V-10 cooling on hot trip #3014650
02/12/22 11:17 AM
02/12/22 11:17 AM
Duluth, Minnesota
Moondog Offline OP
Moondog  Offline OP
Duluth, Minnesota
Hi all, I am planning a family vacation from Minnesota to Yellowstone in middle of summer pulling a 5000 pound travel trailer with my 2000 V-10 Ram that has 110,000 miles on it. It runs great locally, but have heard nightmare stories of the V-10 having bad head gaskets. I don’t know if that is true, but I plan on flushing cooling system and replacing water pump, thermostat, serp belt, and hoses for peace of mind. I hate to have any issues in 95 degree weather with an angry wife and family. I’m sure many of you know what that is like. Anyhow, any other suggestions? Thanks in advance.
Founder of, and reason for, the RED LIGHT RACE TEAM
Re: V-10 cooling on hot trip [Re: Moondog] #3014688
02/12/22 01:41 PM
02/12/22 01:41 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Don't use over drive when towing! Sure way to cook the trans. If your truck doesn't have the optional trans cooler (tow package) i would add one. Possibly add a "pusher" electric fan to help with cooling.
Re: V-10 cooling on hot trip [Re: Moondog] #3014750
02/12/22 06:04 PM
02/12/22 06:04 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I did a trip during August to Grand Tetons, then Yellowstone from NJ, 96 1500 Ram (3.92 gears) towing an almost 9000lbs trailer with all gear. Yes, engine coolant got a little hot on the long climbs, but not bad. I am running an underdrive crank pulley (180F t-stat), so whenever I slowed down, I had to keep RPMs up to keep things cool.
To me more importantly is your trans. I have a nicely built Level 10 trans in mine, so it was ready for it. I also have a deep pan and factory tow package cooler. I have a temp gauge in the pan and wow... does that fluid get hot on long climbs, over 230F easy (peaks higher). It was hard for me to look at that gauge. I would be more concerned about your trans fluid and for sure, if your trans cooler lines are original, keep an eye on the rubber sections up front. I would say bring some 3/8" trans line and some clamps or change that out ahead of time. They blow and you are done.
You may be disappointed in the naturally aspirated engine above 5000 feet. I swear it was like there was a parachute behind me going through Wyoming. Full throttle at times and could not maintain speed. Carry a spare 5 gallon gas can, as at times there are long stretches of nothing...
Oh and please have good brakes as well (truck and trailer). The downhill sections pulling a trailer will make you pucker, in particular when you start seeing the runaway ramps for trucks. Pulse your brakes.
But I would do the trip all over again. Loved it!
Re: V-10 cooling on hot trip [Re: Moondog] #3014904
02/13/22 08:21 AM
02/13/22 08:21 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
You didn't specify what trans you have but I will 3rd the trans temp and O/D if its an auto. Towing 5k should be no sweat.
Re: V-10 cooling on hot trip [Re: redraptor] #3015015
02/13/22 01:07 PM
02/13/22 01:07 PM
Duluth, Minnesota
Moondog Offline OP
Moondog  Offline OP
Duluth, Minnesota
Thanks everyone, I learned a lot. Transmission is stock overdrive, which I plan to not use. Pusher fan, trans temp, and extra gas, got it!
Re: V-10 cooling on hot trip [Re: Moparite] #3015016
02/13/22 01:08 PM
02/13/22 01:08 PM
Alberta
440_Offroader Offline
Alberta
For general towing, I keep the rpms up, and don't have the pedal to the floor, going up long hills. Slow and steady. Should keep your coolant cooler. I know you don't want to be that slow guy going up hills, but you don't want to be that guy with the hood up on the side of the road either. As mentioned, 5000lbs should've a cake walk for your V10.
For an auto, if you can keep the torque converter locked up, that will keep your tranny temps lower. Diesel trucks have a way you could wire up a switch to keep it locked up. I don't have the switch set up in my 01 diesel, but when the torque converter is locked, the transmission temp stays below 160F. That's pulling 10,000lbs. With some research, I'm sure you could wire in a switch to do the same for the V10.
Re: V-10 cooling on hot trip [Re: 440_Offroader] #3015093
02/13/22 05:33 PM
02/13/22 05:33 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Had a 96 and 01 V10 with no cooing issues ever. My 01 Cummins had a radiator go out on me last year while towing from Chicago to Florida and went bad in Birmingham. Autozone had one so Ubered over there and back then changed it in a gas station parking lot, easy peasy! V10's use the same radiator and they have the plastic side tanks, check to see if there is any weapage on yours now...
JB Rhinehart, Realist
A-Body's RULE!
