Re: Thread lock on cam gear bolts?
[Re: A727Tflite]
#3015690
02/15/22 03:47 PM
02/15/22 03:47 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
No he isn’t. Race cars are prone to vibrations at different rpms than stock production vehicles. Then most of us add solid engine mounting and there’s nothing to absorb it. There is not one good reason NOT to use loctite. Carry on.
[Re: pittsburghracer]
#3015701
02/15/22 04:22 PM
02/15/22 04:22 PM
Posts: 3,092 Michigan
A727Tflite
No he isn’t. Race cars are prone to vibrations at different rpms than stock production vehicles. Then most of us add solid engine mounting and there’s nothing to absorb it. There is not one good reason NOT to use loctite. Carry on. Been doing this over 50 years, never seen any bolts back out when torqued to specs. I suppose you Loc-Tite your rod bolts/nuts, head bolts, crank bolt, etc.? But I do agree with you, no reason not to use it. Just not mandatory.
[Re: A727Tflite]
#3015739
02/15/22 06:27 PM
02/15/22 06:27 PM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
No he isn’t. Race cars are prone to vibrations at different rpms than stock production vehicles. Then most of us add solid engine mounting and there’s nothing to absorb it. There is not one good reason NOT to use loctite. Carry on. Been doing this over 50 years, never seen any bolts back out when torqued to specs. I suppose you Loc-Tite your rod bolts/nuts, head bolts, crank bolt, etc.? But I do agree with you, no reason not to use it. Just not mandatory. ^^^ agree, 100%. The very purpose of torque is stretch, every bolt in that engine had 5 engineers figuring out how it keep it tight. Every section in the FSM on the end pages have torque specs for a reason. BTW I have had solid mounts high lift cams and big springs, nothing came loose.
