Re: 269/275 solid roller install
[Re: mopar dave]
#3015283
02/14/22 10:29 AM
02/14/22 10:29 AM
Posts: 717 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
A few times that I have needed to know what the V/P clearance after the engine is on the dyno, I used a length of some .090 acid core solder, just put it in through the spark plug hole, towards the intake valve and crank the engine over by hand, put it out and measure with some calipers, then do the exhaust.
Joe
Without Data, you’re just another guy with an opinion.
[Re: B1MAXX]
#3015354
02/14/22 01:41 PM
02/14/22 01:41 PM
Posts: 8,048 Mt Morris Michigan
mopar dave
Mt Morris Michigan
.020” on both valves. Harland Sharp just told me there could be as much as 1 full ratio deflection between a checking spring and a heavy valve spring. Measure the rocker as valve opens and then the retainer as valve opens to figure deflection using checking and 1243 springs .Changing to a 1.5 rocker won’t fix it.
[Re: B1MAXX]
#3015446
02/14/22 05:19 PM
02/14/22 05:19 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Put it at 106, check the clearance, then measure/figure in the deflection. That’s what I do on the ones where the measured clearance when using checking springs is close/marginal. Since the spring pressure hasn’t gotten real high with the lifts you see when the V/P clearance is closest, there usually isn’t all the much deflection at that point. I checked some HS “1.6’s”, and they were 1.67 with a checking spring......and still 1.63 with 700lbs open load at .700-ish lift. I’d say, if everything was as it should be, and you come up with “zero” V/P intake clearance with a checking spring, and you already have the exhaust clearance near the min....... you’re not going to be able to get to what most would consider “adequate” intake clearance(for me that’s about .050” min) by changing the RR by .1, and moving the cam 2*. Plus, whatever you gain on the intake side by moving the cam...... you’ll lose a similar amount on the exhaust. Off the top of my head I’d say moving the cam 2* will give you about .016”, and dropping the RR by .1 you’d get another .020” or so. You’d go from zero with the checking spring to .036”. You’d need another .015” deflection at that lift point to get it to .050”(and then there’s the question of if you’re comfortable with .050 on the intake, and whatever you lost on the exhaust by moving the cam).
[Re: mopar dave]
#3016025
02/16/22 02:46 PM
02/16/22 02:46 PM
Posts: 43,375 Bend,OR USA
Cab_Burge