Re: V-10 cooling on hot trip [Re: Moondog] #3015196
02/13/22 11:34 PM
02/13/22 11:34 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
I got a V10 if u have 4.10 gears u could tow in overdrive no problem 3.55 I don't know
Re: V-10 cooling on hot trip [Re: d-150] #3017339
02/21/22 01:15 PM
02/21/22 01:15 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a 96 2500 V10 with 3:55's and always tow in over drive with never any issues with trans or over heating of any kind. 174,000+ and it is still 95% all original.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: V-10 cooling on hot trip [Re: 6PKRTSE] #3017584
02/22/22 01:25 AM
02/22/22 01:25 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Same here, 190k on the truck and never had any problems towing in Overdrive.
I'm also not dealing with serious mountains just some mid-western type hills and mostly flat interstates towing a 28 foot enclosed trailer. twocents
Re: V-10 cooling on hot trip [Re: SNK-EYZ] #3017602
02/22/22 07:43 AM
02/22/22 07:43 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Towing in OD will heat up your trans and put extra strain on the OD. If you look in the owners manual of your truck it will tell you to not tow with it on! Of course it depends on what you are towing.
Re: V-10 cooling on hot trip [Re: Moparite] #3017818
02/22/22 07:39 PM
02/22/22 07:39 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
thats why I like to add trans temp gauges, so I can monitor trans temp. and oversized trans coolers piggybacked with the original cooler in the radiator. There are things taht can be done with the trans behind that v10 to improve cooling and longevity as well.
Re: V-10 cooling on hot trip [Re: Moondog] #3017863
02/22/22 09:39 PM
02/22/22 09:39 PM
Guitar Jones Offline
The V10 trans is essentially the same as the diesel trans. Towing in OD is not a problem, especially only 5000 pounds. My V10, with 3.55s pulled my 30 ft enclosed at 80 MPH and never a problem. On long mountain grades you may need to turn the OD off but I wouldn't leave it off. Only turn it off when you need to. Don't lug the engine, slow down and downshift the trans.
Re: V-10 cooling on hot trip [Re: Moparite] #3018637
02/24/22 09:20 PM
02/24/22 09:20 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If you can maintain converter lockup tow in OD. You’d be amazed at how cool a 47RE runs down the highway in lockup.
Re: V-10 cooling on hot trip [Re: Guitar Jones] #3018645
02/24/22 09:40 PM
02/24/22 09:40 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
GJ is spot on with his advice…. Honestly we didn’t see the torque converter issues with the V10 like we did the diesels of that era.
Re: V-10 cooling on hot trip [Re: J_BODY] #3018647
02/24/22 09:46 PM
02/24/22 09:46 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
The biggest downfall of the V10 was the owners and their lack of cooling system maintenance. I don’t recall much of a head gasket issue as much as porous heads but that was back in the mid 90’s. The corrosion probability was quite high as they still used the green 3yr coolant and the more often they were flushed, the better.
Re: V-10 cooling on hot trip [Re: 6PKRTSE] #3018913
02/25/22 07:23 PM
02/25/22 07:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I always tow in OD with my 518s a-500s and now 68RFEs, the only time I turn it off is if it's at the point where it is running with the lock up disengaged or constantly locking and un-locking, then I drop it into direct. Another thing you can do is just watch your trans temp with an add on gauge.
I worked 2 years in a dodge dealership towards the end of V10 production and never did a head gasket job on them, as a matter of fact never saw any of the other mechanics in the shop do one either. I have seen a couple bad rockers on em. I have only seen about 2 V10 engines actually go bad in my life and I been a dodge specialist for over 20 years now (dang I'm getting old!).
Re: V-10 cooling on hot trip [Re: HotRodDave] #3018975
02/25/22 11:38 PM
02/25/22 11:38 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Only real engine failures I remember was from detonation/crossfire from poorly routed low quality plug wires. V-10 was really a great package in its day….. but man that mpg towing! The coolant deal never really caused any drivability issues if you kept the reservoir full. If you run across one in a salvage yard good aluminum t stat housings and the front timing covers are getting hard to find.
Re: V-10 cooling on hot trip [Re: J_BODY] #3019105
02/26/22 03:51 PM
02/26/22 03:51 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
They certainly know how to drink gas! My current 2011 ram 2500 I built a 392 for tows almost as good as my old V10 but over %50 better MPG
Re: V-10 cooling on hot trip [Re: HotRodDave] #3019224
02/26/22 09:15 PM
02/26/22 09:15 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
" flushing cooling system and replacing water pump, thermostat, serp belt, and hoses"
I would also look at the fan clutch and maybe replace.
