Re: Thread lock on cam gear bolts? [Re: an8sec70cuda] #3015626
02/15/22 11:21 AM
02/15/22 11:21 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Originally Posted by an8sec70cuda
Red loctite here.
Me too but I use too much most of the time so I have cut back to the spec amount.
Re: Thread lock on cam gear bolts? [Re: bee1971] #3015627
02/15/22 11:22 AM
02/15/22 11:22 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Red LT here.
Rich H.
Esse Quam Videri
Re: Thread lock on cam gear bolts? [Re: bee1971] #3015630
02/15/22 11:24 AM
02/15/22 11:24 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Why not use a lock plate?
Re: Thread lock on cam gear bolts? [Re: sixpakdodge] #3015653
02/15/22 12:26 PM
02/15/22 12:26 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Nothing, tighten to specs, done. Have you ever pulled apart a 440 and found the cam bolt loose? Only rebuilt engines, mainly because the bolt-s were not torqued right.
Re: Thread lock on cam gear bolts? [Re: cudaman1969] #3015655
02/15/22 12:39 PM
02/15/22 12:39 PM
A727Tflite Offline
A727Tflite  Offline
X
Re: Thread lock on cam gear bolts? [Re: A727Tflite] #3015690
02/15/22 02:47 PM
02/15/22 02:47 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted by Transman
X
No he isn’t. Race cars are prone to vibrations at different rpms than stock production vehicles. Then most of us add solid engine mounting and there’s nothing to absorb it. There is not one good reason NOT to use loctite. Carry on.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: Thread lock on cam gear bolts? [Re: pittsburghracer] #3015701
02/15/22 03:22 PM
02/15/22 03:22 PM
A727Tflite Offline
A727Tflite  Offline
X
Been doing this over 50 years, never seen any bolts back out when torqued to specs. I suppose you Loc-Tite your rod bolts/nuts, head bolts, crank bolt, etc.?
But I do agree with you, no reason not to use it. Just not mandatory.
Re: Thread lock on cam gear bolts? [Re: A727Tflite] #3015739
02/15/22 05:27 PM
02/15/22 05:27 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
X
^^^ agree, 100%. The very purpose of torque is stretch, every bolt in that engine had 5 engineers figuring out how it keep it tight. Every section in the FSM on the end pages have torque specs for a reason.
BTW I have had solid mounts high lift cams and big springs, nothing came loose.
