269/275 solid roller install
#3014816
02/12/22 08:44 PM
02/12/22 08:44 PM
Posts: 8,048 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Checking valve to piston clearance on intake at 10*ATDC results in 0" clearance as the valve opens and on exhaust 10*BTDC results in .090" clearance as the valve closes. Looks like new 1.5 intake rockers are in order. Can someone tell me proper way to map the lobes at .050, .100, .200, .300, .400, .500, .600, .700? Max lift came in at .710" on int. and .668" on exhaust. I use 1.6/1.5 HS rockers currently, soon to be 1.5/1.5, Cam lobe spec .4300/.4300.
Re: 269/275 solid roller install
[Re: 440Jim]
#3014848
02/12/22 10:16 PM
02/12/22 10:16 PM
Posts: 43,364 Bend,OR USA
Cab_Burge
[Re: 440Jim]
#3014942
02/13/22 10:10 AM
02/13/22 10:10 AM
Posts: 2,015 Apollo, PA.
B1MAXX
Apollo, PA.
I would borrow or try to get my hands on a 1.5 first might not provide much (enough) change.
[Re: mopar dave]
#3014968
02/13/22 11:25 AM
02/13/22 11:25 AM
Posts: 16,934 NC
440Jim
NC
Cam lobe spec .4300/.4300. Changing the intake from 1.6 rockers to 1.5 will likely give you roughly 0.043" at max lift. But at 10 ATC, the lobe is open about 0.190-0.200" so the reduction in valve lift at that point will be roughly 0.019" Changing the ICL position 2 degrees will change it roughly 0.015". You can actually make this change now, and see how much it helps you.
[Re: mopar dave]
#3014998
02/13/22 12:45 PM
02/13/22 12:45 PM
mopar dave
Mt Morris Michigan
Something else i notice is, the exhaust vave opens as stated on cam card, but closing spec is way off according to my measures. Should close on 25.5, i think it was actually closing at 75. It opens 70. The intake open spec is consistant with the card,but the closing point is not. What is the proper way to get the closing points?
[Re: mopar dave]
#3015223
02/14/22 02:26 AM
02/14/22 02:26 AM
Cab_Burge
[Re: mopar dave]
#3015246
02/14/22 08:29 AM
02/14/22 08:29 AM
Posts: 4,457 Washington
madscientist
Washington
Cab, what is your method of checking v/p clearance with heads on motor? Dave, the only real way to know what your P/V is is to use clay on the pistons and use the springs you are going to run and the head gasket you are going to run at the lash you want to run and turn it over. If you do the soft spring method you will have way more clearance than you think you do. This is because no matter what rocker you have, if it’s built correctly the ratio will be .3-.5 or so higher than the nominal ratio. Has to be because all rockers flex under load. I’ve seen guys machine the valve pockets because they did the soft spring deal, or change the ICL because they used soft springs when in reality under actual spring loads they had more than enough clearance. I stopped using soft springs to check P/V in about 1986. It’s just not a good way to check that.
