bit misleading IMO despite what they 'saw' in the episode.
Re: Cold fuel
[Re: CokeBottleKid]
#3017086
02/20/22 12:53 PM
02/20/22 12:53 PM
Posts: 1,051 The Great White North
RAMM
I've literally tried this backwards and forwards on the dyno. I've packed the float bowls entirely with snow and put the fuel can out in the snow in the back of my dyno cell to no advantage. Packing the intake with snow can and will add up to 50ft/lbs at the hit but ,Cold fuel does not make power Cold air does. It does however affect the AFR--which way is up for you guys to debate. Your car went quicker because of 1000's of different variables including the possibility of the cold fuel making the AFR slightly richer/leaner. I wouldn't lose any sleep over it. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
Re: Cold fuel
[Re: B3422W5]
#3017088
02/20/22 12:57 PM
02/20/22 12:57 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If the car was on the trailer outside....... wouldn’t the fuel in the cell be the same temp as the fuel in the can?
Re: Cold fuel
[Re: RAMM]
#3017089
02/20/22 12:57 PM
02/20/22 12:57 PM
CSK
Pattison Texas
I've literally tried this backwards and forwards on the dyno. I've packed the float bowls entirely with snow and put the fuel can out in the snow in the back of my dyno cell to no advantage. Packing the intake with snow can and will add up to 50ft/lbs at the hit but ,Cold fuel does not make power Cold air does. It does however affect the AFR--which way is up for you guys to debate. Your car went quicker because of 1000's of different variables including the possibility of the cold fuel making the AFR slightly richer/leaner. I wouldn't lose any sleep over it. J.Rob Thanks for the real world response !!!! ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
