Re: V-10 cooling on hot trip [Re: SALEM1912] #3020987
03/05/22 07:57 AM
03/05/22 07:57 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Wasn’t there a period where the “Heavy Duty Truck Design” V10 thermostats were defective from the factory?
Magnum V8s had a stamped steel coolant pump impellor design that would go bad if the antifreeze got old or had the wrong chemistry, due to cavitation.
There was a TSB on this.
Did V10 coolant pumps also have stamped steel pump impellors?
Re: V-10 cooling on hot trip [Re: 360view] #3021561
03/07/22 04:39 PM
03/07/22 04:39 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
1998 3500 V10 140,000 miles 4:10
19,500 total weight 28 ft trailer slide in camper , no problems, most time turn off o/d on big hills and set cruise at 60 mph on hills, 7/8 mpg
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: V-10 cooling on hot trip [Re: 360view] #3021811
03/08/22 09:40 AM
03/08/22 09:40 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
The early V10 had plastic t-stat housings that’d crack/leak. They were replaced by an aluminum unit. Both this housing as well as the timing cover we’re prone to corroding if cooling sys maintenance not followed.
