Re: Quality lower ball joints. [Re: BlueRacer69] #3017751
02/22/22 03:18 PM
02/22/22 03:18 PM
BlueRacer69 Offline
BlueRacer69  Offline
Originally Posted by BlueRacer69
I need to replace my upper and lower ball joints too. Is the stuff that PST sells any good, and who makes their stuff? Thanks.
Anybody?
Re: Quality lower ball joints. [Re: BlueRacer69] #3017763
02/22/22 03:47 PM
02/22/22 03:47 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Jumping in here and hoping I stay reasonably on topic.
The next step in my front end rebuild is... replacing the lower ball joint arms. I purchased Moog K781/K783 assemblies last fall after one of them finally came off back order. They definitely look beefier than the parts on the car now.
I also purchased some NOS TRW lower ball joint arms while waiting to see if the one missing Moog part was ever going to be available again. The TRW stuff looks basically like what's on the car now, and I have no idea how old it is. The instructions in one of the TRW boxes has a 1978 date on it.
Threads like this always throw me off since I was sure I was buying the "better" parts w/ new "Made in America"-labeled Moog. The boots on the old TRWs should be replaced, but otherwise they're just new old standard stuff. Now I'm second-guessing myself on which parts to install. shruggy
Oh, I'm pretty sure I read that there's something different about the Proforged lower ball joints' geometry than OEM. I'd like to be more explicit, but didn't keep my notes from when I was researching parts.
EDIT: I think we already installed the Moog lower ball joints and were only waiting on the correct tie rod ends to complete the reassembly. That's what happens when you don't wrench on the car when the cold weather sets in. whistling
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Quality lower ball joints. [Re: Brad_Haak] #3017806
02/22/22 06:54 PM
02/22/22 06:54 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I'm just going to go with nos ball joints for the lowers. Has anybody tried qa1 for the upper ball joints? They're usa made and all of qa1s parts I've used so far are excellent quality. Also, has anybody used the polyurethane boots that energy suspension sells? I was looking into a set of their ball joint and torsion bar boots.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Quality lower ball joints. [Re: 73cuda340] #3017813
02/22/22 07:19 PM
02/22/22 07:19 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I would go with NOS first although I think the American made Moog stuff is okay EXCEPT the rubber in the grease boots, which of course almost makes them useless if you have to still source those. I looked for just grease boots for my AHB Diplomat and someone was selling NOS ones for $60 a piece!!! Just the boots! No thanks.
Facts are stubborn things.
Re: Quality lower ball joints. [Re: 73cuda340] #3018899
02/25/22 05:55 PM
02/25/22 05:55 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Originally Posted by 73cuda340
I'm just going to go with nos ball joints for the lowers. Has anybody tried qa1 for the upper ball joints? They're USA made and all of qa1s parts I've used so far are excellent quality. Also, has anybody used the polyurethane boots that energy suspension sells? I was looking into a set of their ball joint and torsion bar boots.
The QA1 upper and lowers are my answer when I go to rebuild the front end on my Demon the lowers in the rare parts links are half the cost of QA1 and if you're not building a concourse restoration I'm certain they have better engineering/design.
eBay-cdwmotorsports
